Drivetrain recommend a belt with 15% pulley?
Old Sep 29, 2005 | 09:44 AM
SB's Avatar
SB
I've searched but searching this forum for pulley doesn't work quite well. Almost every thread has the word pulley in it.
I'm about to get a 15% pulley and notice Helix sells a belt for the stock and 15% pulleys. Webb Motorsports doesn't mention the belt when talking about the pulley. I'm just curious if a short belt should be installed when using the 15% pulley. Or if the standard belt works fine with the difference in pulley size compared to factory. A friend said something about a different size belt and this was the first time I heard so I thought I would ask here.
Old Sep 29, 2005 | 09:53 AM
mdsbrain's Avatar
mdsbrain
Most people tell me they use the stock size belt.
Old Sep 29, 2005 | 11:27 AM
Bahamabart's Avatar
Bahamabart
The stock belt works just fine on the 15% pulley.
Consider when you do the pulley, you put on a new belt - If for no other reason than you can inspect it to see if there are any new pulley issues developing. Also how many miles you have on the old belt would be of influence. New pulley why not a new belt - Its a conservative approach for what $20 ?
Bart
Old Sep 29, 2005 | 06:29 PM
SB's Avatar
SB
Thanks.
This will be my second MINI, first with pulley, so the belt will have less than 1,500 miles on it by the time I get the pulley installed.
Old Oct 1, 2005 | 06:32 AM
Bahamabart's Avatar
Bahamabart
Originally Posted by SB
Thanks.
Then pulley away!
Old Oct 1, 2005 | 06:37 AM
Tit's Avatar
Tit
I've just picked up a Dayco Poly-Rib 6PK1365 - 538K6 on the reccomendation from another mate who fitted it....haven't fitted it yet...
if you've got it all off...why not replace the belt?
Old Oct 1, 2005 | 07:30 AM
jbsf3's Avatar
jbsf3
I'm running a stock belt with an ALTA 15% and 0% lightweight crank pulley- no issues...
Old Oct 1, 2005 | 04:36 PM
pa.now's Avatar
pa.now
I'm running a JCW belt...
Works fine!
Old Oct 1, 2005 | 07:54 PM
gjpundsack's Avatar
gjpundsack
Does anyone have experience with Goodyear's "Gatorback" belt products for this application? Part #? Cost?
Old Oct 1, 2005 | 08:11 PM
kaelaria's Avatar
kaelaria
Gatorbacks (as a type) work fine, grip very well - and whine more than stock. And no there isn't a *need* to change for a 15%, however anything more does need a smaller belt.
Old Oct 1, 2005 | 11:09 PM
tennis_man's Avatar
tennis_man
For a 15% pulley you can use the stock belt. But if you are going to change it, the belt from your local Napa Auto Parts store part number 060539 is the correct size.
Old Oct 4, 2005 | 05:00 AM
minis2005DS's Avatar
minis2005DS
Hi everyone:
After a track day, my pulley belt looks like is near to break too... Would you tell me which kind of belt should I buy? Like which one is the strongest or most reliable one?
Thanks a lot
Happy motoring
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
The_Kid
Nov 3, 2016 06:30 PM
larryd96
11
Sep 8, 2015 05:01 AM
M7Speed
Sep 3, 2015 07:48 AM
