Drivetrain Removing the airbox and putting filter on the front
Old Aug 20, 2017 | 06:05 PM
Ray167's Avatar
Ray167
Hello everyone,
I was just curious if there is a solution where the piping which brings fresh air from the front of the car to the air box can be just used to bring air right to the turbo. Also a filter can be placed on the front to clean the air. In the picture the pink line would be routing for the pipe coming from the front.
Old Aug 21, 2017 | 05:50 AM
MiniToBe's Avatar
MiniToBe
i think the design is made to maximized air coming to the turbo. even if you put a "same size" filter, the air flow will be less. not only that, you still need to install the MAF.
What is the benefit of your shortcut?
Old Aug 21, 2017 | 07:34 PM
Ray167's Avatar
Ray167
Well I have seen these other cars which have filters right on the turbo inlet. It just seems strange to make the air travel so far to the back and then come back to front when it could just as easily be filtered a few inches from the turbo itself. I did look into systems that do what I was thinking about and one of them seems to doing pretty well. Link below, but unfortunately its not MAF compatible.
http://www.dnafilters.com/en/product...ON-MAF-VERSION
Also a member who used it wrote a review on it.
https://www.northamericanmotoring.co...ng-review.html
I think I will try to DIY this and see what happens.
Old Aug 21, 2017 | 07:51 PM
MiniToBe's Avatar
MiniToBe
Is it worth the extra 5WHP?
Old Aug 21, 2017 | 09:19 PM
Ray167's Avatar
Ray167
Lets see I am not sure if I could even get an extra 5 whp. But I know it will be fun to try.
Old Aug 22, 2017 | 04:00 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
In the review thread, he saw basically NO gains with that style intake, so why bother with it? Get a K&N and be done. Or better yet, get an AEM or DDM which includes a scoop duct. There are many other mods and upgrades that are more worthwhile.
Old Aug 22, 2017 | 01:56 PM
Ray167's Avatar
Ray167
Well over stock air box there is definitely gains, but not over the K&N system he was running.I am gonna try to make my own with the MAF in the mix and see what happens.
Old Aug 22, 2017 | 06:05 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Originally Posted by Ray167
Hello everyone,
No air filter just straight outside air to the Turbo via pipe diagram....wanna be a test pilot
First off anything sucked in will be chewed up in the blades of the turbo. All the sand and dirt will eat up the turbo bearings ( eventually ) that is if it outlasts the engine .....
Then there's the MAF wire....no getting past that.
Old Aug 22, 2017 | 08:00 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Check out this thread: http://www.minitorque.com/forum/f272...nls-r56-25947/
he uses the stock filter box... probably the most Torque and HP out of any R56 anywhere (except maybe OldBrokenWind here on NAM.)
Go ahead and do it if you have to scratch that itch, but that's not where the power is found.
Old Aug 22, 2017 | 09:32 PM
randeez's Avatar
randeez
Old Aug 24, 2017 | 03:03 PM
Dr. Spade's Avatar
Dr. Spade
Well that's interesting. Haven't seen it before. How's heat in that area?
Old Aug 24, 2017 | 04:00 PM
RYANR56's Avatar
RYANR56
If you have the time, give it a try! Don't pay any attenention to the negative. Every once in a while, someone comes up with a better idea then what is out there. Personally, I love the sound of my intake. It is very talkative! LOL
Old Aug 24, 2017 | 11:14 PM
Ray167's Avatar
Ray167
Originally Posted by randeez
Wow thats a very custom looking pipe from the turbo to the MAF. I ordered a silicone reducer and should have it in a few days. Where did you get yours made? I was just gonna drill a hole for the PCV hose in the MAF sensor housing, but your pipe looks a lot better.
Old Aug 24, 2017 | 11:24 PM
randeez's Avatar
randeez
It's a piece no longer in production from forge, was marketed for a Peugeot 208gti (same n18 engine).
Forge said all remaining stock went to a tuning shop in france, thats who i bought it from. Would have to dig back through emails to remember.
it throws a MAF code for high flow, manic 2 suppresses it
Old Aug 24, 2017 | 11:35 PM
randeez's Avatar
randeez
Filter is right where the cold air tube comes through the grill, extended idling it will climb up but no worse than the stock box and pipes. Bumper to bumper traffic crawling it only goes up maybe 10* over ambient.
