Drivetrain Alta or K&N CAI ???
Old Nov 5, 2006 | 04:59 PM
RoadFly's Avatar
RoadFly
Alta or K&N CAI ???
OK I need your input here give me your advice on CAI's is it going to be the ALTA or the K&N Typhoon? Also give me reasons why you chose the one you have please. Photos always welcome... love to look under the hoods. Thanks in advance.
Old Nov 5, 2006 | 05:18 PM
SayGoodbye's Avatar
SayGoodbye
If CARB requirements are a concern, the K&N is the way to go. If not, pick one of the others that gives you 3-5 hp.
Old Nov 5, 2006 | 05:31 PM
Longboard110's Avatar
Longboard110
i had the k&n and sold it. Its not much of a COLD air intake, its open to the hot air under the hood. The air inlet from the front is kind of "thrown" towards it from a distance, not piped directly into an enclosure where the filter is at.
Old Nov 5, 2006 | 05:37 PM
cartar452's Avatar
cartar452
go for the alta...
Old Nov 5, 2006 | 05:39 PM
tshubin's Avatar
tshubin
I have the k%n and only noticed a slight difference in power, could have been all in my head though....im retrospect, i would have liked to have the alta intake instead.
Now im giving in to my curiosity and gonna try the m7 AGS
If u want my used k&n, let me know.
Old Nov 5, 2006 | 05:48 PM
Motor On's Avatar
Motor On
The K&N CAI ends up being an HAI, and an expensive one at that. I got the ALTA, made my own top for $4 and insulated it so its a wee bit quieter when cruising (top makes it louder when I step on it and the intake is unaffected by heat soak for a good 10 min of stand still.
Here are some photos of my modded intake.
Old Nov 5, 2006 | 05:53 PM
tennis_man's Avatar
tennis_man
I have the K&N Typhoon and like it because it is CARB approved. But to get the most hp out of it I modified it by enclosing the filter in a box and added heat shielding to the tubing going from the filter to the throttle body.
Spade's Avatar
Spade
K&n
K&N all the way. I actually have mine connected directly to the TB. I took off the stock tubing so that the "cold" air would run right into it. It works great for me and I honestly feel a good difference... not mention, who doesn't like to hear the sound of the air getting "sucked" in?!
I'll show pics tomorrow. By the way, it's way easy to do and you can of course easily replace the stock back if you want or need to later for whatever reason.
Old Nov 5, 2006 | 06:08 PM
Longboard Mini's Avatar
Longboard Mini
ALTA.
Longboard
Old Nov 5, 2006 | 06:18 PM
TheSilverBullet's Avatar
TheSilverBullet
One more for the Alta... I've never drivin a car with the K&N but I love the sound of my Alta and the added power. just waiting to get the pulley inn!!!! lol
Old Nov 5, 2006 | 07:19 PM
jeffc's Avatar
jeffc
7th Gear
Here is my Alta install with insulation.
Old Nov 5, 2006 | 07:43 PM
cartar452's Avatar
cartar452
looks like that insulation blocks air from getting in??
Old Nov 5, 2006 | 07:47 PM
jeffc's Avatar
jeffc
7th Gear
The insulation is against the engine wall and does not restrict any airflow at all. The insultion was added to get rid of the low rpm whistle/squeking.
Old Nov 5, 2006 | 08:36 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Originally Posted by Longboard Mini
ALTA.
Longboard: Is that the way the M7 diverter came, or did you bend the verticals out like that? I wonder how the tops of the diverter seal against your bonnet and what happens to the all that air that goes on either side of the IC? I'm sure that most of the air going in the M7 DF scoop is going into your IC, but there seems to be air escaping around the sides, too.
cheers,
Old Nov 5, 2006 | 09:18 PM
fiveover's Avatar
fiveover
Have you considered the DDM Works?
Old Nov 6, 2006 | 04:45 PM
RoadFly's Avatar
RoadFly
Looks like the Alta is the one to go with --- I just realy like the looks of the K&N -- but I'd rather have the performance over the bling -- Thanks and keep the info rolling in.
Old Nov 6, 2006 | 05:15 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
When I got my MCS, I installed a K&N air intake and thought it was good... until I decided to sell it and get an Alta CAI...
The sound itself is amazing! A lot better than K&N. It's louder and a nicer.
The look can't ne compared! Alta is the only choice!
I recently added the top cover. It seems to make it sound a bit louder.
Old Nov 6, 2006 | 06:32 PM
Longboard Mini
cheers,
It doesn't look like that any more. It came that way. That pic was the morning after the install. They are now strait up. I also have the new foam pieces that Randy came up with. Four pieces in all. The whole thing is sealed tight.
Longboard
Old Nov 6, 2006 | 06:36 PM
Longboard Mini
I now have both. Yes, both. I replaced the foam filter with a K&N of the same length. I just feel the build quality of the K&N filter is better. It may not be, but I feel better about it.
Longboard
Old Nov 7, 2006 | 03:56 AM
Gr8Force's Avatar
Gr8Force
They're tough to compare because the bling is definitely with the K&N Typhoon. While it may not perform as well as the Alta it still performs quite well. The last added benefit is that is a lot quieter than the Alta. For some of us we don't want more noise. Go figure.
Old Nov 7, 2006 | 04:21 AM
jonnieoh's Avatar
jonnieoh
Yet another ALTA vote.
If you love the supercharger whine, and simply cannot get enough of it, there are really only two options: 1.) The ALTA, (easy install, less expensive), 2.) The m7 Air Gain System (or AGS), which is more expensive, and a much more involved installation, but offers a really wicked-loud whine.
But I have not regrets with my ALTA. I love it, and recommend it.
Old Nov 7, 2006 | 02:53 PM
Larry Clemens's Avatar
Larry Clemens
I have the Alta and love it however Alta has been promising CARB certification ever since I bought my 2005 MCS. IMO we should boycott the Alta CAI until they give us a CARB date and stick to it.
Old Nov 7, 2006 | 02:58 PM
cooper99's Avatar
cooper99
Alta all the way. No doubt about it.
Old Nov 7, 2006 | 04:16 PM
amorican's Avatar
amorican
CARB SHMARB, go with the Alta. The sound is great and the look is form follows function, which is how sports cars should be.
Old Nov 7, 2006 | 04:21 PM
sneakerspray's Avatar
sneakerspray
Just got an Alta on last Friday and I am very happy with it. I can't give you too much info on K&N.
What about CARB?
