Drivetrain Dinan upgrades
Old Jan 28, 2008 | 04:28 AM
  #576
qweewq12's Avatar
qweewq12
Dinan will take care of it. Mini of Hawaii had an issue with the fuel pump when they installed my Fuel Upgrade Kit... The car would make a loud pumping noise on start-up, after they installed it... Dinan ended up sending out a new FPR and FP, after they tested it
Old Jan 28, 2008 | 06:44 PM
  #577
BLKDINAN's Avatar
BLKDINAN
I added my DINAN points to 21 out of a possible 26. Lacking the Brembo brakes - 3 pts - in favour of the JCW and the stage 6 with cam shaft - 2 points - I thought that it was time to turn to thoughts of safety. As you increase your points you might think about the same. I recently purchased a Stable Energies Harness Guide Bar and 2 Schroth harnesses. I have found that the grip between the leather seats and me is just not there. MINI has great cornering ability but, I think, very poor seating, unless specialty seats are added. I did not want to chuck lapis blue leather seats so next week the bar and harnesses are being added. I'll take some photos once they are installed and post. Has anyone else done this?
Old Feb 11, 2008 | 10:33 PM
  #578
joe_r's Avatar
joe_r
Ok,
My Install date is set for Feb 28th with NW Mini here in Washington state.I recieved 50% off retail for my Dinan boost upgrade system as long as they install it.
Stage5 ecu $100.00
Install of Stage5 ecu $55.00
Boost upgrade system $549.00
Install of Boost upgrade system $660.00
$1364.00 plus tax & I am good to go.
I also have awaiting for me is,
Dinan floor mats.
Dinan air filter.
Dinan spark plug wires.
Dinan strut brace.
"The DINAN badge,woohoo"
The count down is on!!!
joe r
Old Feb 12, 2008 | 04:17 AM
  #579
mbcoops's Avatar
mbcoops
I'm having the boost upgrade installed 2/18.
mb
edit - and my 3rd Dinan exhaust (rusty tips on the first two).
Old Feb 12, 2008 | 05:26 AM
  #580
Marwan's Avatar
Marwan
Hi there. I would love to ask anyone representing Dinan here:
I'm in the process of changing my stock pulley with a smaller one. Based on my mods listed below, would you recommend the perfect solution from Dinan?
Old Feb 12, 2008 | 06:08 AM
  #581
mbcoops's Avatar
mbcoops
I don't know if you're asking for an official Dinan installer, but I don't think anymore exist here, so I'll take a stab at your inquiry (BTW, they're very helpful on the phone):
If you get the Dinan pulley with the accompanying kit, you get a fuel pressure regulator to give more fuel, like your injectors do. They also basically mandate that you get the Dinan stage 5 software to help deal with the boost and fuel increase. So it seems like you'd be overlapping there.
I don't know how your injectors would affect the system, so you might just consider getting any pulley since your JCW ECU is already apparently meant to take the pulley into account.
I think you could save a lot of money that you've already spent (ie, don't spend it twice), by just getting a pulley and calling it a day.
mb
Old Feb 12, 2008 | 11:01 AM
  #582
charger's Avatar
charger
Originally Posted by 1FSTMINI
Im a Dinan Rep for the NY area.
What is it your needing to know.
If your still a member or is anybody else from Dinan able to look up a VIN on a used Mini that is claimed to have the S2 package. TL18684 is the last 7 digits.
Old Feb 12, 2008 | 01:00 PM
  #583
joe_r's Avatar
joe_r
Call Dinan they will let you know.
joe r
Old Feb 12, 2008 | 08:40 PM
  #584
1FSTMINI's Avatar
1FSTMINI
what he said....call dinan and ask for Eric Baitman. tell him barry said Hi.
Old Feb 18, 2008 | 04:12 PM
  #585
mbcoops's Avatar
mbcoops
Boost kit installed today:
Very smooth, better part-throttle power, much better full throttle power, and quicker pedal feel. As everyone says - this is how the car should come from the factory.
mb
Old Feb 18, 2008 | 04:29 PM
  #586
qweewq12's Avatar
qweewq12
mb
Plan on getting the Dinan Throttle Body?
