Drivetrain Weight of seats?
Old Jan 14, 2003 | 10:06 AM
2minis's Avatar
2minis
Anyone know the driver seat weight?
Anyone installed aftermarket seats?
Warranty issues with removal of stock seats?
Thanks.
Old Jan 14, 2003 | 10:11 AM
chrisneal's Avatar
chrisneal
What about the airbags?!
Old Jan 14, 2003 | 09:33 PM
ficcion's Avatar
ficcion
I am waiting on my Sparco Torino...should be here soon :smile:
Side airbags gone...little red light on. That will be the end result.
Old Jan 14, 2003 | 09:41 PM
Casey's Avatar
Casey
please weigh your old seats when you get the new ones...would be inteested in seeing the weight numbers.
Old Jan 14, 2003 | 09:50 PM
itsthedirtybird's Avatar
itsthedirtybird
can you access the rear seats with the sparco seats?
Old Jan 14, 2003 | 10:06 PM
Casey's Avatar
Casey
depends which seats you get...the torino and milanos you can...the others are fixed back like the Rev. These can be put on sliders but I can't see access to the back being easy if sitll impossible. Some of the sliders i've seen have titls on them so you can actually lean the whole seat up thus making it somewhat accessible form the passenger seat. I plan on removing the rear seats anyway so doesn't matter for me and I hope to put in Sparco Rev Seats
Old Jan 15, 2003 | 01:49 PM
DK23's Avatar
DK23
GRM mag states the sport seats are 47 lbs. each, the standard cooper seats 45 lbs. each.
Old Jan 16, 2003 | 06:05 AM
2minis's Avatar
2minis
Thanks for that info dk23.
ficcion...any warranty issues with removal of stock seats??
You'll have to post pics of the installed seat.
Old Jan 16, 2003 | 06:21 AM
ficcion's Avatar
ficcion
I don't think there are any warrannty issues considering stock seatbelts and everything still functions correctly. I will be using a clip in harness for autocross and the stock set up for normal driving.
The only thing I have heard is if you have the dealer turn off your airbag light you have to sign a waiver holding them faultless if airbags fail.
This is all stuff I have just "heard" through other posts so I cannot verify the veracity of it all.
Logically, it seems the seat is a separate "entity" of it's own which doesn't effect much around it so if my tranny breaks they can't say my new seat caused it :smile:
Old Jan 16, 2003 | 07:24 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Use caution with fixed back seats, Casey. They may pose a safety issue in the event of a rollover if you don't a a roll bar.
You see it all the time - cars with these seats without rollover protection, and hopefully will never be an issue. Just research it before you make the decision.
Randy
Old Jan 16, 2003 | 07:51 AM
Casey's Avatar
Casey
Yup - if i get the Revs there will be a cage and harnesses. I agree fixed back without some sort of protection via a cage is stupid. Now where I am stuck is how big of a cage do i need. Is a rear cage enough or not...I wouldn't mind putting in a rear cage - would look cool as well - the rear seats are useless anyway...now a full cage I feel is a bit too much for road use....so depending if a rear cage is enough i will get the revs.
Old Jan 16, 2003 | 07:59 AM
2minis's Avatar
2minis
>>Randy
Randy,
You must of missed the pics of the rolled Mini. Perhaps it doesn't need a
rollbar????
Old Jan 16, 2003 | 08:32 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Casey,
You'd be fine with a rear roll bar, as long as it isn't just cosmetic. It needs to have sufficient wall thickness and diameter to actually afoord you some protection. The drawback is the additional weight.
Randy
Old Jan 16, 2003 | 08:39 AM
2minis's Avatar
2minis
Sweet looking roll cage but not in a MINI.
Old Jan 16, 2003 | 08:49 AM
sirron's Avatar
sirron
Just make sure your own seat is not too heavy!!!!!
Old Jan 16, 2003 | 08:51 AM
2minis's Avatar
2minis
bADbOYbECK
41
Oct 16, 2015 12:39 PM
RocketUSA
Sep 15, 2015 07:45 AM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
SeattleF56
Sep 3, 2015 03:01 PM
