Drivetrain what is a wideband O2 sensor and why do I need one?
Old Apr 10, 2005 | 08:38 PM
SpiderX's Avatar
SpiderX
Well?
Old Apr 10, 2005 | 09:33 PM
Dr Obnxs's Avatar
Dr Obnxs
It really lets you see what's going on.
The O2 senosr in most cars is a narrow band. So it has a flat output to a certain A/F ration, then has it's output go quickly to the other end of saturation, where it's flat as well. So the narrow really only sends "rich" or "lean" but isn't too good about telling how rich or how lean.
A wideband covers a much larger range of A/F ratios, so you can know how rich or how lean. Search on google to look for more information. The manufacturers web-sites will explain it all.
Matt
Old Apr 10, 2005 | 09:53 PM
M7's Avatar
M7
Hi SpiderX....
M7 are a reseller of PLX Devices A/F ratio equipment at very affordable prices.
Check these links out:
http://www.m7tuning.com/products/plx.htm
www.plxdevices.com
If I can be to any help, feel free to call me.
peter
team M7
562-608-8123
Old Apr 10, 2005 | 10:09 PM
hornguys's Avatar
hornguys
If you're still a bit concerned about A/F ratio (as I always seem to be), especially as it gets hotter and your recent custom tune no longer quite applies, the only way to check it is with a wide-band a/f meter.
Or go back to Hesco...
Old Apr 11, 2005 | 04:26 AM
MiniPilo's Avatar
MiniPilo
Spider,
The Wideband A/F Ratio is a great tuning tool, but requires another package to allow you to tune it like and Apexi S-AFC or other similar device. You can then log or display the Fuel mixture that will allow you to make changes in the ammount of fuel that you are delivering to your engine, thus optimizing performance. We are testing out the new Standalone Gauge unit by Inovative motorsports which is really one of the coolest ones that I have seen.
They alo have some tuning videos on their site. They discuss their LM-1 Sensor system, but the new Standalone unit is what I will be using.
http://www.innovatemotorsports.com/resources/lm101.php
Once done testing, I will have these units available for sale.
Attached Thumbnails what is a wideband O2 sensor and why do I need one?-im-3767.jpg
Old Apr 11, 2005 | 04:37 AM
SpiderX's Avatar
SpiderX
I went to the links and read. It looks like a diagosis tool, I am thinking it has finer resolution and with that info you can make more power.
Would you permanently install this in the car and feed the wideband info to the computer and would it then be able to make more power (perhaps oversimplification) Is the digital readout/controller device something you keep in the car to make on the fly adjustments as necessary?
Lastly, keeping the car out of over lean conditions is paramount to keeping your engine (I used to fly) so this, I think, is not to be taken lightly.
Old Apr 11, 2005 | 04:46 AM
MiniPilo's Avatar
MiniPilo
Originally Posted by SpiderX
Thanks to all
I just had my car custom uned on a dyno and it is running much stronger. Is this a diagnosis product or can you make more power with the sensor and some sort of head end?
If you run an optimum fuel curve, you can make more power.
Old Apr 11, 2005 | 05:51 AM
macncheese's Avatar
macncheese
Spidey,
Its definately not something to be taken lightly and therefor not needed/recommended for the average consumer as the average consumer doesnt do their own tuning. The resolution that a wideband provides is useful only to your engine tuner. If you're interested in monitoring A/F as a safety precaution, I'd recommened a DEWES DEVICE. It allows you to monitor narrow band A/F in a much simpler, easier to read manner. It only works at WOT, but thats most likely all you're concerned about anyway.
Cheese
shorenetworks
Nov 4, 2019 06:18 PM
CRC
Dec 26, 2015 11:30 AM
sempaipaul
Sep 18, 2015 03:05 PM
Doc Pain
Sep 15, 2015 11:31 PM
Sep 14, 2015 12:48 PM
