Drivetrain What size serpentine belt? 16%/2% pulley combo.
Old Nov 27, 2006 | 06:52 AM
Boludo's Avatar
Boludo
Hey guys. I need some quick help. I have an 05 MCS with a 16% and a 2% crank pulley. I was at the track when I lost power and the temp gauge shot up. Anyway, it turns out that I shredded the belt. I have about 8500 miles on the car. I need to pick up a belt today but not sure on what size. Can anyone tell be what size serpentine belt I need?
Thanks.
Old Nov 27, 2006 | 06:56 AM
chuckt's Avatar
chuckt
Will @ M7 told me that the stock size was correct for that combo. What size were you running?
Old Nov 27, 2006 | 07:05 AM
Partsman's Avatar
Partsman
Legion_of_Doom
If you go to NAPA, the 060539 will work. That's what i'm running with the M7 16%/2% combo.
Old Nov 27, 2006 | 07:42 AM
Boludo's Avatar
Boludo
Excellent. Thanks for the help and part number. I called NAPA and they do have them in stock. Does this sound right; they said it's made by Gates and the size is 54.521 inches.
Old Nov 27, 2006 | 08:17 AM
Partsman's Avatar
Partsman
Legion_of_Doom
All the NAPA belts and hose are made by Gates. 54.5" sounds right.
Old Nov 27, 2006 | 08:42 AM
Boludo's Avatar
Boludo
Partsman,
Have you had problems shredding belts with the 16/2 combo. I only have about 5k miles on that combo and 2 track days before mine shredded.
Old Nov 27, 2006 | 08:59 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Partsman,
The only issue i've had was with a rock stuck in my AC compressor pulley, wiping out one single groove.
No other issues.
What belt were you running?
Old Nov 27, 2006 | 09:40 AM
Boludo's Avatar
Boludo
Actually I have no Idea what belt I was running. The mechanic put it on. I will put this one on though.
Do you run yours on the track?
Old Nov 27, 2006 | 09:51 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Not yet.
Do you have a pic of the shred?
Old Nov 27, 2006 | 10:11 AM
Boludo's Avatar
Boludo
No pictures because I have no idea where it went. I only have a few thin strands of belt floating around the engine compartment.
Old Nov 27, 2006 | 11:04 AM
Partsman's Avatar
Partsman
Legion_of_Doom
I hope you have a tensioner stop.
Old Nov 27, 2006 | 12:49 PM
Boludo's Avatar
Boludo
I don't have one but the guy that's helping me with it has one.
Old Nov 27, 2006 | 12:52 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Did you have any other damage from the belt braking?
The tensioner stop is cheap insurance, go with a custom cable type.
Old Nov 27, 2006 | 03:26 PM
Boludo's Avatar
Boludo
I don't think there is any other damage but I will find out tonight.
Old Nov 27, 2006 | 04:38 PM
StayTuned's Avatar
StayTuned
Thanks.
Hey Boludo,
I have seen a lot of these shredded belts and recommend that when anyone switches to a new SC pulley that they specify one with a "TRUFORM" TOOTH PROFILE. "TRUFORM" is the profile used by Original Equipment Manufacturers. The profile rounds the sharp peaks on the pulley and prevents premature belt wear and breakage, helps the belt track correctly, and runs quieter.
Loren
Old Nov 28, 2006 | 09:21 AM
Boludo's Avatar
Boludo
Cravenspeed, That does make sense to me. It does seem that mine are pretty sharp. If I continue to have problems I will switch them out.
Partsman, I actually misunderstood you when you asked if I had a tensioner stop. I thought you were talking about something different, so basically I have no clue what a tensioner stop is. Can you explain it.
Old Nov 28, 2006 | 09:34 AM
Partsman's Avatar
Partsman
Legion_of_Doom
A tensioner stop keeps the tensioner from whacking the crank pulley when the belt breaks...
The one pictured is the basic bar type, however there's a fine line between getting tight enough so it won't rattle, and not so tight where it won't slide.
I made a custom one out of some stainless cable and stainless ends with 8mm holes. This way I can tighten it down and the tensioner will still move normally.
Old Nov 28, 2006 | 09:49 AM
jibeho's Avatar
jibeho
Originally Posted by CravenSpeed
Hey Boludo,
Loren
Craven,
When I Google Truform tooth all I get is your site and a bunch of sites for pantyhose
Are you the only ones that use this wonder technology?
Old Nov 28, 2006 | 03:34 PM
markldriskill's Avatar
markldriskill
Originally Posted by jibeho
Craven,
That's funny -- Yahoo! returned a bunch of prosthetics sites , and Jeeves took me to "marital aids"
Old Nov 28, 2006 | 06:01 PM
CravenSpeed's Avatar
CravenSpeed
Vendor
Truform in its True Form
Here at Craven Speed, we take pride in our inventive nature. We are into invention in all its various forms, including vocabulary... Google "Flexitize". As we all know a true inventor draws on previous experience and expertise to expand the known universe. When we set out to create we brought with us vast experience with pantyhose, prosthetics and marital aides. We applied our understanding of these topics to their most logical application… pulleys!
[FONT=&quot]In short, Truform is merely a word we use to describe the difference between our pulleys, and some other pulleys. It would be really low of us to go around naming other manufacturers parts that we feel are superior or inferior to ours. In fact, we are not sure how anyone who would do that could look at themselves in the mirror. We just suggest that you take a good look at the part you are considering purchasing and decide if it looks like one that will eat your belt. There are plenty of good pulleys out there![/FONT]
Old Nov 28, 2006 | 08:12 PM
Boludo's Avatar
Boludo
Thanks Partsman, that helps out with the picture.
Old Nov 28, 2006 | 08:48 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Your welcome.
If you're on the track a lot, get some kind of tensioner stop on your car.
Old Nov 29, 2006 | 04:25 AM
jibeho's Avatar
jibeho
I was just replying to the previous post from CravenSpeed. Here is his quote
"I have seen a lot of these shredded belts and recommend that when anyone switches to a new SC pulley that they specify one with a "TRUFORM" TOOTH PROFILE. "TRUFORM" is the profile used by Original Equipment Manufacturers."
This lead me to believe that this was NOT an exclusive technology but more like "Mandrel" Bent exhaust. The poster should have said:
I have seen a lot of these shredded belts and recommend that when anyone switches to a new SC pulley that they specify one with a "TRUFORM" TOOTH PROFILE. "TRUFORM" was designed by Craven and is Similar to the profile used by Original Equipment Manufacturers.
Old Nov 29, 2006 | 08:22 AM
CravenSpeed
Vendor
Correct
Truform is not a term used by OEM, so you are correct, 'similar' would have been more appropriate.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
The_Kid
Nov 3, 2016 06:30 PM
larryd96
11
Sep 8, 2015 05:01 AM
M7Speed
Sep 3, 2015 07:48 AM
