Drivetrain horsepower
Old Feb 22, 2005 | 04:17 PM
samjm560@yahoo.com's Avatar
samjm560@yahoo.com
horsepower
what is most horsepwer anybody has gotten out of their mini?
Old Feb 22, 2005 | 04:21 PM
TonyB's Avatar
TonyB
I can't be certain, but the ones with the Honda Vtechs are approaching 200 bhp!!!
http://www.webbmotorsports.com/forum...topic.php?t=37
EDIT: I'm guessing that you mean the new MINI... As far as I know, that claim goes to our El :smile: . The last dyno had his twincharged MCS putting down 281 whp. Welcome to NAM, BTW.
Old Feb 22, 2005 | 04:28 PM
samjm560@yahoo.com
horsepower
do u kno how to get the mini past 200 bhp without spending 5k
Brian's Avatar
Brian
if im not mistaken, i think the turbo kit from spi put you around 260-270. running at... what is it.. about 20 psi or so
Old Feb 22, 2005 | 04:30 PM
Brian's Avatar
Brian
pulley, intake, exhaust, search....
Old Feb 22, 2005 | 04:34 PM
TonyB's Avatar
TonyB
To get 200 bhp, or about 178 whp... There are several approaches I guess... One of the most popular is to go with an aftermkt:
intake
exhaust
pulley (SC reduction)
ECU
That should net you 3 grand extra as well
Old Feb 22, 2005 | 04:39 PM
samjm560@yahoo.com
horsepower
does anybody suggest any particular manufactures
Old Feb 22, 2005 | 04:40 PM
ditc's Avatar
ditc
I like search, search and search
Old Feb 22, 2005 | 04:42 PM
TonyB's Avatar
TonyB
You will get plenty of input on that one!
I have used Peter of M7 and Randy of Webb Motorosports. Exceptional products and support...
I've also heard wonderful things of Eric at Helix! As someone said earlier, spend some time with the search button, and read, read, read...
Old Feb 22, 2005 | 05:41 PM
jlm's Avatar
jlm
i'm getting over 250
Old Feb 22, 2005 | 05:49 PM
SpiderX's Avatar
SpiderX
250......I love the sound of that..........what are your mods?
Old Feb 22, 2005 | 06:01 PM
El Diablito Rojo-N20Mini's Avatar
not the dreaded BHP
Old Feb 22, 2005 | 06:29 PM
hornguys's Avatar
hornguys
Wow, 250...
Just had mine dyno'd here. 196 at the front wheels. Thought I was doing good. :(
Frankly, mine is already faster than my ability. Anything more is jes' braggin' rights, as we say down here in GA...
Old Feb 22, 2005 | 06:33 PM
SpiderX's Avatar
SpiderX
Originally Posted by hornguys
Wow, 250...
Hi Jim,
I have added the head/cam and I'm adding a few other little things next week. Where did you do your dyno runs? Congrats on a great number.
Old Feb 22, 2005 | 07:30 PM
D1JL's Avatar
D1JL
Wow, 250...
As you made it a point to mention at the front wheels, what did you get at the rear ones?
"Slightly modified" is all you need.
Dave
Old Feb 22, 2005 | 08:15 PM
hornguys's Avatar
hornguys
I was concerned about having an adequate safe operating area with a/f ratio. I knew the car was pretty strong (well, maybe not up against the 250 hp big dogs), so I wasn't too concerned about the hp. Although it's nice to see in print.
I went to Balanced Performance, the guys that Grassroots Motorsports recommend. They're not too far away, in Sugar Hill, GA. 678-546-6133. Sharp outfit.
I am still slightly concerned about the a/f and engine longevity. Been thinking about getting the GIAC/Helix injectors for peace of mind with my 19% pulley.
I have the older Webb/Powerchip and the M7 injectors/throttle body. I'd give up the Webb ecu and sell the M7 injectors if I went the GIAC/Helix route. I know it sounds crazy around this bunch, but I'd give up 10 hp or so to have a nice fat a/f ratio...
Unfortunately, I can't get the 19% GIAC if I'm using revalved injectors.
Old Feb 22, 2005 | 08:20 PM
So let's see the dyno sheet and a/f graph...
Old Feb 22, 2005 | 08:29 PM
hornguys's Avatar
hornguys
OK, here's the dyno sheet. Dyno was Dynojet.
Interestingly, he preferred to run a powerful fan directly into the intake scoop (and of course, across the bonnet), from about two feet in front of the car. Apparently, he didn't think the "bonnet-open" test reflected real world conditions.
Old Feb 23, 2005 | 04:45 AM
SpiderX's Avatar
SpiderX
I like that torque curve. 19% really makes a difference (duh)
Old Feb 23, 2005 | 06:59 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Great looking curve!
Old Feb 23, 2005 | 07:11 AM
hornguys's Avatar
hornguys
Andy, what do you think of the a/f ratio, particularly between 2.5k and 3.5k and again at 5.2k to 5.8k?
The guys at Balanced Perfortmance thought that'd be ok for a naturally aspirated engine, but not so good, at least for the long term, for forced induction. What do you think?
Old Feb 23, 2005 | 07:13 AM
a/f is within safe tolerances
it probably didn't have enough air being blown on the car causing it to get hot...(which they will) and cause your a/f to be leaner than normal. We witnessed this when breaking in my new pistons.
Old Feb 23, 2005 | 11:14 AM
05JCWS's Avatar
05JCWS
Jim,
I had mine done at Balanced Motorsports. I was the first Mini that they had done. We found the best numbers and temperature across the intercooler with the hood closed. With the hood open, the overall underhood tempertures were better, but the intercooler ran hotter, because the air was just running over the top of the intercooler and not forced through it. Since the hood is closed and there are myriad air entry points into the hood, fans will not be enough to really cool the engine bay. Since the numbers seemed better keeping the intercooler cooler than to keep the engine bay cooler, that is what we went with. Sorry I don't have the numbers anymore on what the temps were, I have since gotten rid of that Mini and have gotten a new one. I need to go over to Balanced to get my new JCW dynoed. In fact, I may just do that in the next week or so.
Old Feb 23, 2005 | 11:38 AM
62Lincoln's Avatar
62Lincoln
Jim, congrats on the great numbers. Thanks also for pointing out a dyno shop that I can use for my MINI (I'm not too far from Sugar Hill). I'm curious to see what the prevailing opinion will be about your a/f numbers. I always thought staying below 12.0 would be safest from a detonation point of view. Reading between the lines, sounds like you have the same thoughts. Tell us more!
Old Feb 23, 2005 | 11:55 AM
KevinR's Avatar
KevinR
What does Balanced charge for dyno runs? I'm down in Columbus, GA, but Sugar Hill isn't THAT far away. My car is completely stock but it might be nice to get a baseline for it prior to making any changes.
