Drivetrain grounding wires install?
Old Nov 4, 2005 | 07:08 PM
electricblue's Avatar
electricblue
hi i brought a grounding wires kit that comes with 4 cables but it has a generic install info. Do anybody know how and were install this cables .thank's for all the info and if anybody have photo it will be appreciate
Old Nov 5, 2005 | 04:59 AM
62Lincoln's Avatar
62Lincoln
PM me your email address, and I can send you some really good instructions with photos.
Old Nov 5, 2005 | 11:56 AM
mdsbrain's Avatar
mdsbrain
Do these even help a MINI? I thought if you look @ the MINI engine it has several grounds already.
Old Nov 5, 2005 | 11:58 AM
Battle Cattle's Avatar
Battle Cattle
anything connected to the (-) terminal will be a ground...unscrew one of those bolts... and put your ground on it!
-Josh
Old Nov 5, 2005 | 07:50 PM
GrilleGuy's Avatar
GrilleGuy
I bought a set and then looked into the engine bay and saw a massive wire grounding the engine to the frame so I gave the cables to a Miata owner. I was hoping to get better FM reception
Old Nov 6, 2005 | 03:43 AM
daleCarlsbad's Avatar
daleCarlsbad
Not to jack the thread...but hey GrillGuy..... painting all the "stuff" behind the grill in flat black will really make a difference.
Old Nov 7, 2005 | 04:12 AM
electricblue
jrgonzalezpr@yahoo.com
Old Nov 7, 2005 | 05:30 AM
62Lincoln's Avatar
62Lincoln
Email sent.
Old Nov 10, 2005 | 09:09 PM
Darin45's Avatar
Darin45
Let me know too...I have the same kit as you, remember?
darin
darin1274@***.net
Originally Posted by electricblue
Old Nov 11, 2005 | 03:10 AM
62Lincoln's Avatar
62Lincoln
Email sent.
Old Dec 18, 2005 | 10:12 AM
SSMini's Avatar
SSMini
Grounding kit
62Lincoln, If you don't mind, can you send me a few pics of the install?
Thanks...
WoodyRVT1000@aol.com
Old Dec 18, 2005 | 10:19 AM
Dr Obnxs's Avatar
Dr Obnxs
Have any of you that have installed these noticed any difference?
Or better yet, measured one? The Mini is pretty well grounded. There are lots of ground meccas in the harness, bolted to the frame. Also, the previosly mentioned ground strap from the engine to the frame over on the drivers side.... It doesn't look like the Mini has bad grounding design to start.
Matt
adrchn
Aug 13, 2019 02:11 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
squawSkiBum
Oct 2, 2015 09:21 AM
Super Coop
Aug 17, 2015 05:09 PM
