Drivetrain fuel questions... and ideas...
Old Jan 28, 2005 | 08:43 AM
warchieft2k's Avatar
warchieft2k
hello everyone, i got a 03 mcs with a 19% pulley and as most of us know if you can get a little more fuel we can get more HP.... working along with a ECU of course.
now i have a few ideas and i wonder if they would work....
1. use the fuel pump, fuel preasure regulator and injectors from a BMW m3.
2. use the fuel pump, fuel preasure regulator from a bmw m3 with the m7 440cc injectors.
*for both of them the right ECU and new fuel lines will be needed as well*
and here are my questions
1. what are the specs on the fuel pump ton the cooper s and is it enough for the bigger injectors?
2. would the m3 part work on the mini?
3. is there any fuel upgrades for sale for the mini?
now feel free to give me some ideas! im all confused with this fuel upgrade deal....
thanks
Carlos
Old Jan 28, 2005 | 08:50 AM
orthomini's Avatar
orthomini
injectors
if youre looking for bigger injectors m7 sells them. i also hear that helix will have injectors combined with the giac flash for a 19% pulley, youd have to call helix for that info.
Old Jan 28, 2005 | 09:03 AM
10851CS's Avatar
10851CS
Back in 1968 I had a Dodge Dart with a 383 ci and one of the things that helped the engine from starving from a lack of fuel was we added a 12 volt elect. fuel pump inline to help the fuel move better from the tank to the engine. .
Something cheap to try, just pick up a 12 volt pump, cut the fuel line, add in the pump, (also we put in an on/off switch) and give it a go.
Earl
Old Jan 28, 2005 | 09:04 AM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
JLM is currently running the 440cc injectors on his rig with the Stock Fuel pump and regulator. He has no problems. Also he is running a SAFC2 controler to help dial in the injectors better. I think but not positive he is running an AFTERMARKET ECU flash as well. The AMD one click but i could wrong on that. I do know he has had alot of engine work done via THEOLDONES. So far there has been no trouble keeping enough fuel going to the injectors.
Old Jan 28, 2005 | 04:50 PM
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
Carlos,
Read Greatgro's post on the 19% with GIAC software and injectors. That's the way I'm going to go.
Old Jan 28, 2005 | 04:57 PM
TonyB's Avatar
TonyB
I've heard that the stock fuel pump is more than adequate for our hp needs - well beyond 300 hp, if I recall correctly...
Old Jan 28, 2005 | 05:07 PM
jlm's Avatar
jlm
those lies about me are true.
Roland, in the UK, claims he is getting 273hp without the need for an ECU tune or larger injectors, but his data is skimpy and his findings contradict several others. buyer beware.
I think the big hp guys (300 whp range)...red devil, Helix and Hubie have had enough gas with the stock pump, fuel ines and regulator at stock 51psi.
this weekend there is a dyno party in SoCal and the expectation is >300whp. let's be sure to ask about the A/F at 6800 rpm, eh?
Old Jan 28, 2005 | 05:11 PM
greatgro's Avatar
greatgro
Originally Posted by Veni_Vidi_Vici
Carlos,
It's true. Why go through all that trouble - GIAC software and injectors are available. You too can fly off the line.
Old Jan 28, 2005 | 10:14 PM
MiniPilo's Avatar
MiniPilo
If things go as we plan.... the 300 hp barrier will go down....
Old Jan 29, 2005 | 05:47 AM
jlm's Avatar
jlm
once again, the "we" but now I know who else he has included. spill the beans, pilo!
Old Jan 29, 2005 | 06:30 AM
El Diablito Rojo-N20Mini's Avatar
if we tell ya.... we have to kill ya.....
btw... .NEED MORE COWBELL!!!!!
Old Feb 1, 2005 | 09:23 AM
warchieft2k
nice! i wanna see pics of this dynos as well!
so you guys think the helix13 computer and injector kit will do?
well i think im goin to go for that. when i get it on i will be posting dyno information!
thanks!
IQRaceworks
53
Jun 28, 2024 07:29 AM
OutMotoring
Mar 3, 2017 06:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
HK_MCS
R58 :: Coupé Talk (2012+)
Oct 4, 2015 08:03 PM
dutchhome
Sep 30, 2015 07:17 AM
