Drivetrain PLEASE HELP!17% and 19% pulley Belt
Old Feb 24, 2006 | 12:16 PM
Detonics's Avatar
Detonics
Guys,
I need some advices here. A friend of mine just got the 17% and 19% pulley which come with 25-060547 and 25-060535 napa belt. He is going to installed the pulley in 6 hours time. The prob here is, which belt is for which pulley?
From my understanding, use the 535 for the 19% and 547 for 17%. I think he is fitting the 17% pulley first. Shoud he uses the 535 or the 547 for the 17% pulley? Please advice..
I need fast info before the installation.. Thanks guys!
Old Feb 24, 2006 | 12:20 PM
ted leist's Avatar
ted leist
If one belt is obviously shorter then the other, the shorter belt
goes with the 19% pulley.
Originally Posted by Detonics
Guys,
Old Feb 24, 2006 | 12:24 PM
gmcdonnell's Avatar
gmcdonnell
The 547 is the longer of the two (55 1/4 inches).
The 535 is 54 1/8 inches long.
So the 19% pully should use the 535 and the 17% should use the 547.
http://www.napabeltshose.com/downloa...IDE_FORWEB.pdf
/gary
Old Feb 24, 2006 | 12:25 PM
Detonics's Avatar
Detonics
Yes, but are those the right belt for the pulleys? I'm just afraid if the shortest belt is too short or long for the 19% pulley and the other belt is too long for the 17% pulley. 535 for 17 or 19 pulley?
Old Feb 24, 2006 | 12:29 PM
Detonics's Avatar
Detonics
gmc,
You posted first before me. Thanks for your input. I can see the difference between those two belts in terms of length but I'm just afraid it those are not the right belt for both pulley. Read somewhere that 539 is the best for 19% pulley.not sure about 17%. Can we use 535 belt with 17% pulley, too tight? too loose?
Old Feb 24, 2006 | 12:30 PM
ted leist's Avatar
ted leist
http://www.eurostyleseast.com/item.a...-ENGINE&Cc=MCS
Old Feb 24, 2006 | 12:34 PM
gmcdonnell's Avatar
gmcdonnell
I just checked the belt I'm using on my 17% pulley. It's a 535. I was told by Alta that it would work fine with a 19% as well. I think the 547 is actually a replacement for a stock MCS.
Old Feb 24, 2006 | 12:44 PM
Detonics's Avatar
Detonics
now im confused, some said that the stock belt can be used with 15% and 17%, just like the link Ted posted.
GMC, any problem so far? Belt snapped or slipped?
Old Feb 24, 2006 | 12:56 PM
ted leist's Avatar
ted leist
I believe that the link that I posted said that the
stock belt or 539 can be used for the 15% pulley.
I believe that the stock belt is shorter then the 539.
17% - 539
19% - 535
Old Feb 24, 2006 | 01:00 PM
gmcdonnell's Avatar
gmcdonnell
The stock belt probably can be used with a 17% in most cases. There's some amount of adjustability in the tensioner for obvious reasons.
My belt is in great shape - about 8000 miles on it and the 17% pulley, no slipping or cracking or any visible wear. I don't track / race / autox but I do enjoy driving spiritedly on the street.
The thing with the belt length is that you don't want the tensioner to end up all the way tight or all the way loose if you can avoid it. There are probably people that have heated opinions on where the tensioner should be when a new belt is properly installed - as for me I just wanted it to have at least half it's overall range of travel remaining when the belt was new and with the 535 I think I got about 2/3rds of the travel remaining, which I was happy with.
/gary
Old Feb 24, 2006 | 01:05 PM
gmcdonnell's Avatar
gmcdonnell
17% - 539
19% - 535
The stock belt is definitely longer than the one that should be used with a 19% pulley.
Also, there are people who have used the (shorter than stock) 535 belt with a 15% pulley (Andy of Ross-Tech is one according to an old post of his I read) with good results.
There are probably a few engines that require a longer or shorter belt than the vast majority just due to variations in locations of the alternator / AC compressor / supercharger.
Old Feb 24, 2006 | 04:28 PM
Detonics's Avatar
Detonics
GMC,
Are you saying that he should do some adjustments at the tensioner with the 17% pulley, not just plug and play? IF yes, how much?
Im using 15% and it was just plug and play, I mean I didnt adjust anything.
Old Feb 24, 2006 | 04:54 PM
norm03s's Avatar
norm03s
Detonics, this info was searched and found in 20 sec. in Beneath The Bonnet
https://www.northamericanmotoring.co...gatorback+belt
Old Feb 25, 2006 | 10:51 PM
Detonics's Avatar
Detonics
Thanks guys, really appreciate your help. Fitted the 17% pulley with 535 belt....
elverado
Jan 18, 2022 02:51 AM
BernieCoop
Sep 10, 2021 03:15 AM
daviday
Sep 25, 2015 01:31 AM
makg
Sep 24, 2015 11:10 AM
Emnotek
Sep 11, 2015 04:16 PM
