Drivetrain Replacing OEM pulley...anyone done it?
Old Nov 11, 2004 | 01:27 PM
Bisch's Avatar
Bisch
I know this was discussed months ago. Has anyone attempted to re-interface fit the oem pulley? Bake it in the oven to 500 degrees, etc.
Can it be cranked back onto the shaft with a 13mm bolt in the threaded shaft end...basically a reversal of removal.
Old Nov 11, 2004 | 01:51 PM
paul_'s Avatar
paul_
WHY do you want to replace your pulley? does that mean u want the STOCK pulley BACK ON????????!
-Paul
Old Nov 11, 2004 | 02:17 PM
Bisch's Avatar
Bisch
Yes.
I have my reasons.... (some regulars have probably figured out why... )
Old Nov 11, 2004 | 02:56 PM
mini giant's Avatar
mini giant
i dont know if this will help, but if i recall correctly, i thought their was a company that sold a stock size pulley that was the same type as the reduction ones
Old Nov 11, 2004 | 03:00 PM
jlm's Avatar
jlm
Old Nov 11, 2004 | 03:10 PM
GBMINI's Avatar
GBMINI
Bisch,
Might it be less expensive overall to grab a stock supercharger off eBay? They appear now and then ...
Old Nov 11, 2004 | 03:23 PM
minimort's Avatar
minimort
Going for STX perhaps?
Old Nov 11, 2004 | 03:31 PM
MartyR's Avatar
MartyR
Nope. Not STX but "TC".
hahaha
Have fun, Bischy!
Marty
Old Nov 11, 2004 | 03:35 PM
Pebblecrusher's Avatar
Pebblecrusher
Your pulley is two parts right? I know Helix sells several sizes, and think they have a stock size too. Would that be good enough? Or do you have to have the actual stock pulley?
Old Nov 11, 2004 | 03:43 PM
minimort's Avatar
minimort
hahaha
Have fun, Bischy!
Marty
TC?
Old Nov 11, 2004 | 03:45 PM
mini giant's Avatar
mini giant
i knew their was someone out there that knew the company,lol
Old Nov 11, 2004 | 03:51 PM
MartyR's Avatar
MartyR
I don't wanna be the one to spill the beans.
Marty
Old Nov 11, 2004 | 03:58 PM
mini giant's Avatar
mini giant
does the TC stand for t--- c--r-e- fill in the blanks
Old Nov 11, 2004 | 04:10 PM
TonyB's Avatar
TonyB
pfft! [BOV sound]
at least that's my guess...
Old Nov 11, 2004 | 05:47 PM
early_apex
Did you mean t _ _ _ _ c _ _ _ _ _ _
| ...0
Old Nov 11, 2004 | 07:26 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Actually, if you are replacing (returning) the stock pulley, the safest way to install it is to run a long bolt or threaded rod into the blower shaft first, then add the preheated pulley, a thick washer (or two) then a nut. Crank the nut down the threaded rod to press the pulley onto the shaft. Reason for this is that the threads in the supercharger shaft might be a bit softer than the bolt you would be using, plus not very deep. You dont want to strip the shaft threads out, nor do you want to bottom the bolt out during the pressing process. Doing the latter will allow the assembly to cool and tighten up while you are scrambling to find washers or a shorter bolt.
Old Nov 12, 2004 | 06:35 AM
norm03s's Avatar
norm03s
OEM pulley size refit
I think Helix has an interference (shrink fit) hub with a bolt on stock size pulley.
Same heating procedure is used but theirs has a stop on the hub so alignment is a no brainer.
I want them to make (jlm) an OEM size pulley for the two piece compression style which I have. So then you could go OEM, 15%, 17%, 19%.
Old Nov 12, 2004 | 07:08 AM
jlm's Avatar
jlm
it's in the works; it will be a piggy though.
Old Nov 12, 2004 | 08:09 AM
norm03s's Avatar
norm03s
WaWooo
Thanks, thats GREAT news!:smile:
Old Nov 12, 2004 | 08:19 AM
MartyR's Avatar
MartyR
I have heard from at least two reputable sources that the OEM pulley is warped when pulled. Can anyone confirm/deny this?
Marty
Old Nov 12, 2004 | 08:39 AM
mini giant's Avatar
mini giant
i thikn you and me are thinking the same thing, but i think your first word might have and extra letter
| ...0
Old Nov 12, 2004 | 10:26 AM
Bisch's Avatar
Bisch
Marty
I have a few of them here. One is toast. Two look to be true.
Old Nov 12, 2004 | 12:04 PM
early_apex
I was thinking your first word was missing a letter...
edit - I get it now :smile:
Old Nov 12, 2004 | 12:32 PM
MartyR's Avatar
MartyR
you guys are both right.
Bisch, I'd go with the P&D pulley that Helix sells (or is rumored to - I dunno if that's what jlm is referring to here). You have an ALTA now, right? Should be an easy swap.
Keep up posted on your "new developments."
Marty
Old Nov 12, 2004 | 06:58 PM
Bisch's Avatar
Bisch
I can't find a good pic of the original pulley on the shaft of the SC. Anyone have a close-up? Better yet, is the oem pulley hub flush with the end of the shaft? I seem to remember it was set a little deeper than flush...anyone with specs? I'm gonna heat it and screw it.
BTW, if anyone is installing a 19% or greater boost, and plan on romping the snot out of it, my suggestion would be to re-torque your head bolts first...before it's too late.