My car only has stage 2 tune, seems like it could use a little more fuel right off idle in the tune but it's not bad driving
Old Aug 25, 2017 | 07:19 AM
Dr. Spade's Avatar
Dr. Spade
Oh yea you're local. I was wondering about the cold air tube.
I currently have the K&N intake with the same Vibrant dry flow filter you have. Opened up the hood scoop a little so air hits it well on track days.
Old Aug 25, 2017 | 07:39 AM
Qik420's Avatar
Qik420
I ran into the cowl cover. Still fresh air IAT's right at ambient. Sounds awesome.
Old Aug 25, 2017 | 08:52 AM
Ray167's Avatar
Ray167
So when you say the code is for high flow do you mean the sensor sees too much air coming in and it dosnt like it?
Old Aug 25, 2017 | 09:28 AM
randeez's Avatar
randeez
The cold air tube is removed also
With the tune it doesn't seem to care, even if I switch back to stock map with the code thrown it drives the same. I'm guessing the ecu has a set of MAF flow numbers per rpm/speed it monitors . With the hybrid turbo the MAF is maxed out much of the time
Old Aug 25, 2017 | 07:56 PM
Ray167's Avatar
Ray167
randeez I forgot to ask how did you attach the expansion tank to the back. Did you make a bracket for it and drill a hole into the plastic part on the rear of the engine bay. What kind of screws did you use?
Old Aug 26, 2017 | 09:38 AM
randeez's Avatar
randeez
Yep, I had some 1/8" aluminum plate just an almost 90* bracket eith a couple of spots cut out for clearance of the tank. Attached with 10-32 machine screws, fender washers, lock nuts
Old Sep 2, 2017 | 03:32 PM
Ray167's Avatar
Ray167
Semi finished job
Ok so here is my progress up to now in the first picture. I did run into three problems, the first that the diameter of my air filter is 6" which is too big and interferes with the large diameter coolant hose. This you can see in the second picture. I ordered a K & N filter that should resolve that problem. The second issue I have is that after removing the noise maker I couldn't find a proper cap sized for the hole left in the charged piping. In the third picture you can see that I took some thick plastic and clamped it on the opening. This will be a temporary fix until I get some fancy new charge piping. In the last two pictures you maybe able to tell that there is a small hole for the crankcase venting pipe where the filter is. Since the opening is half a circle I am pretty sure I cannot find any kind of filter to fill it in. I am thinking of using some high temperature silicone to patch up that area.
Entire work.
Air filter interfering with the coolant pipe.
Small hole left in the crankcase venting pipe.
Old Sep 20, 2017 | 08:55 PM
Ray167's Avatar
Ray167
Ok so an update on my setup. A few minutes after running the engine with the high flow filter I got the CEL light which I am pretty sure is the result of the MAF sensor having too much air flowing through it. So as a result my Mini is running pretty crappy. The low end power has pretty much disappeared and the car feels like its a NA engine. I talked with Randeez about it hoping that a tune would solve the problem and unfortunately all it does is turn off the CEL light with no change to the MAF problem. I also did a google search for the MAF problem and ran into an old post on NAM https://www.northamericanmotoring.co...e-made-31.html. It was 31 pages which I read through and the best solution people were talking about was an elbow before the air filter in order to smooth out the air flow. The elbow wouldn't work for me because I have no room to fit one in so I am just going back to stock and look into aftermarket air box instead.
Old Sep 21, 2017 | 04:57 AM
Qik420's Avatar
Qik420
Also, venting to atmosphere causes more oil consumption/loss.
Old Nov 15, 2017 | 01:39 PM
AWD_Rally's Avatar
AWD_Rally
Moderator
Veteran: Marine Corp
I plan on moving the expansion tank like you did to tighten up my intake a bit. I have more mods are plan on doing, that will support the room I need for this, so this has been on hold for a bit.
Since a bend seems to be ideal before or after the MAF I curved it around the way I did so that the filter can be up front. This is what I did temporarily.
