Drivetrain How to tell the difference between a JCW supercharger and a regular S supercharger?
Old Jan 2, 2006 | 12:49 PM
warchieft2k's Avatar
warchieft2k
Maybe there is a code or a number?
Old Jan 2, 2006 | 12:55 PM
chows4us's Avatar
chows4us
11657526657 normal S after 7/04
11650300354 JCW
Old Jan 2, 2006 | 01:15 PM
10851CS's Avatar
10851CS
Hey chows4us,
That took six minutes!! What up with being so slow?
Talk about fast
Earl
Old Jan 2, 2006 | 01:17 PM
chows4us's Avatar
chows4us
Originally Posted by 10851CS
Hey chows4us,
I know, I should have let him look it up but I got that page of parts bookmarked its so valuable! Besides helping the community is a good thing
Old Jan 2, 2006 | 03:41 PM
minimotoman's Avatar
minimotoman
what do they run
are they running the m62 instead of the m45? what is the difference in superchargers.
Old Jan 2, 2006 | 03:56 PM
Dr Obnxs's Avatar
Dr Obnxs
Mostly pully diameter.
It's still the M45. Someone care to comment on the coatings in the current S vs the JCW? I have and 02 S. It didn't have any coatings on the rotors.
Matt
Old Jan 2, 2006 | 04:41 PM
k-huevo's Avatar
k-huevo
The only difference between the JCW and the current build SC is the diameter of the pulley. The earlier model SC had a coating on the lobes also, just a different composition lacking at least the ceramic component.
Old Jan 2, 2006 | 05:03 PM
ScuderiaMini's Avatar
ScuderiaMini
in other words there is no dif. in between two SC except the pulley. How about a JCW pulley? Would it be available through a Mini dealer and would they install it and cover it under warranty? It sounds like a dummy question but i am on fact finding questions. I will sum up my thoughts at the end.
Old Jan 2, 2006 | 05:35 PM
k-huevo's Avatar
k-huevo
The pulley alone is not available from BMW/MINI. The JCW supercharger as well as the standard SC is warranted in the event of a defect if purchased from a MINI parts department but installation, removal, or incidental damage is not covered.
The JCW and stock pulleys are interference fit. If you were to remove a JCW or stock pulley there is high risk of deformation even with the robust P&D style puller and defiantly with the newer low profile style pullers. A re-fit would not be recommended.
Old Jan 2, 2006 | 08:21 PM
J Propane's Avatar
J Propane
Scuderiamini, you've already summed up your thoughts:
https://www.northamericanmotoring.co...ad.php?t=45668
oh cool, an original JCW pulley, make sure you get it installed at your dealer...
Short memory.
JP
Old Jan 2, 2006 | 09:29 PM
ScuderiaMini
whatever
Old Jan 3, 2006 | 09:25 AM
warchieft2k
11650300354 JCW
thanks for the info!... could you send me the link to tha page with the part numbers?
thanks again
Old Jan 3, 2006 | 11:18 AM
CDMINI's Avatar
CDMINI
I was HOPING to here that flames shot out the exhaust or that the driver and passengers get hopelessly pinned to the back of the seat after a great launch. I guess with FWD, wheelies from the front wheel are physically impossible...
Old Jan 3, 2006 | 12:38 PM
MINIAC's Avatar
MINIAC
Originally Posted by warchieft2k
... link to the page with the part numbers?
http://www.realoem.com/bmw/partgrp.d...21&hg=11&fg=50
http://www.realoem.com/bmw/partgrp.d...21&hg=11&fg=95
Old Jan 3, 2006 | 01:29 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
FURIOSO stated that he counted the rotations of the pulley and counted the rotations of the water pump input for both the stock and JCW blower, and they were different. Anyone have a JCW and a non-JCW sitting on a bench?
Old Jan 3, 2006 | 01:36 PM
Dr Obnxs's Avatar
Dr Obnxs
I can check a stock one later today.
I'll post what I find...
Matt
Old Jan 3, 2006 | 02:55 PM
warchieft2k
thanks for all the response...
so lets say i was to find a JCW car crashed... and i take the supercharger from it.... would i get any HP increase with just that?
how about if i throw in my 19% on the JCW supercharger? will that be a safe thing to do? and would it work better than a regular S with the 19%? (i already have the JCW injectros....)
thanks
Old Jan 3, 2006 | 03:34 PM
Dr Obnxs's Avatar
Dr Obnxs
Eaton's web site..
or one of the quotes from the Eaton team claim that the abradable coating is good for a few % increased thermal efficiency due to less leakage between the rotors and the case and the rotor.
For each % in in efficiency, that should be good for 1-2 HP
Matt
The short answer is yes.
Also, grab the injectors (380 cc cap, as opposed to the 340cc from the S), and if it's not bent, the exhaust.
Old Jan 3, 2006 | 04:15 PM
warchieft2k
Matt
thanks, i already got the 380cc injectors... and well the exhaust is gone.. it was a rear crash...
Old Jan 3, 2006 | 04:53 PM
Dr Obnxs's Avatar
Dr Obnxs
I forgot!
You;ve got to get the badges! And any works logo items (like floormats), those are good for a few HP too!
Matt
Old Jan 3, 2006 | 05:40 PM
warchieft2k
Matt
im sure they are specially the floormats ... but the guy has sold a lot of the parts... im lucky i got the SC...
Old Jan 3, 2006 | 11:02 PM
Dr Obnxs's Avatar
Dr Obnxs
Bonehead move on my part.
I forgot to look at the waterpump drive ratio this evening. The little girl is asleep after I woke her up by being loud, and it took over a half hour to get her back down. Half to wait till tomorrow. Sorry folks...
Matt
Old Jan 4, 2006 | 06:09 AM
Wagnbat's Avatar
Wagnbat
Nothing is impossible.
Old Jan 4, 2006 | 07:55 PM
Dr Obnxs's Avatar
Dr Obnxs
Checked the stock SC...
1.75 rotations of the input shaft for a single rotation of the waterpump shaft.
Hope this helps.
Matt
Old Jan 4, 2006 | 08:03 PM
ChiliCooperS's Avatar
ChiliCooperS
You have to have known someone would say this:
One's CRAPPY and the other isn't.