Old Feb 18, 2008 | 06:08 PM
  #587
Scavenger's Avatar
Scavenger
mb
All I got to say is
Old Feb 18, 2008 | 06:47 PM
  #588
mbcoops's Avatar
mbcoops
The top end is what surprised me the most. I expected a gain, but where the car used to sort of die, now it pulls harder.
This system isn't earth-shattering, but it is satisfying.
mb
Old Feb 18, 2008 | 06:50 PM
  #589
joe_r's Avatar
joe_r
I can not wait.
Next week & SilverBullet is going in for his stage5 & boost upgrade,WOOHOO!
joe r
Old Feb 18, 2008 | 08:46 PM
  #590
charger's Avatar
charger
My wife had a guy in a Mustang pull up at a red light and laugh at her and rev up his engine. She gave him a taste of what a Dinan car can do! Only had the car for two days and she is allready racing.. I knew I should have gotten her just a normal MCS.
Back when I had a Callaway Camaro - she comes home and says "you need a bigger speedometer".
Old Feb 19, 2008 | 12:31 AM
  #591
SharoSC02's Avatar
SharoSC02
Originally Posted by mholtsberg
Has anyone here done the DINAN performance on their MINI S..airbox, software, pulley etc. ?
I had a shop in town program one of their latest software that was recommended with bigger valve head upgrade. But in process of having it re-tuned by Jan, hopefully soon.
Old Feb 19, 2008 | 07:35 AM
  #592
joe_r's Avatar
joe_r
That is one great thing I hope for the Pacific NW to happen is Jan comes up to visit.
joe r
Old Feb 25, 2008 | 09:01 AM
  #593
sBox's Avatar
sBox
Anyone have problems with their ECU updates causing the car to run excessively rich? I've heard the '06 MCS is programmed to run a little richer to get more burble, but the car nearly backfires at every stop sign now. I've got a Dinan cowl, Stage 3 software, a 15% pulley and the JCW exhaust which shouldn't be a problem.
Old Feb 25, 2008 | 09:20 AM
  #594
charger's Avatar
charger
My dinan stage 5 does rumble when off the throttle and slowing down. I guess I could hook up my laptop and see what the A/F ratio is.
On a long trip from Pa down some big hills the car did throw a lean bank code. But I did put in a bottle of fuel system cleaner and the fuel station only had e10 gas. Since then no other A/F problems.
Old Feb 25, 2008 | 01:01 PM
  #595
mbcoops's Avatar
mbcoops
Stage 5 software is recommended for the 15% pulley - that could be your problem.
mb
Edit - my S1 + the boost upgrade and ECU still pops like crazy on deceleration. I like it.
Old Feb 25, 2008 | 01:02 PM
  #596
joe_r's Avatar
joe_r
I bet its do to the 15% pulley.Stage3 is not ment for a pulley.
To use a 15% pulley you need,
MINI > Cooper S Coupe & Convertible (2002-2007) > Engine Tuning > Fuel Injection Upgrade Kit (for use with 14-16 psi supercharger pulley)
DC783-0032
MINI > Cooper S Coupe & Convertible (2002-2007) > Engine Tuning > Engine Software for Fuel Injection Upgrade Kit)
D903-16R S1-NP
& you should be safe & I bet the backfire will stop.
joe r
  #597
mbcoops's Avatar
mbcoops
Sorry - I missed this post before.
I don't plan on getting the throttle body. I'm going to spend that money on track days.
mb
Old Feb 25, 2008 | 01:03 PM
  #598
joe_r's Avatar
joe_r
mb
But to run stage5 software he still needs the boost upgrade kit.The thing is he is not running the Dinan pulley.
joe r
Old Feb 25, 2008 | 01:07 PM
  #599
1FSTMINI's Avatar
1FSTMINI
I have a 19% pulley with a dinan stage 5 flash and have no problems. Im also using 440inj which i know arent dialed in to good.
Old Feb 25, 2008 | 01:10 PM
  #600
joe_r's Avatar
joe_r
Are you getting any sort of backfires?
joe r
