Drivetrain No MAF sensor readout over OBD?
Old Aug 31, 2018 | 06:23 PM
mationato's Avatar
mationato
Over the summer I had my car RPM Stage 2 tuned. During the process the car spent about 4 weeks with no ECU. I'm not sure if this is part of the cause, but for some reason now my UltraGauge (nor torque pro, nor carly) can measure MAF sensor anymore. I noticed this because I usually have my UltraGauge set to show me trip MPG, but it can't calculate MPG without the MAF readout. Here's an image of what the UltraGauge is showing:
Does anyone know what could be causing this? I've been assured by the tuner that RPM shouldn't be blocking this output. Could I have a blown fuse somewhere? I don't think it's the sensor going bad because I don't have any stalling issues on startup.
Old Sep 3, 2018 | 05:30 PM
BigBoost's Avatar
BigBoost
are you getting any cels
Old Sep 3, 2018 | 08:33 PM
mationato's Avatar
mationato
nope, no trouble codes showing
Old Sep 3, 2018 | 08:37 PM
BigBoost's Avatar
BigBoost
is it plug in?
they will sometimes now show a cel
Old Sep 3, 2018 | 10:16 PM
mationato's Avatar
mationato
is it plug in?
The MAF sensor? Yeah it's plugged in, I'd imagine that if it weren't I'd be having a lot of engine troubles. I've also tried disconnecting the battery and reseating both the MAF sensor and the ECU to no avail
Old Sep 3, 2018 | 10:24 PM
BigBoost's Avatar
BigBoost
Yeh I drove around with
mine unplugged for about 2 weeks before
i noticed it was never plugged back in
Hell of a lot more
pop’s & bangs
but didn’t throw any codes .
Idk if it’s not thrown
any cels
an it driving fine I
wouldn’t worry about it
who help you at RPM
have a buddy’s o7 setting in my shop now.
Waiting for a stage 3 from them.
he ended up getting
the power gate flash tool.
Instead of sending the ecm out
Old Sep 3, 2018 | 10:31 PM
mationato's Avatar
mationato
Hell of a lot more
pop’s & bangs
any cels
who help you at RPM
he ended up getting
Hmm ok. I just did some reading and people are saying that if you unplug the MAF while idling the engine should idle differently as long as the sensor is still good, and it'll be the exact same if it's bad. So I'll try that tomorrow and see what happens.
It's hard to tell exactly the cause. I've got a lot more pops and bangs too, but since this happened the same time I did the RPM tune I'd assume it's the tune causing that. I'm less so worried about the car having issues due to the OBD not reading this and more annoyed that I'm losing my MPG gauge lol
Old Sep 3, 2018 | 10:38 PM
BigBoost's Avatar
BigBoost
Yeh it’s hard to say
i don’t think I’ve ever seen anyone
With that problem .
Old Sep 3, 2018 | 11:30 PM
MrGrumpy's Avatar
MrGrumpy
Yeah, that’s a different one. Is your OBD2 port working at all? Is it just boost you are having trouble reading? If it’s not working at all, it may very well be a fuse, that happened to me once when I had my battery replaced, plugged in my scan tool to register the battery and had no power there. Scratch that I see it’s the MAF for MPG not the MAP for boost. My mistake. I still don’t see how the tune can be causing it. I have RPM also. I think at this point you should consider replacing the sensor to see it that fixes it. Or if it’s running fine, maybe just learn not to worry too much about MPG? You do have a tune after all. Drive it hard and you won’t want to know your MPG’s, lol. I’m just joking there, but I seriously doubt it has anything to do with the tune, check the sensor
Old Sep 4, 2018 | 07:11 AM
mationato's Avatar
mationato
Yeah the OBD works fine for all the gauges I used to use except for this one. I don't think it's the tune that's causing it either, I'm just not sure what it could be.
Old Sep 4, 2018 | 12:44 PM
cornjuice's Avatar
cornjuice
MAF may be broken..so car is in open-loop/WOT mode and using ECU fuel tables ... NOT measuring LAMBDA.
**The above is why your mileage sucks. Pickup a new MAF sensor to swap in.. see if your readings come back after.
Old Sep 4, 2018 | 09:16 PM
mationato's Avatar
mationato
Is there a way to diagnose the MAF sensor definitely? My mileage hasn't changed dramatically and when I unplug it while running, the engine does change the idle slightly -- it doesn't get horrible, but there's a slight change. I'd rather not spend hundreds of dollars on a new MAF that I don't actually need.
Old Sep 4, 2018 | 09:28 PM
BigBoost's Avatar
BigBoost
you could use a multi meter
test the singles to & from the ECM
should be 4 wires
2 will be power & ground
the other two
will be
the Signal wire from ECM
an
signal wire ground
Going to have to try to find a voltage chart
Along with the wiring diagram
Old Sep 5, 2018 | 12:03 PM
MrGrumpy's Avatar
MrGrumpy
There has to be ways to test it. BigBoost above has it there. Just need to know what you’re looking for..... I’m not exactly sure if I could do it without a tutorial, but I’m not exactly electronically inclined, lol. Good luck. I didn’t realize that the MAF is pricey to replace, but that’s not surprising. Most everything OEM on these is a bit on the spendy side.
