Drivetrain M7 Oil Catch Can install help
Old Nov 15, 2006 | 07:24 PM
irlracefan's Avatar
irlracefan
1. How do you get the tube off of the vacuum line (grey line), it is really tight?
2. Do you cut the line that was connected to the vacuum line to put the "T" connector in?
3. What did you do about the line that goes from the air box hose to the valve cover?
Any help would be appreciated.
irlracefan
Old Nov 15, 2006 | 07:58 PM
RA080624's Avatar
RA080624
wasnt that hard to pull off the gray tube what i did was put the cap on the gray tube and put it under my intercooler with mine there was a supplied hose that i had to cut into pieces i removed all of the stock tubes and put the pieces i cut in their place
irlracefan
Old Nov 15, 2006 | 08:01 PM
RA080624's Avatar
RA080624
here are the instructions i got with my mini madness catch can
File Type: pdf
Old Nov 16, 2006 | 04:11 AM
polizei's Avatar
polizei
Click the "OCC How To" in my sig, that might help you.
-Cody
Old Nov 16, 2006 | 07:40 AM
Bahamabart's Avatar
Bahamabart
irlracefan
Didn't you get the M7 directions? If you didn't contact Peter immediately. I just installed an M7 OCC and found the directions straight forward and clear. I followed the directions and had it done in no time at all. What took the longest was deciding where I wanted to put the can!
And yes, the stock connection / tubing can be hard to get off.
Old Nov 16, 2006 | 07:46 AM
irlracefan's Avatar
irlracefan
I got the install diagram, but didn't know if some of the stock tubing was used with the install.
Old Nov 16, 2006 | 08:52 AM
Bahamabart's Avatar
Bahamabart
lets see facing the engine - connection point left - iused the stock bent tubing (just rotated it) and hooked it up to the M7 tubing. Connection point right were the "T" goes - I cut the stock tubing - leaving enough for the "T" to connect.
if you want picks, I can send this weekend - just drop me a PM w/ yr email.
Old Nov 16, 2006 | 09:12 AM
irlracefan's Avatar
irlracefan
Thanks for the help. I now have a better idea on what to do.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
M7Speed
Aug 6, 2015 01:48 PM
