Drivetrain warranty and mods
Old Jan 27, 2003 | 09:31 PM
Bk_MCS's Avatar
Bk_MCS
If this has already been touched on sorry.
I will be getting a MCS soon (hopefully sooner) and am planning on the magnaflow exhaust, madness intake, and madness swaybar. What I want to know is if any of these will void the warranty, because I work at burger king and am going to FSU in the fall so I wont be able to afford maintenance. I was also wondering about the pulley mod having read Randy's quickie, will it effect the warranty. Thanks in advance.
Old Jan 27, 2003 | 09:42 PM
Thechandler81's Avatar
Thechandler81
If i remember correctly - all of your wanted mods are fine with warranty, except the pulley, which is a royal pain in the a$$ to change from the looks of it, and yes, the pulley will most likely void the warranty out. If you say for instance blow an engine and try to take it in with that aftermarket pulley on it, i would think the service department would turn you away, but everything else you listed is relatively safe.
Old Jan 27, 2003 | 09:45 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Hey bk!
Welcome to MCO!
The pulley will most certainly void the engine part of the warranty. Things like windows, sunroofs, brakes, etc. would not be affected (is that the right use of affect - or is it effect ??? - that might start an off-topic post though).
Hope that helps. Let me know if you have any other questions. You should be able to find information on this topic using the search function - the small yellow one, not the big one.
Randy
Old Jan 27, 2003 | 09:47 PM
Thechandler81
randy-
yes that is the proper use of affect.
Old Jan 28, 2003 | 02:59 AM
BoyRacer's Avatar
BoyRacer
What exactly does a rear sway bar do??? I have noticed that quite a lot of people have had this modified.
Old Jan 28, 2003 | 03:16 AM
TwOMINIs's Avatar
TwOMINIs
It keep the rear of the vehicle from "swaying"...lol....Check out the write up by RandyBMC "track day info" in the performance Modification section..." A picture is worth a thousand words"......
Old Jan 28, 2003 | 04:37 AM
Bk_MCS's Avatar
Bk_MCS
Ha ha ha! sometimes I get confused as to witch I should be using. Thanks guys.
Old Jan 29, 2003 | 06:00 AM
chrisneal's Avatar
chrisneal
Thereby avoiding unwanted attention from larger SUVs, Azteks, etc.
Sorry...
Old Jan 29, 2003 | 06:03 AM
BoyRacer's Avatar
BoyRacer
Thanks for answering my question. I better get me one of them!
bADbOYbECK
41
Oct 16, 2015 12:39 PM
The Rossness
Sep 17, 2015 03:06 PM
Empura
Cooper (non S)
Sep 16, 2015 07:35 PM
Colt45Magnus
Sep 14, 2015 03:12 AM
larryd96
11
Sep 8, 2015 05:01 AM
