Drivetrain NGK (1422) ILKR8E6 Spark Plug????? Really Confused!!!
Old Oct 29, 2016 | 04:26 PM
LuvMyJCWCoupe's Avatar
LuvMyJCWCoupe
Hey all... I went a bought a set of 4 NGK (!422) ILKR8E6 spark plugs based on what Manic Tunes told me and from reading up here on the forum.
Everywhere I'm reading that I need a thin-wall 14mm 12 pt spark plug socket to do the swap but the NGK (1422) ILKR8E6 spark plugs ARE not 14mm they are 16mm... so now I'm really confused!
So here's the question... am I going to need the thin-wall 14mm, 12pt socket to remove the factory plugs and then get a thin wall 16mm socket to install these new NGK spark plugs??? I think I have to be missing something here or not following directions or something... Can someone whose done this maybe shed some light on what's going on?
Thank you so much... Alex
Old Oct 29, 2016 | 11:00 PM
oldbrokenwind's Avatar
oldbrokenwind
The two plugs take different size thin-wall sockets. 1422's are the correct replacement as manic recommends --- one heat range colder. You'll like the added performance.
Old Oct 30, 2016 | 05:53 PM
Denzien's Avatar
Denzien
Is this plug for a stock engine?
Old Oct 30, 2016 | 06:17 PM
yesti's Avatar
yesti
1422 is two steps colder than stock S engine and one step colder than JCW engine. it is for tuned cars (higher than JCW spec).
Old Oct 30, 2016 | 07:41 PM
oldbrokenwind
My '07 MCS came OEM with ILZKBR7A-8G aka stock # 5992. The heat range is designated as "7". Stock # 1442 or ILKR8E6 is heat range "8", or one range colder than my OEM. Can't comment on JCW --- I don't have one.
I've read that for every 75HP increase, one step colder heat range is recommended. However with a custom tune, regardless of HP increase, it's a good idea to follow your tuners suggestion.
Old Oct 31, 2016 | 02:28 AM
Club77's Avatar
Club77
Is those plug for N18 engine?
Old Oct 31, 2016 | 05:10 AM
cerenkov's Avatar
cerenkov
You will need the thin wall 14mm for the stock plugs and a regular 5/8 inch spark plug socket for the new plugs.
Note that some 5/8 spark plug sockets are thicker than others. If it does not fit easily then try a different one. A cheap Stanley from Walmart work for me.
Old Oct 31, 2016 | 06:17 PM
yesti's Avatar
yesti
My '12 S came with beru brand plugs heat range 6. Probably for emissions and/or mpg, useless with anything higher than stock output. I put in 'JCW' spec plugs (heat range 7) for my manic stage 2 tune and that solved the random misses and complete boost loss. I can run up to map B until I change to 1422 plugs which are heat range 8. Still got ~25k miles on the plugs assuming change interval of 30k.
Old Nov 5, 2016 | 07:09 AM
BigBoost's Avatar
BigBoost
Do not mean to thread jack' but i Currently put a manic stage 3 map C tune on the wife's car! 07 mcs' with all the proper mod's ' and I want with a stage colder then stock and it did not like it one bit! Any ideas should I try a 2 stage colder! Currently running stock spec plugs and no problem's !!
Old Nov 5, 2016 | 10:37 AM
cerenkov's Avatar
cerenkov
Can you be more specific about the car not liking the plugs.
And why not go with the plugs recommended by Manic?
Old Nov 5, 2016 | 11:05 AM
randeez's Avatar
randeez
Not trying to derail just hoping someone can confirm torque spec off top of their head ~10-14.5 ft lbs?
Replacing mine after about 40k miles on stage 2, still looked pretty good!
Old Nov 5, 2016 | 11:51 AM
yesti's Avatar
yesti
What did you gap them to? If the gap is too big you will have problems.
Old Nov 5, 2016 | 12:02 PM
cerenkov's Avatar
cerenkov
The Bentley manual has spark plug torque at 17 ft-lbs or 23 Nm.
