Drivetrain P0141 with catless downpipes + spacer.
Old Aug 16, 2017 | 01:19 PM
yervais's Avatar
yervais
I am experimenting a bit with the catless down pipe (please don't &#128293 I I used all kinds of spacers, it works... sort of...
I keep throwing pending code P0141 for secondary sensor heater but ONLY when I go WOT.
1. Question: why does WOT triggers P0141? normal driving no codes pending or permanent with CEL. We tried another O2 and still the same behaviour, normally o2 spacers are adjustable... getting the sensor "closer" triggers p0420 only... getting it a bit farther away triggers p0141 and even farther p0140 & p0141.
2. Do "Pending" codes affect drivability in terms on fuel trims or injector pulse? Or only "confirmed" codes?
Everything else is fine and drives perfect, it even reaches full readiness after three drive cycles...
Old Aug 16, 2017 | 02:46 PM
cerenkov's Avatar
cerenkov
When you go WOT, air to fuel ratio goes rich, so this maybe the reason. Normal driving is fairly lean especially with direct injection and super lean burn mappings.
Old Aug 16, 2017 | 04:38 PM
yervais's Avatar
yervais
I see... so is too hot or too cold of a temp for the sensor the problem?
JC
Old Aug 16, 2017 | 05:49 PM
cerenkov's Avatar
cerenkov
I was thinking that there is a lot more unburned fuel (from running rich during WOT) in the exhaust stream that the sensor detecting.
Old Aug 16, 2017 | 06:32 PM
yervais's Avatar
yervais
Thanks cerenkov, but wouldnt that trigger P0420?
or why P0141? Which apparently is unrelated...
Old Aug 16, 2017 | 06:51 PM
cerenkov's Avatar
cerenkov
You're right, sorry didn't read your first post closely enough. I'll think about it some more.
Old Aug 16, 2017 | 06:55 PM
yervais's Avatar
yervais
Thanks! I am really looking to get to the bottom of this...
Old Aug 16, 2017 | 07:02 PM
cerenkov's Avatar
cerenkov
Is it possible that you damaged a wire and when going WOT the engine rocks causing the wire to move and touches something and shorts to ground?
Old Aug 16, 2017 | 07:04 PM
yervais's Avatar
yervais
not really... we even tried another O2 same results... and if we reinstall without O2 spacer we get the "normal" P0420.
Old Aug 17, 2017 | 06:51 AM
spotted's Avatar
spotted
Hmm I'm getting the P0420 code from installing a new downpipe. I was thinking that it was the sensor and was about to buy one but now since I saw that you have that problem even with a new sensor.
I also get this when I go wot. Don't know if this code will cause any damages.
Old Aug 17, 2017 | 07:34 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
It is not at all uncommon to get O2 sensor codes when you install a cat-less down pipe. Only option is to ignore the light, or have a Manic tune installed to remove the code.
yervais
R60/61 Cooper S Drivetrain
Jul 11, 2019 04:27 PM
