Drivetrain Current LSD options?
Old Aug 16, 2018 | 04:41 AM
  #26
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
mfactory have been popular with 135i/335i owners, well reviewed when I was shopping for my 135i
Old Aug 16, 2018 | 07:20 AM
  #27
downshift1's Avatar
downshift1
We broke the Subaru ones when they came out and went to Quaife and never had an issue.
Old Aug 16, 2018 | 11:27 AM
  #28
MrBlah's Avatar
MrBlah
a little off topic, did you break the viscous coupling diffs?
Old Aug 16, 2018 | 02:26 PM
  #29
Boostmaster's Avatar
Boostmaster
Interesting.... I need to do more research... Hard to swallow $1k or better especially when I don't really push the car or track it. Just want it to be able to hook up when I mash the pedal... (yes, the other bits will be addressed but I want to take advantage that the "boss" wants it to be as "sticky" to the road as the WRX...) Just need to be able to justify the expense.
Old Aug 16, 2018 | 02:50 PM
  #30
MrBlah's Avatar
MrBlah
Doing the install yourself? The labor to install thrtlsd he the biggest expense, and then you might as well do a clutch too while you are there, and rear main and crank sensor...
Old Aug 16, 2018 | 03:09 PM
  #31
Boostmaster
I do all my own work. I'm planning on pulling the whole engine assembly. Much easier. And simply going through everything. Clutch is at 130k with zero issues...
Might do one anyway. No real leaks to speak of but if I'm there I may go ahead and do it all.
Right now, I'm just trying to narrow down the expenses and if I can get an LSD that does the job without having to be the top of the line super, ultra, mega...-I'm fine with that.
However, I don't want to install some junk that will break after a few spirited runs (should I be so inclined)
Old Aug 16, 2018 | 03:22 PM
  #32
MrBlah's Avatar
MrBlah
I've done 3 so far, but I never take the engine out I always use "mod mini" videos on it, with a engine support brace it's pretty easy I can do it in a weekend now. Having a lift also helps a lot but I'm not sure it would change my opinion much on full remove vs trans only. I guess I need to try a full swap once to see how it is.
Old Aug 16, 2018 | 06:28 PM
  #33
Boostmaster
We use MOD mini as well. Last time took 2 hours to pull everything. No lift, just jack stands. Next time I think we can do in 1 hour. There's no rust. Everything moves freely. Having engine out affords better opportunity to inspect, clean and touch everything. I have another car to use in the interim and can take my time once it's all out. Been shopping for odds and ends a little at a time so I can have it wrapped up rather quickly. I hate having to wait on parts...
Old Aug 18, 2018 | 07:49 PM
  #34
Mini_Crazy's Avatar
Mini_Crazy
FYI: Looks like the Ford Torsen for our Getrag 6sp may still be available for $598 + shipping from one source:
http://www.chicagoconnection.us/inde...oducts_id=5878
Like the Quaife, this is a helical gear LSD, and both are based on the original licensed Gleason patents I believe.
That said, I have a Quaife sitting in the garage, waiting to replace the OEM Mini GKN LSD that's currently in my car.
Old Aug 20, 2018 | 01:44 PM
  #35
Boostmaster
Good Catch. Sadly, they're out of stock. They referred me to another dealer who said it's discontinued....
Oh well...At least we tried.
Old Aug 21, 2018 | 11:16 AM
  #36
downshift1's Avatar
downshift1
They only offer torsion and plated
Mr_Bueno
Dec 1, 2012 07:04 PM
MattMan
Sep 22, 2009 08:11 AM
Krut
Jan 5, 2006 09:36 AM
pure&simple
Aug 15, 2005 04:52 AM
imaginemini
Sep 4, 2004 12:10 PM
