Drivetrain Bad luck after M7 2%!
Old Dec 7, 2006 | 12:38 AM
  #76
JSWMCS's Avatar
JSWMCS
did the installer heat the M7 pulley to 475 degrees prior to installing it??
- john
Old Dec 7, 2006 | 12:41 AM
  #77
JSWMCS's Avatar
JSWMCS
it is an interference fit. the part needs to be expanded by heat and then torqued to 85 ft-lbs.
Old Dec 7, 2006 | 12:44 AM
  #78
JSWMCS's Avatar
JSWMCS
was the M7 Crank pulley heated to 475 degrees in an oven prior to the install? the piece is an interference fit so it needs to be expanded by heat to get it pressed in far enough on the crank shaft.
Old Dec 7, 2006 | 01:25 AM
  #79
MarioKart's Avatar
MarioKart
Vendor
I was told there was no need to heat it up, it was just a bolt on. I know some of the supercharger pulley's are like that. heat and release.
M
Old Dec 7, 2006 | 01:48 AM
  #80
JSWMCS's Avatar
JSWMCS
Peter told me it needed to be heated first.
BTW i am an M7 dealer.
ask him and see what he says just to be safe.
Old Dec 7, 2006 | 01:49 AM
  #81
JSWMCS's Avatar
JSWMCS
man your as bad as me i'm a night owl too!!
Old Dec 7, 2006 | 03:07 AM
  #82
jibeho's Avatar
jibeho
Originally Posted by MarioKart
Well M7 is sending me a new 2% pulley for me for my suffering. I do beilieve that the install was the whole problem. It looks like the crank bolt was put on with way too much torque and stripped the crank case. Hopefully when this is all done I will get to enjoy my car gain with the new M7 pulley. I guess even if products are good, the install can still ***** it up.
Mario
Correct me if I'm wrong but how hard is it to strip the threads in the crank. It is my understanding that these are made of some pretty strong metal.
Paul!
Electrical
16
Feb 18, 2025 06:29 AM
IrishMCS
Dec 1, 2015 04:21 PM
simron
Sep 23, 2015 10:02 PM
riff42
Sep 22, 2015 03:07 PM
StillK
R55 :: Clubman Talk (2008+)
Sep 10, 2015 12:17 PM
