Drivetrain Alta Twurbo/Turbo questions here.....
Old Sep 5, 2006 | 12:53 AM
  #101
Eastsidemini's Avatar
Eastsidemini
good news
Oh, I forget to mention I re-installed everything the same way like the first time
Old Sep 5, 2006 | 01:05 AM
  #102
SSMini's Avatar
SSMini
Thats Great news... Let us know what Alta has to say. When all is well, get out there and give it hell and tell how she drives..
Old Sep 5, 2006 | 01:23 AM
  #103
Eastsidemini
Thx
SSmini, just make sure everything is free of oil and telflon all the pipe thread. I'm really glad I didn't just give up but to clean and re-installed it. I really can't explain why it happened the first time but I will get it all sort out I still have a lot to go a far as tuning/monitoring the a/f, boost control and may be hooking up a probe for EGT. I'm new to the turbo world and so much to learn but I love it I'll be glad to help when you start your installed
Old Sep 5, 2006 | 05:24 AM
  #104
SpiderX's Avatar
SpiderX
great
Originally Posted by Eastsidemini
I clean out the turbo houseing today and wipe down the entire houseing. Reinstalled the turbo and everything was fineno smokeand no glowing manifoldbut the overlfow tank is still a little hot even after bleeding The car is idleing fine and took it around the block and pull back into my garage. It feels great I will need to hook up the Apexi and the wideband now.
I will call Alta tomorrow and explain the whole experience to them.
Great.... glad to hear it
Old Sep 5, 2006 | 08:40 AM
  #105
Eastsidemini
good news
Thanks broI hope your dyno goes well and the M62 setup will be hugh/fantasic to the mini community.
Old Sep 5, 2006 | 09:50 AM
  #106
cliff@coasttocoastusa's Avatar
Former Sponsor
I am putting a little video together of the Alta kit in action. I will have it on NAM in a few days. A video is worth a thousand words..or something like that.
-Cliff
Old Sep 5, 2006 | 12:24 PM
  #107
SSMini's Avatar
SSMini
Eastsidemini, Glade to hear all is working out. Is the overflow still running a bit hot? or is that also fixed. I was getting a little nervous there for awhile. Are you going to run stock boost at first? If so, let us know how the MINI pulls with stock boost. I'll be running stock boost till I can save up some funds to up the boost. How long was the install? No counting taking off the turbo and reinstalling it. Were the directions good or were there some parts that were a little hard to understand? Just want to be prepared before I jump into this.
Cliff, The video of the Alta kit in action would be great!!
Old Sep 5, 2006 | 01:32 PM
  #108
Gizzy's Avatar
Gizzy
Thats great news man, lets get a full mod list . +1 for the vid
Old Sep 6, 2006 | 07:43 AM
  #109
Trickle X's Avatar
Trickle X
Great to hear Andrew...did u disassemble the compressor side of the turbo when u had it off??? I am thinking that is where your issue was, but nontheless....great to hear..
As for the overflow....yup it will be hot...as your dumping the super hot coolant from the turbo into it! I have the same issue. Its only time before that plastic tank fails....
Old Sep 6, 2006 | 08:39 AM
  #110
Soul Coughing's Avatar
Soul Coughing
you need to get that stainless steel overflow tank that one of the vendor sells!
Old Sep 6, 2006 | 09:10 AM
  #111
Former Sponsor
A combination of water+ redlines water wetter is said to reduce coolant temps up to 20 degrees.
Old Sep 6, 2006 | 09:24 AM
  #112
Eastsidemini
Thx
Yes, I did Tricklex and foung just a small trace of engine oil I've been using Royal Puple and it has a slice tint of color I agreed as for the hot water from the turbo going into the overflow tank, I am also using a bottle of water wetter too and still There's gotta be a sololution to this and I'll look in to it I'm hooking up the Apexi SAFC and the AEM wideband today I will post pics only if I knew how Help please
Old Sep 6, 2006 | 09:33 AM
  #113
Eastsidemini
Stainless or Alum Mania has the Alum one and I can do a group buy for those who might be interested?
Old Sep 6, 2006 | 11:52 AM
  #114
Johan's Avatar
Johan
Glad to hear you got everything going good now! Did alta ever get a hold of you? Or did you call them this week and get any feedback from them?? -- Johan
Old Sep 6, 2006 | 12:08 PM
  #115
Eastsidemini
Thanks bro, yes Jeff from Alta contacted me and the heated overflow tank is normal when the car is not moving at all. The exhaust manifold and the turbo housing will glow a little
Old Sep 6, 2006 | 12:57 PM
  #116
SSMini's Avatar
SSMini
I would be interested in a group buy on the aluminum overflow tank. There is another brand that is half the price. Its not as pretty as the other, but will do the job. Its the second from the bottom.
http://www.cantonracingproducts.com/...tanks.html#top
Eastsidemini, Did you use your cat, or did you go with a o2 sim?
Old Sep 7, 2006 | 09:43 AM
  #117
Eastsidemini
COOL tank
Originally Posted by SSMini
I would be interested in a group buy on the aluminum overflow tank. There is another brand that is half the price. Its not are pretty as the other, but will do the job. Its the second from the bottom.
I will contact them and establish an account. Those are COOL tanksCOOL.
I will be installing the 02 sim today.
Make sure nothing touches the turbo after installed. Especially any plastic or rubber products. I would recommend using stainless steel braided hose for the water lines and apply the fire shield over it. IT GETS HOT
Old Sep 7, 2006 | 11:00 AM
  #118
Soul Coughing
grrr i want to install my stuff so badly!!! im so jealous of you!
whats the damage on the overflow tank?
Old Sep 8, 2006 | 12:36 AM
  #119
Eastsidemini
There's no damage at all. It's just a matter of time for the plastic parts to break cause of the heat. I'm wrapping the turbo and the DP tomorrow to shade some of the heat I'm using DEI product for the wrapping.
Old Sep 8, 2006 | 02:38 AM
  #120
SpiderX's Avatar
SpiderX
how is the power output?
Old Sep 8, 2006 | 09:10 AM
  #121
Eastsidemini
I will hook up the Apexi SAFC this weekend to tune the A/F and hopfully I can get to the dyno soon for the final tune The car feel strong already without any tuning but I haven't gun it yet I will test it this afternoon.
Old Sep 8, 2006 | 09:21 AM
  #122
Soul Coughing
when i said damage, i meant the price of the new one?
Old Sep 8, 2006 | 10:59 AM
  #123
Trickle X's Avatar
Trickle X
Andrew.....make sure not to wrap the Header.....
Old Sep 8, 2006 | 11:26 AM
  #124
Eastsidemini
heat wrap
Thanks you Cole. No, I wasn't planning on wrapping the header. I will wrap only the down pipe and the turbo exhaust side
How do you use the SS strap to tie the wrap? Anyone?
Old Sep 8, 2006 | 02:49 PM
  #125
Soul Coughing
Just took some pics...
... of my yet to be installed turbo. Its on my photos.. how do i put it on the page?
