Drivetrain R56 N14 Piston Ring Suggestions
Old May 15, 2018 | 09:31 AM
Bcoday's Avatar
Bcoday
I'm looking for some info on piston rings for my 09 MCS rebuild. I'm not doing anything fancy to the engine. Just a simple rebuild for my daughter's Mini.
What brand/vendor would you suggest and why?
Old May 18, 2018 | 07:39 PM
oldbrokenwind's Avatar
oldbrokenwind
Try OEM rings but use non-synthetic oil for break-in, then switch back to full synthetic oil. If going for oversize pistons, get the piston mfgr rings. I've found that using non-synthetic oil for break-in allows the rings to seat properly, and stop excessive oil burning --- less than 1 qt used every 5K oil change. If cylinder bore isn't true round, or there's lotsa miles on the engine, you should really consider a slight over-bore, new pistons and rings. Pistons that're 0.050mm oversize are readily available for most of the aftermarket suppliers.
Old May 19, 2018 | 08:07 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
talk to jan I heard he has a fix for the oil burning
AvianMan
Mar 30, 2020 07:12 AM
dajiggalo
Sep 2, 2017 07:08 AM
jeffl
Sep 22, 2016 01:38 PM
GreekDrifter91
Jul 18, 2016 08:16 AM
genik
Apr 5, 2014 08:04 AM
