Drivetrain DIY Cold Air Intake
Old Jan 23, 2006 | 09:07 AM
sanddan's Avatar
sanddan
DIY Cold Air Intake
This is a good DIY project if you have some basic tools and want to give it a go. I did this several years ago after reading a similar how-to that Dan Pilo wrote.
I started by mocking up the heatshield using thin cardboard. I used modeling clay to determine the height that the heatshield needed to be.
I made a second cardboard mockup to check the fit of the final design. Once I was happy with the fit, I made a master template to make it easier to transfer the outline.
I used a jigsaw with a metal cutting blade to cut the basic shape. I then drilled the mounting holes and the hole for the intake tube as it's a lot easier to do this on flat material.
The next step is to bend the flat sheet to it's final shape. I used 2 pieces of angle iron and a shop vise to make the bends.
This shows the final shape.
Here's a group photo.
The hole for the intake tube will vary depending on the size tube and filter you use. The stock rubber tube will accept a 2 5/8" OD tube. If you are using a Alta silicone tube you can use a 2 3/4" OD tube. I used a 2 3/4" OD by 2 1/2" ID aluminum tube with one end machined down to 2 5/8" to maximize airflow.
Here is a drawing of the flat pattern for the heatshield.
This was a fun project to do. My costs were as follows.
Aluminum sheetmetal $0
Aluminum tubing (2') $40
Rubber seal (20') $20
K&N filter $60
Total cost $120
Saved $80 over typical intake. I sold several heatshields to cover the material costs so it really only cost me some of my time.
Old Jan 23, 2006 | 10:03 AM
Bahamabart's Avatar
Bahamabart
NICE
Nothing like rolling up one's sleeves. I especially like the made a few extras and re-cooped my costs .
Thanks for sharing
Old Jan 23, 2006 | 12:49 PM
sanddan's Avatar
sanddan
Thanks Bahamabart.
Old Aug 8, 2009 | 03:45 AM
PowerPig's Avatar
PowerPig
GREAT!!! Hate 'off the shelf' stuff (except of hard-core tech stuff)! Maust have, must make!
Old Aug 9, 2009 | 06:34 PM
FL_blue_MINI's Avatar
FL_blue_MINI
What software did you use to make the drawing? Is there any way you could let us download a PDF or similar?
Old Aug 9, 2009 | 07:13 PM
everytimeidie027's Avatar
everytimeidie027
looks like it's made in Auto CAD to me
Old Aug 9, 2009 | 07:14 PM
everytimeidie027
oh by the way, that's an amazing job!
Old Aug 9, 2009 | 09:00 PM
PowerPig's Avatar
PowerPig
Hi,
I just 'threw it' in the Corel and it is more than enougth to have a accurate drawing.
Old Aug 10, 2009 | 12:47 AM
PowerPig's Avatar
PowerPig
Originally Posted by sanddan
Hi sanddan,
Any chance to tell us the exact position and diameter of the hole? Everything is so precise so...
TNXaLOT!
chrisx18240
26
Mar 16, 2022 09:56 AM
W0TM8
Dec 19, 2019 07:50 AM
theblackfalcon
Aug 26, 2015 09:18 AM
rentedblackbird
Aug 24, 2015 10:22 AM
joelcseymour
Aug 7, 2015 12:43 PM
