Drivetrain Torque specs - flywheel , pressure plate, clutch swap
Hi,
I'm going to change out these components and I was wondering.. won't I need to torque things up after the installation to spec
I don't have time to buy the Mini manual to check that out. I'm hoping that someone can help me out. I'm entering TOTB http://www.totb.co.uk/home/ (Ten of The Best) on Thursday and Friday and I don't have time to spare.
If you can help me, I will be greatful
Pressure plate to flywheel = 23NM (17ft-lb) M8
Pressure plate to flywheel = 28NM (21ft-lb) M9
Flywheel to crank 90NM (66ft-lb)
Transmission to engine 85NM (63ft-lb)
Good Luck
Peter
Team M7
562-608-8123
Good Luck
Peter
Team M7
562-608-8123
I've run into a problem.
When I disengage the clutch to the farthest position its still touching the flywheel. Its very difficult to change gears... when its cold its fine but once hot isn't. If I take my foot of the clutch pedal slightly it come off the flywheel.. I can't drag or do a road course like this
Is there a way to ajust the clutch travel? What is up with this?
It was a new replacement flywheel with new bolts.
Use caution when approaching the limit!
andrewjg1994
Jan 29, 2021 07:45 PM
Sep 17, 2015 09:27 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
