Drivetrain Anyone here got a boost gauge in their car without using the Alta mount
Old Nov 16, 2004 | 03:48 PM
larkie's Avatar
larkie
I want to get a boost gauge for my car, is there anyway that i can mount beside [size=2]tachometer[/size]?
since id ont' want to spend $155 for a alta mounting bracket.
Old Nov 16, 2004 | 05:22 PM
WildcatKC's Avatar
WildcatKC
check out the ATI ePod for the mini
http://www.autotechinteriors.com/
Old Nov 16, 2004 | 05:40 PM
MiniPilo's Avatar
MiniPilo
This is a custom pod that I made...
Old Nov 16, 2004 | 05:49 PM
minimort's Avatar
minimort
Dan,
Any plans to market this gauge pod?
Old Nov 16, 2004 | 05:54 PM
MiniPilo's Avatar
MiniPilo
http://www.jcwhitney.com/autoparts/P...p-6589/c-10101
With a little heat gun action, it molds up pretty nice...
Though if I did it again.. I'd trim it a bit
Old Nov 16, 2004 | 09:36 PM
El Diablito Rojo-N20Mini's Avatar
what about the airbags? doesn't that piece pop off when the bag deploys?
Old Nov 16, 2004 | 09:48 PM
TonyB's Avatar
TonyB
That was the first thing I thought of El. I can sort of visualize a boost guage impression on one's forehead . Maybe Dan checked into this and found-out that it deploys in such a way that it wouldn't be a problem. I certainly hope so...
Old Nov 16, 2004 | 09:58 PM
will be interesting to find out...
Old Nov 17, 2004 | 12:38 AM
jinubob81's Avatar
jinubob81
that's it. these guage mounts are just ridiculously expensive.
i'm going to embed them into my arm, and attach a wire to human interface. I will become one.
Old Nov 17, 2004 | 12:42 AM
GRENDEL's Avatar
GRENDEL
I mounted mine in the sun visor
Old Nov 17, 2004 | 04:20 AM
MiniPilo's Avatar
MiniPilo
The Bag Deploys from the Headliner area above the door, not from the pillar area. The Pillar only houses the charge that will expand the Air Bag. Because of that, It is not a concern of mine about flying boost gauges.
Old Nov 17, 2004 | 05:12 AM
jlm's Avatar
jlm
here is an alternate:
Old Nov 17, 2004 | 05:22 AM
thanks for the clarification Dan....
Old Nov 17, 2004 | 06:28 AM
iamwiz82's Avatar
iamwiz82
I am still shocked over the prices of MINI stuff. Maybe I am just used to cheap domestic parts. I can't see how a piece of aluminum can cost me $164.
Old Nov 17, 2004 | 06:30 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Mine's ghetto (velcro in the instrument cluster butt crack) but it does the trick:
Old Nov 17, 2004 | 08:36 AM
TonyB's Avatar
TonyB
Good to hear Dan! I won't have any bad dreams tonight .
I have the "typical" oil pressure & boost (30/30) a la PROMINI on the column. From Summit Racing I got a voltmeter and oil temp gauges (the same Autometer series) and I plan to mount them, along with a Stuart Warner shift light, under the toggles with a home-made plate of some type...
Old Nov 17, 2004 | 09:21 AM
andy@ross-tech.com
It's your head, but I wouldn't put a gauge there. FWIW, the gas generator that inflates the bag is at the rear of the car under the rear side windows. The airbag itself extends along the top of the windows along the edge of the headliner partway down into the A-pillar.
http://www.mini2.com/forum/attachmen...chmentid=31004
That A-pillar is going to need to get out of the way of that airbag when it deploys.
Last edited by andy@ross-tech.com; Nov 17, 2004 at 09:25 AM. Reason: This pic shows where the airbag connects.
Old Nov 17, 2004 | 10:39 AM
MINImotor's Avatar
MINImotor
How are these mounted? looks cool.
Old Nov 17, 2004 | 10:49 AM
DrkSilver163's Avatar
DrkSilver163
it also looks really complicated, wouldnt the steering wheel get in the way of the gauges?
Old Nov 17, 2004 | 10:53 AM
MSFITOY's Avatar
MSFITOY
Jlm...how'd you do that:smile:
Old Nov 17, 2004 | 11:33 AM
jlm's Avatar
jlm
helix can set you up; the bracket is a simple install and can be made to hold two, three or four gauges for a car with or without nav. the gauges are aoutometer. visibility is not 100%, but is workable.
Old Nov 17, 2004 | 12:27 PM
vdubdoug's Avatar
vdubdoug
I believe I still have a single guage mount(Mount of the Tach) and boost guage(Autometer electronic w/ peak boost hold) at home for sale .
Old Nov 17, 2004 | 01:17 PM
FastLaneTuning's Avatar
FastLaneTuning
unfortunately, every one of those shown so far are out of the normal driving view - either too far to the left (a-pillar) or blocked by the beefy steering wheel spokes.... so i did something a little different.....
painted to match the SILVER interior trim.... more available soon!!
Old Nov 17, 2004 | 03:03 PM
larkie's Avatar
larkie
i wondering which is the least expensive way to mount the boost gauge?and to be look good too.. like mount it right beside tach.
can i get those autometer pod and find something mount on the tach?
Old Nov 17, 2004 | 03:22 PM
GRSmotorsport's Avatar
GRSmotorsport
Here's my boost gauge, back grounds now been change to green - its better than the red back ground