Old Sep 5, 2018 | 05:52 PM
mationato's Avatar
mationato
Ok so I pulled the plug on the sensor again and tried to drive this time. It stalled almost immediately, so it's definitely different with the maf unplugged. I've got a multimeter that senses frequency on the way, so I'll test out the signal wires when I get that. Otherwise, I guess my options are to either deal with it (and the possibility of other things not working that I'm not aware of) or taking it to the dealer. It's hard to tell what's wrong because I had the ecu out for a month or so while I was out of state and getting it tuned, so it could be just about anything.
Old Sep 5, 2018 | 06:02 PM
MrGrumpy's Avatar
MrGrumpy
Hmmm...interesting. I usually actively avoid thinking about mpg because my car, especially since Mario tuned it, totally brings out my inner 13 year old, lol. And I know I’m getting terrible mileage. But I’m having way more fun this way. Aside from it not reading through the OBD2 port, there are no other symptoms or codes? I still can’t help but think there must be something with the sensor or plug/wiring that is causing the problem, since the obd port is working for everything else.
Old Sep 5, 2018 | 06:41 PM
BigBoost's Avatar
BigBoost
It could still be going
bad it’s just not seeing the
proper amount
of voltage
yeh if you have a tune don’t worry about your mpg
Old Sep 5, 2018 | 08:14 PM
mationato's Avatar
mationato
Nope, nothing else that I can see isn't working. No trouble codes (or pending trouble codes) that I can find. It seems to be running perfect. I usually like to see my mpg for long trips, but it doesn't really matter that much to me -- smiles per gallon is much more important. With that said, is there anything I should replace the gauge with? I've currently got boost PSI, coolant temp, outside temp, intake temp, mpg srt, and miles srt. I also might hit up a friend and see if he'd let me try to swap in his MAF sensor to see if that changes anything.
Old Sep 8, 2018 | 03:17 PM
mationato's Avatar
mationato
Okay, I've done some testing. I honestly have no idea if I'm measuring the right stuff or not, but here's what I've managed to gather:
Of the 4 wires on my MAF plug,
(pin 1) orange = 12v
(pin 2) white = ground
(pin 3) blue = 5v
(pin 4) yellow = ground
I wasn't able to measure any voltage differences while revving (as expected since it's a hot film MAF)
Here's a wiring diagram from the bentley manual that shows the pins on the MAF:
https://photos.app.goo.gl/CZxBhykVS6BWZ27C9
Of all the combinations, I was able to read a frequency if I put the test leads between the orange and yellow wires.
Here's a video of me revving and the resulting frequency output:
https://photos.app.goo.gl/bvTjXaiaGNEXotCW6
In the video, it looks like the voltage is related to the RPM, but it's also jumping around a lot. I'm not sure if this is expected, or if it's the MAF's fault, or if it's the multimeter's fault.
Does anyone have any insight given this data?
Old Sep 9, 2018 | 08:06 AM
BigBoost's Avatar
BigBoost
Yeh I don’t think
you have you’re Multi meter
set right ,
Old Sep 9, 2018 | 08:07 AM
BigBoost's Avatar
BigBoost
Old Sep 9, 2018 | 04:27 PM
mationato's Avatar
mationato
I think I've got it set right.
In the second video the guy says there will be a constant voltage (5 or 12v), constant ground, signal wire, and sensor ground.
So in my case, it seems the blue wire was constant voltage (@5v), white wire was constant ground, orange wire was signal wire(@12v) and yellow wire was signal ground.
Since the R56 uses a hot film type MAF sensor, I should be using the Hz monitoring between signal wire and signal ground (orange and yellow).
Am I wrong in these assumptions? I'll have to go back and measure the terminals when it's not connected to the MAF to validate this.
Old Sep 13, 2018 | 10:42 AM
BigBoost's Avatar
BigBoost
well if you have it set
right
my guess would be bad maf
but it’s hard to say over the inter web
Old Aug 9, 2025 | 10:34 AM
aaron5140's Avatar
aaron5140
I know this is an old post that I'm reviving, but I have this exact same situation. 2007 mini Cooper s with a tune from RPM. Once I got the ECU back I saw zeros from my MAF sensor. I've swapped out the sensor with the same results.. has anybody figured this out yet?
Old Aug 10, 2025 | 11:51 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Two examples that correlate with a RPM tune.
RudyT
Europe
51
Mar 24, 2007 02:44 PM
dave
Southern California
Mar 13, 2005 04:39 PM
Pocket_Rocket
Mid-Atlantic
Oct 18, 2004 09:35 AM