FYI.m, a gap of 0.6 mm works really well.
Old Nov 5, 2016 | 12:34 PM
oldbrokenwind
My '07 MCS also ran fine with OEM plugs --- Stock #NGK5992. Even finer when re-gapped to about .020". They've been discontinued and replaced with Stock #NGK95770. Both of these plugs have the same gap spec --- 0.8mm (the last number in the part number, not the stock number). The stock #NGK1422, (part # ILKR8E6) wants a gap of 0.6mm.
I only switched to the 1422's on Manic's recommendation, but I did so BEFORE the Manic install. There was a noticeable improvement --- more so than just a new OEM plug. And this was while still pumping out 312 WHP!
And good luck finding a plug 2 ranges colder. I've read there is one, an NGK, but un-godly expensive and special order only --- used by some racing team. Take a week or two off and read thru this thread --- http://www.minitorque.com/forum/f272...47/#post447094 I'm pretty sure this is where I read about it. Maybe another brand has one? Be sure and verify all the specs are compatible if you find one.
Old Nov 6, 2016 | 09:28 AM
BigBoost's Avatar
BigBoost
When I order my tune from m7 I order the one stage colder ! And I was getting crazy detonation' so I swap it back sock and run's fine'
Old Nov 6, 2016 | 01:48 PM
yesti's Avatar
yesti
hi thanks for reporting but that doesn't make any sense. what model/heat range are your stock plugs and what model/heat range are the plugs that gave you problems? what gap did you run them both at.?
Old Nov 6, 2016 | 03:27 PM
cerenkov's Avatar
cerenkov
Were you getting detonation or misfires?
Old Oct 8, 2017 | 01:54 PM
Guitaradam2000's Avatar
Guitaradam2000
I'm also getting similar issues after changing to these plugs. It was running pretty smooth with the the stock NGK plugs from BMW, but after changing to these iridium plugs the idle is rough, engine noisey (not sure if its knocking or miss firing), looks to be spitting out unburned fuel from the exhaust. I'm running the stage 3 from Manic on performance mode C (95ron but I put in 98).
I put the stock ones back in and its back to running smoothly again. Not sure the issue. I left the gap on plugs as they were, 0.020" I believe.
Old Oct 8, 2017 | 02:56 PM
BigBoost's Avatar
BigBoost
Are you running meth ?
They way I fix it was running race fuel or meth !
Old Oct 8, 2017 | 03:26 PM
oldbrokenwind
Try setting the NGK1422, (part # ILKR8E6) plug gap to 0.6mm. I think your 0.020" is a little too tight.
Old Oct 8, 2017 | 03:33 PM
BigBoost's Avatar
BigBoost
Hmm’ idk if I would be gapping Those plugs’ bad idea’
Old Oct 8, 2017 | 03:36 PM
Guitaradam2000
The iridium's are not the easiest plugs to gap without damaging. I guess I'll give it a go. The guys at Jmtcperformance.com also recommend a wider gap. I didn't think it was going to make much a difference though.
In response to the other reply, I don't believe "running meth" is a prerequisite to using these plugs with the tune.
Old Oct 8, 2017 | 05:12 PM
BigBoost's Avatar
BigBoost
sounds like your a manic tune expert ! Best of luck
Old Oct 8, 2017 | 05:19 PM
MarioKart's Avatar
MarioKart
Vendor
No need to gap them, leave them at .6mm. Lowes sells the 12pt 14mm deep thin socket for $3.00
mQubed Motorsport, Manic/NM Tuning Dealer
Old Oct 8, 2017 | 05:52 PM
Guitaradam2000
I've got the tools to required and have already installed them, but pulled them out again due to the issues. If I leave the gap "as-is" I've not changed anything and the problem will persist.
Is running race fuel or methanol really the only solution that the others experienced in here? It seems a bit drastic
