Drivetrain Cleaning Unifilter?
Old Nov 1, 2006 | 09:48 AM
SORMINI's Avatar
SORMINI
Cleaning Unifilter?
what do I need to buy (and where) to clean my foam unifilter? All I have locally is kits to clean the k&n filters.
Old Nov 1, 2006 | 09:54 AM
mdsbrain's Avatar
mdsbrain
http://www.altaminiperformance.com/p...r/cleaner.html
$13.99
I just love fast answers :-)
Old Nov 1, 2006 | 09:55 AM
latte hiatus's Avatar
latte hiatus
You ned a UNI cleaner and UNI oil, available separately, but most often found in a package like this:
It seems that you prefer to purchase locally. None of my local automotive parts stores carried UNI products, so I checked around with some motorcycle gear shops, and they ALL had UNI service kits. HTH!
Old Nov 1, 2006 | 09:56 AM
latte hiatus
Always one step ahead of me!
mdsbrain's Avatar
mdsbrain
Just backing me up
Old Nov 1, 2006 | 09:58 AM
SORMINI's Avatar
SORMINI
Wow, thanks for the fast help!! (But you Don't have to step all over each other!!!LOL)
Old Nov 1, 2006 | 09:59 AM
mdsbrain's Avatar
mdsbrain
We're MINI owners, we sit @ work and wait for threads like this
Old Nov 1, 2006 | 10:00 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
You can also call your local motorcycle shop to see if they have the UNI Service kit also.
And don't let anyone tell you that the K&N kit will work as well.
Old Nov 1, 2006 | 10:08 AM
latte hiatus
We aim to please!
The oil that comes in the UNI service kit is a spray-on. It's difficult (though certainly still possible) to over-oil using it. Last time I cleaned my CAI filter, I thought I'd be different and use the oil that you pour into a pan, soak the foam filter, and wring out the excess. Turns out that the foam soaks up a heck of a lot more oil than I anticipated. For weeks, my filter dripped oil into the bottom intake enclosure and leaked through the engine bay and onto my driveway.
The moral is, don't try to be different.
SORMINI's Avatar
SORMINI
Thanks, I just called a couple and they have clening kits for foam filters, but they don't have specifically the UNI cleaning kit. Does it matter which brand?
Old Nov 1, 2006 | 10:11 AM
golden_child
I would personally buy the UNI brand. If I recall correctly that is who makes the Alta Foam Filter
Old Nov 1, 2006 | 10:13 AM
latte hiatus
Cleaning-wise, there's no reason why you can't use dish soap or a degreaser like Simple Green, per http://www.unifilter.com/maintenance.html .
On the other hand, when it comes to oiling, I've never come across another oil that has the tackiness of UNI oil - then again, I've never used another foam filter oil.
Perhaps give UNI a call and see if they can locate a dealer near you?
Old Nov 1, 2006 | 10:45 AM
Wesmonster's Avatar
Wesmonster
Ditto
Any good degreasing dish soap will make a good cleaner, but UNI's spray oil is the best.
Old Nov 1, 2006 | 11:11 AM
fiveover's Avatar
fiveover
Any motorcycle shop should have foam filter cleaner. I use UNI oil on my dirt bikes. I'd recommend the spray on because it's really easy of "over" oil a foam filter. The spray on is more expensive.
OutMotoring
Mar 3, 2017 06:29 AM
bahman
Feb 14, 2016 10:29 AM
simo711
Oct 8, 2015 07:07 PM
Sep 29, 2015 12:11 PM
EVMini
Sep 28, 2015 10:20 AM
