Drivetrain Flex joint importan on OBX header?
Old Oct 4, 2006 | 08:52 PM
MarioKart's Avatar
MarioKart
Vendor
I noticed some of the members with OBX headers have Zero flex joint. Doesn't it need it since the motor moves so much? Can you reuse the OEM one with the stock cat, is there room?
M
ario
Old Oct 4, 2006 | 09:03 PM
Ryephile's Avatar
Ryephile
It is a very good idea to use a flex joint! If you don't you risk cracking welds and breaking exhaust hangers.
Old Oct 4, 2006 | 11:29 PM
ThumperMCS's Avatar
ThumperMCS
The joint at the end of the OBX is ment to serve as a flex-joint. I dunno what the name for it is...it's like a curved-shaped ball joint thing. Haha great description. From what I've experienced and from what I've heard...it works just fine, as long as the bolts are tightened properly. I will say that it does not absorb vibration as well as the stock one though. Idle, with the a/c on...you get quite a bit of vibration through the header that is transfered back to the exhaust and through the rest of the car. It was much worse when I didn't have a cat...but its definitely liveable and shouldn't be an issue.
Old Oct 5, 2006 | 01:10 AM
Tit's Avatar
Tit
If you decide not to use the flex joint, you could get an engine damper to reduce engine movement....
Old Oct 5, 2006 | 02:10 AM
miniracer1's Avatar
miniracer1
okay but what exaclty is an engine damper
and where do u get it
and how do u install it
and how does it look like (picture pls)
cheers
Old Oct 5, 2006 | 05:39 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
It looks like this, or a variant of this:
you get it from a group buy here on NAM - the vendor is called Lord of the Flies.
You install it various ways which are outlined on the thread of same vendor above.
It reduces engine movement/rock by about 50%.
cheers,
Old Oct 5, 2006 | 05:58 AM
etalj's Avatar
etalj
yep. Well said. Mine does this as well.
Old Oct 8, 2006 | 04:10 AM
Tit's Avatar
Tit
Exactly what gandini said...
cheers
Old Oct 8, 2006 | 04:52 PM
BluMiniMe's Avatar
BluMiniMe
The ball joint replaces the flex pipe. Works terrific. Been running the obx for a year and still have the original doughnut gasket, and all is well.
Ball-n-socket on an exhaust is not a new idea. GP race bikes and the car racing world have been using this arrangement for years. Manufacturers even use it sometimes. Fear not.
Old Oct 9, 2006 | 06:18 AM
Bahamabart's Avatar
Bahamabart
I have the OBX w/ std donut connection and have not had any problems for the first 10,000 miles. The is an old design which has proven to work well over the years. I would just go with it and if it fails then consider other options - why spend upfront ?
vulkandino
Oct 31, 2015 08:29 PM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:13 PM
gknorr
Oct 1, 2015 09:20 AM
Sep 29, 2015 12:11 PM
