Drivetrain Alta CAI = Loss of torque?
Old Sep 19, 2006 | 08:53 AM
morespam's Avatar
morespam
Hi,
I recently (3 days ago) installed an Alta CAI on my 06 MCS and straight away it seemed to feel that the engine was not as "guttys" bellow 3k.
Unsure if this was just a bit of placebo I did a search around here and found some information about back pressure and the effects on low end torque with a “free-er” flowing engine (Intake, exhaust).
Has anyone else had this experience when installing a CAI or Exhaust?
P.S: I only have a CAI installed at the moment was looking at doing Cat Back, Pulley and ECU next.
Old Sep 19, 2006 | 01:49 PM
F15EWeapon's Avatar
F15EWeapon
Umm... nope... felt more power on my car.
Old Sep 19, 2006 | 01:53 PM
Dr Obnxs's Avatar
Dr Obnxs
Check the weatherstripping...
to make sure you're sealing with the hood, as hot air can negate the benefit of higher pressures at the SC inlet.
Matt
Old Sep 19, 2006 | 01:55 PM
justintime's Avatar
justintime
Originally Posted by morespam
Hi,
if you have the s, then a forced induction car has gain on both ends as far as loosing backpressure.
on NA cars decreasing backpressure ALOT will loose torque and you will gain top end.
When I ran from the headers/cat only I lost alot of tourque but gained alot of power in the higher rpms.
I dont think a cai would effect this that much though...
Old Sep 19, 2006 | 01:58 PM
obehave's Avatar
obehave
I noted the sane thing after insalling mine a few years ago.
Using the stock hose helped but I kept the Alta hose and worked with it.
As you nnoted, above 3K it gets better than stock was.
Old Apr 17, 2009 | 06:26 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Hi,
Mybe this is why the JCW Intake has a flap which doesnt open until you hit about 4K RPM's............just a thought.
Old Apr 17, 2009 | 07:13 PM
Dead Ringer's Avatar
Dead Ringer
Hi,
Do a search under my name in this section. I had dyno runs before & after (I did also install other tubes), but I saw gains.
Old Apr 17, 2009 | 07:19 PM
-=gRaY rAvEn=-
Moderator
What came first, the CAI or the Tune ?
And was your MINI's ECU Tweeked WITH the CAI for this Dyno run that you saw gains ?
Old Apr 18, 2009 | 08:32 AM
Dead Ringer
tune was first, this is the post where I installed the CAI "system" cai system here and yes it was still tuned with the ECU at this point.
Old Apr 18, 2009 | 04:36 PM
obehave's Avatar
obehave
So essentially you are talking about a totally different car, different engine, different forced induction system with a tune and you think your experience relates to the posters somehow?
It doesn't.
Old Apr 18, 2009 | 07:58 PM
Dead Ringer
It doesn't.
sorry for trying to help out with any information.. not to familiar with his car, I didnt know his engine was different. I will try to never help out again, since I seem to be so stupid, what was I thinking??
Old Apr 20, 2009 | 05:32 PM
MerchoMini's Avatar
MerchoMini
Reset the ECU and give the engine a day to get used to it. Sometimes the ECU senses something weird and cuts the gas some.
Old Apr 20, 2009 | 05:52 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Yeah you should see and feel nothing but gains across the board. For sure check all of the connections at the T/B etc. Hit me up if you still feel something is amiss! Always happy to help if I can! Thanks for the business!
patsum
26
May 29, 2021 06:29 PM
bahman
Nov 15, 2019 05:45 AM
Vaderm34
Sep 27, 2015 09:25 PM
Alanberto
Sep 16, 2015 07:25 AM
Emnotek
Sep 11, 2015 04:16 PM
