Drivetrain Want More Down Low Power
Old Jan 13, 2005 | 06:02 PM
JCampos's Avatar
JCampos
Want More Down Low Power - 19%?
So, my quest for more horsepower has brought me short of a cylinder head, cam, and intake manifold by the end of this month. Now, I know that a head and cam will give me a good jump in power, but I am looking for more down low grunt.
This has brought me to something I originally did not consider.... the 19% pulley People who have it swear by it, and Randy Webb swears against it So, what am I to do?! Here is my thought.... At the next pulley party here (Feb 20th) have Randy remove my 15% pulley and replace it with the 19% pulley... however, there are reason why I didnt get it in the first place.... heat and a/f mixture. My question is, if I upgrade my injectors to the 400cc injectors from M7 and have my unichip tuned for it at the local tuner down here, should I be safe? I now have a large TMIC so I am a little less worried about the heat, especially since I plan to p/p the blower in the near future anyway which should drop temps a bit more.
So.... to 19% + injectors + unichip tune OR to not?
Old Jan 13, 2005 | 06:24 PM
conehead's Avatar
conehead
Where is that Feb pulley party going to be ?
Old Jan 13, 2005 | 06:28 PM
JCampos's Avatar
JCampos
NorCal.... I BELIEVE at BayBridgeMotors again.... but I hear they have a new and improved shop
Old Jan 13, 2005 | 06:36 PM
minimort's Avatar
minimort
You could go 19%, injectors, and GIAC like greatgro, but you lose the dyno tunability with the saved $$
Old Jan 13, 2005 | 06:43 PM
JCampos's Avatar
JCampos
Ive already got the Unichip so tunability isnt a problem. I would also like to know how long people with the 19% have been running on that pulley and what their driving habits are like. I tend to spend alot of time at high revs, especially when cutting around the retards driving 60 in the fast lane
Old Jan 13, 2005 | 07:18 PM
JCampos's Avatar
JCampos
Oh, and this brings me to another question.... I have the Alta 15% right now and would go with their 19% if I were to upgrade... question being, do I need to pull the entire pulley off or just the outer piece?
Also, how hard is it to change the belt? The pulley is the only thing I didnt do by myself on the car, but changing out the outer piece on the Alta is simple and I highly doubt changing a belt is harder than installing springs and a swaybar.
Old Jan 14, 2005 | 05:33 AM
greatgro's Avatar
greatgro
I've had the 19% for 33k+ miles now and the 15% for 17k miles before that. I have 62k miles currently. Keep in mind, one of the reasons you spend a lot of time at high revs - especially to pass people - is b/c you don't have a lot of torque. I know, I had the 15% and kept the revs up high too. But that changed significantly with the 19% b/c I was getting the torque the 15% gets at 5-6k RPM at 4k RPMs. Unless you're going to do all those mods you listed, tunability is really not an issue. If your ECU is tuned to your pulley and injectors as well as the GIAC is, a different exhaust, intake, header, throttle body aren't going to make a difference. The more "general" GIAC tune will still be better (IMO of course ).
Old Jan 14, 2005 | 06:15 AM
jlm's Avatar
jlm
Yo! what you mean by high revs?
doesn't you tink 6k is arite?
Old Jan 14, 2005 | 06:23 AM
05JCWS's Avatar
05JCWS
Get the JCW kit :smile:
Actually in seriousness, I think a lot has been done in the '05 to help this. I had an '03 with various mods such as pulley, exhaust, intake, chip... And it still bogged down some. My new '05 with the JCW is significantly better, and with 7,000 miles on it, I have never bogged down. I felt a similiar low down grunt in a stock '05. Not sure which specific change fixed that, but probably the gears had a lot to do with it.
Since you already have the Unichip, you may want to try out the injectors from Helix with the 19% pulley.
Old Jan 14, 2005 | 08:34 AM
SpiderX's Avatar
SpiderX
I have made the decision to go 19% with injectors and a GIAC. My Unichip is tuneable but no one around Atlanta tunes them so I have to send my Unichip to Randy who does his best guess. The point is the tuneablility without some with a dyno sitting there tuning is a non feature. The GIAC flash is my next step and it will go in hopefully when I get home from LA in a few weeks.
