Drivetrain 19% + Larger injectors + MTH = All Smiles
Old Jun 25, 2005 | 10:46 AM
Morales's Avatar
Morales
I've been running 17% with MTH since last September.
Went to Helix last week to get the 19% and Injectors and I loaded the MTH when Eric was done.
This combination is fantastic. The car pulls hard. Acceleration is effortless. I did some 70mph-90mph bursts in 6th on the way home and the power is there. What would normally have best been done by downshifting to 5th is no longer necessary.
No official dyno numbers, but the infamous butt-dyno is pleased. Go out and get this done!
Old Jun 25, 2005 | 01:05 PM
bouray's Avatar
bouray
Welcome to what others have previously referred to as the dark side. Congrad's, you now have THE hot setup for street driving, IMHO.
Old Jun 26, 2005 | 11:54 PM
matma92ser's Avatar
matma92ser
Hot setup for the track too?
Old Jun 27, 2005 | 07:10 AM
bouray's Avatar
bouray
Not necessarily. Folks with well tuned 15%-17% have done real well on various types of courses. Seems like where the 19% accels in adding more grunt down low in the rpm band, this is not necessarily everyone's cup of tea. Depends on what type of event one is running.
Old Jun 27, 2005 | 07:26 AM
Pat_Cooper's Avatar
Pat_Cooper
I know this will start a arguement but.... IMO GIAC would of been better for that setup
Old Jun 27, 2005 | 07:55 AM
ditc's Avatar
ditc
... But GIAC would have cost 4x more ! Is it 4x better?
Old Jun 27, 2005 | 08:17 AM
kaelaria's Avatar
kaelaria
Exactly - sure you get a few more HP with the other choices - but MTH is a LOT cheaper!
Old Jun 27, 2005 | 09:48 AM
Morales's Avatar
Morales
I like the ability to switch files without needing to ship out my ECU or drive down to Helix. I agree the GIAC may be slightly better, but the price point and flexibility of MTH is what sold me.
Old Jun 27, 2005 | 10:41 AM
Dr Obnxs's Avatar
Dr Obnxs
Can we all just agree...
that none of the "as bought" maps are perfect? And that for every tuning method out there there are good and bad points? There are lots of ways to skin the tuning cat, why complain that some of us choose a different knife?
We've heard all the names, Giac, Unichip, Shark, MTH blah blah blah blah blah.... And we all know that some have really nice features (tune timing and fuel, or easy re-maps whatever) and some don't (Apexi doesn't do timing, MTH can have some longggg waits for maps, Shark is a factory return.....)
But they all make SOME improvement, more if your car hits the mark that they are tuned for, but none are perfect....
Me, I'm looking for the easiest way to get control of my own tuning. That means I have to get access to wideband data, data logging, and remapping. I can spend a bit on the wideband (PLX R500 is in the lead, covers data logging too!), and then MTH gets me a bunch of programming other than the maps, but I have to use e-mail and patience, and I'm not too good at patience, or I have to go with Apexi, and give up timing tuning, but get control of my own fuel mapping. Then no more dyno needed! I can use an electronic one (the car is a mass too, so you can use your own 0-60 times or whatever.....) But I fully realize that both of these paths aren't perfect, and that if any of us were worth our salt, we'd just go buy a race computer and throw out the stock wiring harness!
I'm just looking to get control over my own tunes....
Matt
Old Jun 27, 2005 | 03:31 PM
Pat_Cooper's Avatar
Pat_Cooper
Actually. After you are in GIAC's system...you can goto any GIAC dealer and get a reflash....or upgrade.
GIAC = used by all high end tuners... if cost is a major factor then MTH should serve its purpose. But isn't the MTH not a full flash? Like the GIAC is a full flash that means they actually worked out fuel maps and etc... isn't the MTH one of those.. "Lets trick the ECU" type of deals? I could be totally wrong though...
Old Jun 27, 2005 | 04:33 PM
Dr Obnxs's Avatar
Dr Obnxs
Huh????
I'm sure all the rest of the electronic engine control supplieres would be happy to know that they'd screwed up!
Want a kick in the pants? Check this out.....
http://www.electromotive-inc.com/products/tec3.html
Oh, I forgot. It's not a GIAC
Matt
Old Jun 27, 2005 | 04:56 PM
kaelaria's Avatar
kaelaria
THe biggest issue I have with GIAC (if this wasn't an issue I would have done it over MTH even though it's 3x as much) is that it doesn't temper the traction control system. This is a major issue with a modded car and the stock TCS. I hated having to turn it off everytime I drove the car, pretty much every take off would trip it. MTH fixed all that, GIAC would not have. The driveability of the MTH is what sells it, not the HP gains like the other solutions.
Old Jun 27, 2005 | 08:48 PM
Dr Obnxs's Avatar
Dr Obnxs
I want it all!
Point is, with proper programming one should be able to get the HP the others do as well. Get into the maps and you can make the computer do whatever you want it to! So if a data logger and some other stuff can help Franz dial in the tune, then we should be able to get the best of both worlds!
For those that are into real inexpesive ideas.....
look here for a $25 logger. I"m ordering one right now....
Matt
mni928
Oct 11, 2015 07:37 PM
randeez
Oct 5, 2015 09:23 AM
Snotrocket555
Oct 1, 2015 08:59 AM
eliseo1981
Sep 30, 2015 07:57 PM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
