Drivetrain Engine Rebuild Rocker Arm Questions
Old Apr 3, 2017 | 02:25 PM
hwy78garage's Avatar
hwy78garage
Hi.building my engine on a 2006 MCs 83k miles .Not sure about the rocker arm tappets.How do you know if they are good.A few where stuck but managed to free them up,they feel a little loose do they get stiff with oil pressure or should they feel stiff and have some tension when you push down on the plastic cap. Should i replace all now. Any info on this would be great thnx.
Old Apr 5, 2017 | 11:35 AM
xsmini's Avatar
xsmini
I had one tappet with some wear on the roller when I rebuilt my engine a year ago. That is the only one I replaced.
Nik
Old Apr 9, 2017 | 11:14 AM
hwy78garage
Answer better to replace them
Buying new ones $18 intake side. $ 23 exhaust side.
Old May 9, 2017 | 07:50 PM
AlphaBob's Avatar
AlphaBob
hwy78garage,
Where are you finding those prices? I'm looking for rocker arms for a 2006 R50 and the prices I'm seeing are considerably higher.
Let me know, I'm in the middle of a tear down.
Old May 10, 2017 | 08:09 AM
hwy78garage
Rocker arms
There beautifull. There available from Carid. Purchased mine from RMeuropean. I live on the west coast shipping was to much. There made by ajusa seen some on ebay for a little more. There out there. Also found a exhuast set complete new on ebay delivery miles. There still a brand nee head available with vslves & springs. on ebay canada great deal with the xchange rate
Old Feb 15, 2020 | 05:59 AM
booyah93's Avatar
booyah93
After replacing the timing chain componets I still have this exact same noise from a year ago. Do you guys think it’s rocker arms? Someone else suggested it is. Also if I could do the timing chain does that mean rocker arms should be no problem? The cam has to go in a specific way because of the peg on the face of it and I own a Bentley manual. Lmk please!! Thank you!
Old Feb 15, 2020 | 09:11 AM
BlwnAway's Avatar
BlwnAway
Best I can hear, it does sound like Tappet Clatter.
As far as changing the rockers, you won't have to worry about Cam timing at all, you can simply pull the tensioner, which will take the pressure off the chain, with the pressure off the chain, the Cam will simply lay in place while you swap the rockers. Actually a pretty easy job.
Old Feb 15, 2020 | 09:14 AM
booyah93's Avatar
booyah93
Nice. Holy cow I did all that work for nothing.
Hey so RockAuto 🎸 🚗 has intake for $22/arm and exhaust for $30/arm
should I replace them all? Should I replace the cam? Is there a cheap solution?
Old Feb 15, 2020 | 09:27 AM
booyah93's Avatar
booyah93
Oh! There is an unusually high number of mini coopers at pick n pull near me (3), one is reported having 140,000 miles. Would those rockets be worth looking at?
Old Feb 15, 2020 | 09:59 AM
BlwnAway's Avatar
BlwnAway
Personally, with that many miles, even if they are ok, you're just setting yourself up to do the job again much sooner than later.
The RockAuto thing is up to you, I just replaced mine with aftermarket, couldn't see paying $800 ish for a set of OEM, but it's always a gamble, no matter whose you use.
Old Feb 15, 2020 | 12:38 PM
booyah93's Avatar
booyah93
I’m gonna check them out, so that I might learn for cheaper if this is the issue. With my tax return I’ll get a new cam shaft and rocker arms.
Thank you everyone for the input!!
They are $4.20 an arm, so I’ll hopefully find all eight I need. Hopefully the cold scared off the engine pickers.
action428
Jun 27, 2019 02:48 PM
Ken G.
Sep 24, 2014 12:23 AM
pedjag
Jun 22, 2010 08:18 AM
musiq021
30
Oct 25, 2007 12:29 PM
kraigster414
Jun 12, 2004 12:08 PM
