Drivetrain Which intercooler????
Old May 30, 2005 | 09:57 PM
spillman's Avatar
spillman
I am trying to figure out what type of intercooler I should pick up next. I am going to be doing a lot of drag racing and autocrossing with maybe one or two track days a year.
I want something that won't heat soak while doing a burnout before a run down the track. But I also want something that will stay cool an entire autocross run.
Price isn't a variable here, I just want to get a few opinions on what would work the best for what I'm doing.
Ryan
Old May 30, 2005 | 10:14 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Have you talked to Randy Webb at Webbmotorsports.com?
Options include-
Front mounted large air to air intercooler- up to 17 HP gain and expensive!
Air to air top mount intercoolers-
Alta costs less and gains about 6 HP
GRS costs a little more and gains up to about 10 HP
Forge- Randy didn't like the design of the ends but testing is needed.
Water cooled IC
Several sources- WMS might be worth a look for efficient cooling when used for autocross, drag racing and street use.
Maybe combine a top mounted IC with the M7 bonnet scoop!
One note- I saw a posted picture of an upgraded IC behind the stock bonnet scoop and the air flow didn't look optimal- it was kinda blocked so I would ask about that.
Old May 30, 2005 | 10:22 PM
TonyB's Avatar
TonyB
That is actually the Forge one:
https://www.northamericanmotoring.co...ad.php?t=43528
Old May 31, 2005 | 12:11 AM
mininutz's Avatar
mininutz
Although the GRS seems like a wonderful unit according to the venerable Mr. Webb, the Alta top-mount still has the squirting feature (which as far as I know is lacking with the GRS), which might make a difference if things get hot. I'm trying to decide between these two myself, and the lower priced Alta with shpritzer is quite attractive...
Old May 31, 2005 | 03:58 PM
'*Ace*''s Avatar
'*Ace*'
I hear that!
Old May 31, 2005 | 09:00 PM
d6-mcs's Avatar
d6-mcs
i just got the new MINI Madness water to air intercooler.....one word ROCKS!!! never had anything give me a jump since my 19% pulley..
BATES
Old Jun 1, 2005 | 03:29 AM
jlm's Avatar
jlm
here is a liquid cooled version:
Old Jun 1, 2005 | 04:10 AM
SpiderX's Avatar
SpiderX
I see your listed as a mfg. what are you rproducts?
Old Jun 1, 2005 | 04:31 AM
mpwald05's Avatar
mpwald05
Originally Posted by TonyB
I noticed the same thing, as far as size goes. I was considering Forge myself and adding the M7 scoop.
The more research the better on this mod.
IQRaceworks
53
Jun 28, 2024 07:29 AM
gar56
Nov 15, 2016 06:41 AM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