Old Jan 14, 2005 | 09:24 AM
JCampos's Avatar
JCampos
Thanks for the responses.... you are right about why I spend time at high revs... I didnt think that I wouldnt need to as much with the 19% pulley. I do have a unichip tuner in my area, so I look forward to having it tuned on the dyno to make sure I am getting a nice smooth powerband with a good peak number.
Still, is the 19% outer piece able to fit on the 15% hub? If so I dont need to blow the money having randy install it, I could just pull the 4 bolts out and throw the new ones in. Injectors are an easy install also, so if I can get all this I am looking at around $700-$750 for this bump in power.
Old Jan 14, 2005 | 09:40 AM
MyPocketRocket's Avatar
MyPocketRocket
13" wheels would do the job!
Old Jan 14, 2005 | 10:00 AM
JCampos's Avatar
JCampos
Old Jan 14, 2005 | 12:13 PM
greatgro's Avatar
greatgro
There's ZERO bog, that's right no bog whatsoever at any RPM with GIAC.
Old Jan 14, 2005 | 12:24 PM
sfjames2's Avatar
sfjames2
dude, I think with all the time you spend in upper rpm range (close to or above 7000) a 19% might not be a good idea.
What about 17%, I haven't read to much on the belts failing at high rpm with those.
Old Jan 14, 2005 | 12:31 PM
JCampos's Avatar
JCampos
Like it was mentioned earlier, I wont need to rev so high with the 19%. I would calm down on the high rev driving a bit Heat shouldnt be THAT much of an issue now.... I bet the Alta TMIC probably bring the temps back down close to a stock IC with a 15%... plus I will get the injectors and have the chip tuned to avoid any lean conditions.
GIAC isnt an option greatgro... do you get commission or something?
Old Jan 14, 2005 | 12:45 PM
sfjames2's Avatar
sfjames2
gonna calm down on the high rev driving heh.....ok, we'll see about that one.
hook me up with 15% if you have to buy another will ya? I'm down to help you with the 19% install no prob.
Old Jan 14, 2005 | 12:51 PM
JCampos's Avatar
JCampos
Cool. If you buy the puller ill give you the 15% for free
Old Jan 14, 2005 | 12:52 PM
sfjames2's Avatar
sfjames2
Old Jan 14, 2005 | 12:56 PM
JCampos's Avatar
JCampos
Im tryin to get ahold of Peter to see how long I would have to wait to get some injectors. I should get paid in the next week or so and this sounds like its going to be the next step for me. $700-$750, get to dyno the car, and gain the down low torque I crave This will be a post AGS/TB upgrade. HOPEFULLY Randy can find me a header... been a week with no reply
Old Jan 14, 2005 | 12:58 PM
MartyR's Avatar
MartyR
I emailed the guys at ALTA and here's the answer about putting a 19% pulley on a 15% hub:
NO, because each pulley is matched to a specific hub. However, they WILL give you a significant discount on the 19% pulley/hub combo if you have an ALTA 15% pulley on your car already.
I think it sucks, and wish now that I had gone with the Helix/P&D, but whatever.
I am saving for the 19% plus GIAC plus injectors...hopefully by the time I get the nod from the old lady, the injectors might have come down in price. With any luck it'll be before spring so I can make the most of this cold, dense, Mid-Atlantic air that's sure to come.
Marty
Old Jan 14, 2005 | 12:59 PM
sfjames2's Avatar
sfjames2
just found that the MM pulley remover is for stock pullies only.
do the Alta 15% pullies need a puller to remove them?
Old Jan 14, 2005 | 01:00 PM
JCampos's Avatar
JCampos
I gave them a call this morning also for the lack of a good response on these boards and my response was a bit different. I was told that it may or may not... depends on when you bought your 15%. I guess they did start to make them interchangalbe at one point.... the guy said the timeline I gave him is on the borderline.
Old Jan 14, 2005 | 01:01 PM
JCampos's Avatar
JCampos
Dunno. Maybe ask Randy how to change from 15 to 19?
sfjames2's Avatar
sfjames2
maybe that discount is the way to go afterall.
I'm down to help with installing any of the stuff you mentioned still though.
