Electrical FTP into CHAMP2?
Old Sep 5, 2015 | 12:18 PM
Paul!'s Avatar
Paul!
FTP into CHAMP2?
Has anyone been able to successfully FTP into CHAMP2 on an R56? I'm trying to pull the 1B FSC file but I'm having absolutely zero luck.
I've tried:
- Going through the glovebox USB with a D-Link E100 adapter (no connection at all).
- Going through the center column USB with the same adapter. (I get a link but no IP is assigned. If I run a DHCP server, I get an IP address assigned to my laptop, but nothing requests an address from the DHCP service on my laptop.)
- Going through the OBDII port using an E-Sys cable (I can find an IP address for a unit who's MAC address corresponds to an Alpine unit (CHAMP2!), but nothing to FTP into. I've done a full port scan on the responding IP address, but nothing I can 'log in' to. The answering TCP ports are 135 (DCE Endpoint resolution (?)), 1000 (doesn't outright refuse a ping but doesn't respond to anything either), 5001 (same), 7331 (some kind of diagnostic output - I can see various data go flying by when I do anything with the head unit), and 50850 (responds with 'EL Server here, protocol version 1' and more of what looks to be diagnostic output).
I've tried to enable the glovebox USB port through Tool32 but no luck.
Ultimately my goal is to FTP into and grab the 1B FSC file. This file is... useful in performing Navigation Map updates.
Anyhow, any and all ideas are appreciated!!
-Paul
Old Sep 5, 2015 | 12:39 PM
rkw's Avatar
rkw
I cannot imagine that the car is hosting an FTP server. Do you have evidence that BMW (or any other manufacturer) does this?
Is this the sort of thing you're trying to do: http://www.m5board.com/vbulletin/e60...-2015-2-a.html. Vendor MiniNavPro on this forum is providing a similar service.
Old Sep 5, 2015 | 03:55 PM
Paul!'s Avatar
Paul!
Uote
Believe it or not it does. See here for an example: http://www.e90post.com/forums/showthread.php?t=1154524
The above link is instructions for an E9x (which a R56 is electronically somewhat similar to) on how to access the FTP server on the CIC (Car Information Computer). The MINIs unit is CHAMP2 (not sure what the heck that stands for! ), but it accomplishes most of the same functions.
Now as to *why* MINI/BMW has an FTP server, I have no idea. Troubleshooting? Diagnostics? Upgrades? Dunno. But some have figured out how to get in there and retrieve items of interest (fairly safe) and to mess with internals (not recommended).
Ultimately, yes! But what the guy in the above link is doing (and what I'm guessing MiniNavPro is also doing) is taking the last 7 digits of a VIN, entering it into the BMW ASAP website, and generating a FSC code to unlock maps. Which is fine.
Alternatively though, you can pull your own '1B' file from your BMW or MINI. From there, by using a few other programs, you can generate your own FSC. You can also generate an FSC that would be valid through 2099 so you would *never* have to generate another FSC again!
-Paul
Old Sep 5, 2015 | 05:55 PM
siriuszero's Avatar
siriuszero
Wondering if you could use a DCAN cable and NCSExpert to accomplish the same. CIC was the older nav headunit and was replaced with the CHAMP headunits with the LCI refresh for MY2011 (if memory serves correct). I have a feeling the process is quite different for CHAMP. What year MINI do you have?
EDIT: Actually, I may be backwards....I'm thinking of CCC... CIC is newer than CHAMP I think
Old Sep 5, 2015 | 09:44 PM
Paul!'s Avatar
Paul!
Lol, not sure the order! I have a 2012 JCW hardtop.
In theory, you can use a D-CAN cable with NCSExpert and/or Tool32 to accomplish the same. But I'll be damned if I can't figure out how to do it. I've been trying off and on for months now with no luck. Supposedly, If I had an ICOM cable, this process would be easy(ier). I may ask the local indy service shops to see if they had a cable I could borrow for about two minutes...
-Paul
Old May 12, 2017 | 12:24 PM
sectormns's Avatar
sectormns
Hi, Paul!
I've the same issues as you did. No respond for glovebox USB. Have you managed to connect as FTP?
Old Feb 7, 2020 | 03:59 AM
slimjimtell's Avatar
slimjimtell
deleted, wrong thread
Old Mar 27, 2021 | 12:03 AM
Milkbottle's Avatar
Milkbottle
Sorry wrong thread
Old May 10, 2021 | 09:42 AM
ARTAM's Avatar
ARTAM
Wrong tread sorry
Old Jul 17, 2021 | 11:28 AM
olegflash's Avatar
olegflash
guys, just got my 2019 f60.
appreciate your help with Carplay activation )
Old Jul 29, 2021 | 03:45 PM
diambience's Avatar
diambience
*** wrong thread **** can't find delete sorry
i searched ebay for a head unit with 8.8 screen, is the price really over a grand?
Old Sep 22, 2021 | 09:16 PM
Keith Chisholm's Avatar
Keith Chisholm
@sb2002 I have spent too much time researching this to activate carplay on my 2019 MINI Countryman SE All4. My VIN # is WMZYU7C55K3F93429. It has a 6.5" touch screen without nav. I took a picture of the head unit and screen. Let me know what the best option is. Thanks!
Old Dec 16, 2022 | 11:40 AM
jwoodhi5's Avatar
jwoodhi5
@sb2002 HELP WITH CARPLAY/digital clister
HEY GUYS-
new here. But i hope i have finally found the place i need to be. Desperately want to add CarPlay to my 2018 f60 countryman. Touch screen…no no on it. Assuming i need new head unit because i also need one that has a “most port” so i can add digital cluster. I would need them both to come coded as i have no idea about that. I hear @sb2002 is the king. Please god someone help me end this headache haha. Thank you so very much.
Old Sep 23, 2024 | 11:22 AM
Lerjo34's Avatar
Lerjo34
HI @sb2002 can you help me, i'm new here. Trying to find how to upgrade to CarPlay my F60 2017. Thank you!
Old Sep 30, 2024 | 04:51 PM
MotoRobot's Avatar
MotoRobot
Hi @sb2002 I have a F60 2019 Countryman without CarPlay - may you be able to assist? I can PM VIN if so.
Thank you very much.
Old Jan 10, 2025 | 12:55 PM
mightyMONTY's Avatar
mightyMONTY
@sb2002 hi, are you still active?
Old Feb 18, 2025 | 06:29 AM
Ninja1317's Avatar
Ninja1317
HI @sb2002 i need some help, i was searching all over the internet and dont really find a good solution, i'm trying to find how to add CarPlay to my F60 2018, EVO, touch but no navigation.
Thanks a lot
ssoliman
88
Sep 15, 2025 09:09 AM
Comasynthesis
Electrical
146
Nov 28, 2018 06:24 PM
DeadEye
Apr 27, 2006 06:06 AM
Skoobeedu
Feb 24, 2004 09:39 AM
CharlesT
Nov 10, 2003 02:56 PM
