Drivetrain Show me your Iridiums
Old Sep 18, 2006 | 08:45 AM
  #126
nascar mini's Avatar
nascar mini
Ngk's Are Available A '' Advance Autoparts'',at Least In Nc. For $6.99 Ea.(bkr7e1x-11) One Step Colder Than Stock.
Old Sep 18, 2006 | 01:44 PM
  #127
F15EWeapon's Avatar
F15EWeapon
Originally Posted by obehave
Norm, I was there when Ben did the install. Impedance on the wires was higher than the Jackson wires he was taking off but consistent across wire lengths. ( I have forgotten the value)
Quality looked good too.
Long term who knows but for $24 they look like a good deal.
Yeah, what he said! Not sure whether to blame plugs or wires or both, but throttle response seemed more consistent. I was very very glad I did check my plugs at this time, as my #3 was backed off pretty bad, and was experiencing some degree of blow-by(if that's the right term..but the top of the plug has a nasty brown streak going from bottom to top). I'd say considering the troubles many have had, most recently by Coop d' etat, it's well worth checking the torque on your plugs every 5-7k, regardless of what plugs you're using. I wouldn't hesitate on the Kingsborne wires... they are the 8mm wires without the 1200 degree firebraiding. If you're having temps underhood like that anyhow, you have more serious problems. Perfect fit, darn good connectors... nice color, and the car does run fine on them.
Old Sep 18, 2006 | 02:02 PM
  #128
norm03s's Avatar
norm03s
Thanks for the input
I got antsy waiting for F15EWeapon to answer, one of my OEM wires (#3) has a bad coil connector. So I ordered and spent almost 3X as much with Out Motoring on a set of Kingsborne 8 mm Plug Wires with Firebraid @ $69.73 to my door. These wires appear to be put together pretty well and should be flexible enough not to have any severe bends.
Might as well get some of these too,
product code 6988, NGK BKR7EIX-11 .044" (1.1mm) $6.95
http://sparkplugs.com/ after I check at AutoZone/Pepboys.
Old Sep 18, 2006 | 04:53 PM
  #129
obehave's Avatar
obehave
Hope you have better luck with your autozone than I did with 3 different ones here.
You'd have thought I was talking about this
I happen to have a picture
Old Sep 18, 2006 | 04:59 PM
  #130
MSFITOY's Avatar
MSFITOY
Try http://www.jscspeed.com/mini/mini_base.html ...not as cheap as Autozone but you might ask them to match prices...
Old Sep 18, 2006 | 05:47 PM
  #131
obehave's Avatar
obehave
Thanks.
I have mine. I was just taking cheap shots
Old Sep 19, 2006 | 08:31 AM
  #132
MiniMacPR's Avatar
MiniMacPR
I just received these today from importpartsspec.com:
They look good, but they neither say kingsborne anywhere on the package nor do they say the diameter . I've never bought Kingsborne wires before so I don't have any reference for comparison.
What do you think?
Old Sep 19, 2006 | 01:04 PM
  #133
HHFD633's Avatar
HHFD633
has anyone tried bosch plat
+4's in a mini. had then in my turbo vw and they were great
Old Sep 19, 2006 | 01:33 PM
  #134
gizzer777's Avatar
gizzer777
I bought mine from Kingsbourn
I got my wires from Kingsbourn directly and the Packaging looked exactly like yours. While I was at it, I added the metal braiding ...for $12 why not.
They seem to be of good quality and have good connectors.
Kingsbourn also said they make both 7mm and 8mm wire sets....they did not say why one would be better than the other though.
I imagine the effect of plug wires would only be felt if one or more were to "go bad"...Just a guess
I just did it as a preventitive measure ...Been really hot here this summer, so when I did the plug change.,..I also did new wires.
What do you think?
Old Sep 19, 2006 | 01:47 PM
  #135
F15EWeapon's Avatar
F15EWeapon
For what it's worth..
I spoke directly with the guys at import parts spec... nice fella there that spoke with me at length about the mini parts market. He was full of questions about what sorts of things other people tend to carry. They tend to deal with more OEM type parts than anything, so I don't expect to see them as a vendor anytime soon. I asked very directly about the size and source of the kingborne wires. He assured me that they indeed come from there, and that they were the 8mm variety, not the 7mm.
Old Sep 19, 2006 | 01:51 PM
  #136
MiniMacPR's Avatar
MiniMacPR
Old Sep 19, 2006 | 02:00 PM
  #137
obehave's Avatar
obehave
Mine came with platinum +4s. NGK.
Old Sep 22, 2006 | 08:20 PM
  #138
kyriian's Avatar
kyriian
just finally had a chance to swap out the IK22s today, here's the pic after about 25,000 miles:
very uneven wear, worst wear is the 4th cylinder (left most one) (sorry for the crappy pic, still learning to use macro mode on my new camera), note that i installed Livewire wires and a coil pack around 5000 miles after the spark plugs gone in, and i didnt really feel misfire till really recently.... so there is defenitely some relationship between the IK22 and a more powerful coil pack
installed new NGK BKR7EIX today, and well, we'll see how things go
Old Sep 22, 2006 | 08:42 PM
  #139
obehave's Avatar
obehave
Your plugs have the same coffe stain 1 of mine did and I've seen others. Mine and 1 other I know for sure were from plugs not at their proper torque.
Do you know if this is true for yours as well?
Old Sep 22, 2006 | 10:30 PM
  #140
kyriian's Avatar
kyriian
hm... well i know for sure when i did the plugs i did the pulley, when the pulley guy threw them in he must've used some threadlock, so it did not lose torque at all through it's life and every now and then i check the torque its never off much...
so it might be something else
Old Sep 23, 2006 | 05:26 AM
  #141
norm03s's Avatar
norm03s
Advance Autoparts
NGK BKR7EIX-11 not carried in stock at my store, ordered, next day service $6.96 ea + tax 29.24
PEPBOYS, Not in stock, wouldn't place an order
AUTOZONE, to far away didn't check
Thanks guys for all your input + pictures and experiences with them.
IMHO I think these are the best bang for the buck + performance
Old Sep 23, 2006 | 08:21 PM
  #142
obehave's Avatar
obehave
Never heard of anyone ever using thread lock on spark plugs.
Not trying to be a putz but you contradict yourself in the part I placed in bold.
Old Sep 23, 2006 | 08:35 PM
  #143
kyriian's Avatar
kyriian
so im not an english major.....
point is, the thread lock (could be a thread sealant) kept the spark plug in the cylinder block.... not sure which one they used, with the NGK i threw in some medium strength ones, but i am not sure whether they will burn off in there...
Old Feb 16, 2008 | 10:18 AM
  #144
norm03s's Avatar
norm03s
Here we go again
How much does the dealer charge for the OEM plugs?
Old Aug 12, 2009 | 08:48 PM
  #145
rawcapture's Avatar
rawcapture
no pic and just chiming in but taking a guess without seeing the pic:
http://aftermarket.denso-europe.com/...170000011.aspx
sorry for the bump, been researching this myself...
Fordgt4
Oct 10, 2015 10:42 AM
Chefben63075
Oct 1, 2015 12:04 PM
moonloop
Sep 28, 2015 08:22 PM
EVMini
Sep 28, 2015 10:20 AM
dragonby
Sep 25, 2015 08:10 PM
