Drivetrain Anyone have a Sound clip of Header + Oneball
Old Jun 13, 2006 | 04:46 AM
etalj's Avatar
etalj
I was wondering if anyone has recorded, or if you have this combo, could be kind enough to record, a clip of a one-balled MCS exhaust with any header? I'd like to hear what it sounds like. Please mention which header it is that you've installed as well.
Thanks in advance,
Elie
Old Jun 13, 2006 | 11:48 AM
bmweater's Avatar
bmweater
I second this request!!
Old Jun 13, 2006 | 11:54 AM
myzamboni's Avatar
myzamboni
A good subset request would be the sound from inside the car ( I have the one-ball but no way to record the sound and I noticed a bigger change from inside the car than from the outside . . . a good change).
Old Jun 13, 2006 | 09:13 PM
ThumperMCS's Avatar
ThumperMCS
I should be able to get a sound clip for you guys within the next couple weeks. I should have my OBX header with my One-Ball, sometime in the coming week and will try to get some recordings for everyone!
Old Jun 13, 2006 | 10:51 PM
The MINITOR's Avatar
The MINITOR
If I had to start over on mods, I would definately do the OBX header and oneball. You can do both for less than the cost of some exhaust systems, cant beat that. I've never heard it with the one ball though (I only have the OBX), so I am eager to hear the clip as well.
Old Jun 14, 2006 | 04:54 AM
etalj's Avatar
etalj
awesome! that's the particular one i really wanted to hear, just wanted to compare it with a few others. I have a oneball, and probably will end up with the OBX header.
Please do high revving, idle, and cruising, both inside and out, back seat up and down if you can. Just mix it up a bit
Old Jun 14, 2006 | 08:16 AM
Bahamabart's Avatar
Bahamabart
While I have gone beyond the 1-ball plus OBX header - this is in my opinion THE way to go!
Old Jun 14, 2006 | 08:17 AM
Bahamabart's Avatar
Bahamabart
For those that now the 1-ball sound - adding the obx header just deepens the sound a tad.
Old Jun 14, 2006 | 09:03 AM
etalj's Avatar
etalj
does it make it louder?
Old Jun 14, 2006 | 09:17 AM
Bahamabart's Avatar
Bahamabart
I didn't think it was louder just deeper. What this should tell you is that whether it's actually deeper or louder it is just a little bit.
The car with th e1-ball and header remains stealthy which I think is a good thing at a light next to a honda .
Old Jun 14, 2006 | 09:57 AM
etalj's Avatar
etalj
well that's what i love about my car...looks bone stock, and has suprised a hell of a lot of ppl.
i like the idea of more power and better breathing while remaining stealthy. right up my street
Old Jun 14, 2006 | 10:01 AM
Motor On's Avatar
Motor On
Could you do a before and after clip so we can hear the change?
Old Jun 14, 2006 | 10:34 PM
ThumperMCS's Avatar
ThumperMCS
Yeah, I will do before and after clips as well as a variety of clips inside and out with the new set up. I should tell you that I will be running the header catless, which should make it significantly louder than one with a cat. I will also be dynoing afterward, so look forward to those as well!
Old Jun 15, 2006 | 07:39 AM
S Curvz's Avatar
S Curvz
I amsume you have already been on a dyno.. What are you numbers thus far?
Old Jun 15, 2006 | 10:27 AM
sprp85's Avatar
sprp85
Thumbs up !
Old Jun 15, 2006 | 05:42 PM
ThumperMCS's Avatar
ThumperMCS
Yeah, they were pretty strong runs for the minimal mods that I have, so I'm excited to see what the header will do for me.
15% Pulley, CAI, and One-Ball gave me 192.5 hp at the wheels. Here's the graph if you wanted to look at it:
Old Jun 15, 2006 | 10:28 PM
MSFIT's Avatar
MSFIT
^^ wednesday motor
Old Jun 16, 2006 | 05:46 AM
SpiderX's Avatar
SpiderX
Originally Posted by MSFIT
^^ wednesday motor
That's what I was thinking.....that is an amazing result for those few mods......either that or a very high correction factor....are you sure that is WHP not crank estimate? I'm just jealous....but I admit it ....nice numbers....
Old Jun 16, 2006 | 07:27 AM
ThumperMCS's Avatar
ThumperMCS
Yup, that's WHP. The guys that own the shop said its by far the strongest MINI they've ever seen (with the given mods). Also, their dyno, a DynoDynamics dyno, is known to be one of the most conservative dyno's available and is notorious for lower, more accurate numbers...so knowing that is even more amazing!
Old Jun 16, 2006 | 07:28 AM
S Curvz's Avatar
S Curvz
Thats not bad. Is one of those graphs from just the one ball? Just curious because of the hand written stuff on the side.
Old Jun 16, 2006 | 12:42 PM
ThumperMCS's Avatar
ThumperMCS
The lowest run is with the 15%
Old Jun 16, 2006 | 12:43 PM
S Curvz's Avatar
S Curvz
Then intake then one ball?
Old Jun 16, 2006 | 12:45 PM
ThumperMCS's Avatar
ThumperMCS
-The lowest run is with the 15% pulley.
-The middle run is the pulley along with the CAI+One-Ball. This was a hot run, taken after 3 or 4 previous pulls.
-The top run is pulley w/ CAI+One Ball except I had misted water over the intercooler prior to it. Eliminating heat soak makes a HUGE difference in the MINI.
Old Jun 16, 2006 | 12:47 PM
S Curvz's Avatar
S Curvz
Alright, cool. Yeah, I am sure sitting on a dyno doesnt help either.
Thanks for explaining things.
tr3y003
33
Jun 5, 2020 05:00 AM
atenzany62
Aug 26, 2015 09:26 AM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
