Drivetrain BBQ mode as a intake valve cleaner ?
Old Feb 24, 2018 | 10:35 PM
blue al's Avatar
blue al
My N14 roadster project is beginning to take shape
It's starting this journey with just cosmetic + handling bits and bobs to begin with,
whilst I forge a longer term plan for upgrades under the hood.
Remember I have a factory fresh engine with next to no miles on it (3500)
So what's the best way to keep those inlet valves clean and shiny, the idea of multiple catch cans and foot after foot of tubing snaking around the engine bay leaves me stone cold.
What if there was a solution under our noses ?
It occurred to me that BBQ mode is sending unburnt fuel down the pipes,
Could this also not help clean the inlet valves ?
Could this be tweaked further and made into a "service map"
Be good to hear anyone else's thoughts on this concept, might be that
What I save on catch cans could be spent on extra fuel, or exhaust components
Still a clean engine is a happy engine.
Old Feb 25, 2018 | 06:26 AM
thebombardier's Avatar
thebombardier
Nothing will keep the intake valves clean on a stock motor because the engine is direct injection. By the time any fuel in entering the mix the intake valves are closed and the area that gets coked up is closed off to the ignition cycle. You either need to walnut blast them periodically or invest in methanol injection.
Old Feb 27, 2018 | 06:16 AM
Gabriel MCS's Avatar
Gabriel MCS
WMI keeps it clean.
Old Feb 27, 2018 | 06:58 AM
thebombardier
Originally Posted by Gabriel MCS
WMI keeps it clean.
Also I wouldn't call an engine with WMI a "stock motor".
Old Feb 27, 2018 | 10:19 PM
blue al's Avatar
blue al
Should meth be 4 port or will a simple single jet do the job ?
Old Feb 28, 2018 | 04:20 AM
thebombardier
Single would be fine. As long as you have fluid hitting the back of the valves. There's a guy over in the Aquamist thread who made a 4 port setup and it is a pain to say the least.
Old Mar 4, 2018 | 07:11 AM
BigBoost's Avatar
BigBoost
4 port really don't do much! cuz its post MAP" single jet before MAP works the best. until we have a standalone tuning system i would just stay with the jet! AM running aquamist my self ! go check this thread out i have some photo in there of my set up think its on page 21/22 really cant remember !
https://www.northamericanmotoring.co...n-systems.html
Old Mar 4, 2018 | 10:49 AM
oldbrokenwind's Avatar
oldbrokenwind
I started with a single 1.2mm jet, located "upstream" of the MAP/T sensor --- worked great 'til I got over 300WHP. After blowing #1 spark plug and 1 exhaust valve due to heat, I added 4 more 0.4mm jets, and also changed the sensor jet to 0.4mm, for a total of 2.0mm. Yes, it was a PITA to add the 4 jets, but for my build it was necessary. I chose to add them to the existing manifold, but there are manifold "spacers" out there that can be modified to accept WMI jets. Still a PITA!
Lesson learned --- WMI is good for not only cleaning valves, but also for cooling down the combustion chamber. Our intake manifold is not designed for distributing the "upstream" WMI, only air. As a result, WMI was not being distributed properly to #1 cylinder. Apparently not a problem 'til you get closer to 300WHP, unless maybe you do a lot of track driving --- mines a DD with minimal full throttle --- don't need it that often. I'm also running a dual OCC --- really want to minimize build-up on the valves.
So, my recommendation is to go with a dual OCC, then the Aquamist HFS4 WMI and a Manic tune -- to get the full benefit of WMI. Depending on your WMI ratio, there's power to be had. Talk it up with your local Manic installer.
Nealuss
Jan 12, 2019 05:58 PM
phil@detailersdomain
Detailing 101
May 17, 2012 11:59 AM
Detailing 101
May 2, 2010 07:29 PM
RonP
Detailing 101
18
Dec 2, 2006 11:15 PM
jsouz
Aug 1, 2006 09:48 AM
