Drivetrain Installed Detroit ByPass Valve. No more YO-YO!
Old Nov 23, 2006 | 03:06 PM
MarioKart's Avatar
MarioKart
Vendor
Ever since I bought my car 3 months ago I have always had a first gear lunge. The car would move forward and then bog down for a spilt second. I have driven other Mini's and they don't have this problem. I thought after I had software, pulley and Head/cam it would go away, but no. Yesteday I installed the Detroit BPV and voila the problem went away and now the car takes off smooth. Also the boost comes on faster and sharper, and I get 1psi more on the top end. The installs was fairly simple and took about 1.5 hours. You have to remove the CAi, aftercooler, TB and some clamps. Chad at Detroit said my MPG would drop and tiny bit but I have seen no drop. This is a great mod for many 02-04 Mini's, maybe even for 05-06 models. I should have done it sooner.
M
Old Nov 23, 2006 | 03:34 PM
JSWMCS's Avatar
JSWMCS
detroit tuned
do they have a website to see this product??
Old Nov 23, 2006 | 03:37 PM
BE4TNUT's Avatar
BE4TNUT
DT BPV
BEATNUT
Old Nov 23, 2006 | 03:45 PM
JSWMCS's Avatar
JSWMCS
thanks.
Old Nov 23, 2006 | 03:48 PM
jeffc's Avatar
jeffc
7th Gear
Did it resolve the whistle on your Alta CAI as well or did you not have that issue?
Old Nov 23, 2006 | 06:18 PM
pberry51mini's Avatar
pberry51mini
No Fear Gear
I have both the DT BPV and the Alta CAI and haven't ever had a whistle going on that I can hear.
The BPV definately smooths out things but I've been concerned about those that have said that it increases air temps in the intake charge.
Worth it though so far I'd say.
Old Nov 23, 2006 | 08:31 PM
jaynicholson's Avatar
jaynicholson
It completely eliminated the whistle from my Alta CAI.
Old Nov 23, 2006 | 10:14 PM
MarioKart's Avatar
MarioKart
Vendor
I never had it, or maybe I'm not sure what you mean.
Old Nov 24, 2006 | 01:59 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Originally Posted by pberry51mini
... but I've been concerned about those that have said that it increases air temps in the intake charge...
Both MSFITOY and I have measured higher IATs with the VGS than without (I just measured it today--data just in!) I've never heard any one link the DT BPV to higher intake temperatures. There may be, but if so it's smaller than the impact of the VGS.
cheers,
Old Nov 24, 2006 | 05:19 PM
90STX's Avatar
90STX
I have said that the DTBPV increases intake air temps, posting on the IC efficiency thread.
On my car, using a 19% and GRS, it increased them 10-12 degF at highway cruise speeds. Measured using a Scanguage II connected to the OBDII port.
Scott
90SM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
minimofo
Sep 9, 2015 10:29 AM
quickquest88
Aug 8, 2015 08:45 PM
