Drivetrain How does the air intake fail
Old Sep 1, 2018 | 05:18 AM
Jacki's Avatar
Jacki
I had my thermostat replaced in my 2011 mini cooper s which cost $1,000 and now after a few months the car ran hot and lost all antifreeze and now the mechanic is saying something about the air intake and it will cost $900. please advise is this a common problem
Old Sep 1, 2018 | 07:59 AM
S-2013's Avatar
S-2013
Am I missing something, how does the air intake cause coolant loss and is it an aftermarket intake? Need more info.
Old Sep 1, 2018 | 08:33 PM
MrGrumpy's Avatar
MrGrumpy
Yes, the two things are just not connected in any way. We definitely need more info. Is he saying that it got so hot that it melted the intake because it lost all of the coolant? It is a little confusing without more to go on.
Old Sep 27, 2018 | 02:20 PM
cornjuice's Avatar
cornjuice
it wouldnt be 900$ to replace the entire intake manifold and intake assembly.. better get some good details and photos before you hand over any $$$
Old Sep 27, 2018 | 08:26 PM
Yupetc's Avatar
Yupetc
Your mechanic must be high off his butt. Our intake doesn't even have any coolant hoses to and from it. Please go kick him in the nuts and find another mechanic who is honest enough to not take advantage of customers.
Unless you're having something else done, that thermostat job shouldn't even cost 1k either. The part can be had through ECS for less than 200 bucks, labor isn't that difficult or time consuming, whole thing shouldn't cost more than 500 bucks.
Your issue of losing the coolant must be due to something else. I suspect the pipe between the water pump and the thermostat is probably having a leak. That thing can be found if you remove the intake manifold, look for "white water marks on that plastic pipe" and you probably can get a clue there.
Hope this helps.
Old Sep 27, 2018 | 08:43 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You need another opinion as we do a thermostat for about $500 so a $1000 is HIGH. Then to say something with the intake causing the overheat for $900. If it's true using the same math would only cost $450. Won't hurt to get another option.
Old Sep 28, 2018 | 07:37 AM
Hope this helps.
Yep, something does not sound right +1 Thermostat DIY is here for reference: First time you do it you will need the pigtail for the 2011 S models
https://www.northamericanmotoring.co...ine-codes.html
We also have lots of thermostats in stock and free shipping.
Geoff Boynton
Sep 15, 2016 02:10 PM
Mb460
Sep 12, 2016 03:56 PM
MiniMe762
Feb 6, 2003 08:27 AM
invaliduser
Oct 17, 2002 11:54 AM
SCHAPO
Oct 4, 2002 07:46 PM
