Drivetrain NGK (1422) ILKR8E6 Spark Plug????? Really Confused!!!
Old Oct 8, 2017 | 10:29 PM
  #26
oldbrokenwind's Avatar
oldbrokenwind
Originally Posted by MarioKart
No need to gap them, leave them at .6mm. Lowes sells the 12pt 14mm deep thin socket for $3.00
mQubed Motorsport, Manic/NM Tuning Dealer
Sorry Mario, NGK1422's are 16mm (or ⅝") and are not 12 pt, altho a 12 pt will work.
Originally Posted by Guitaradam2000
I've got the tools to required and have already installed them, but pulled them out again due to the issues. If I leave the gap "as-is" I've not changed anything and the problem will persist.
Is running race fuel or methanol really the only solution that the others experienced in here? It seems a bit drastic
NGK spec sheet indicates the gap should be 0.6mm (0.024") --- pretty close to your 0.020" so they should function OK. But since all engines are different, yours just might not like the smaller gap. Since they're iridium, maybe use a feeler gauge for measurements --- much less stress on the electrode. As mentioned earlier, if you re-gap them, do so very carefully.
My 1422's perform nicely with 91 octane pump gas and an 80 - 20 WMI mix. Even nicer with a mix of 91 and 100 race fuel plus the same WMI mix. Even on map A there's no missing, rough idle, or any other issues.
Old Oct 8, 2017 | 10:55 PM
  #27
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by oldbrokenwind
Sorry Mario, NGK1422's are 16mm (or ⅝") and are not 12 pt, altho a 12 pt will work.issues.
I thought he was talking about the stock plugs.
mQubed Motorsport, Manic Tuning Dealer
Old Oct 9, 2017 | 12:16 AM
  #28
Guitaradam2000's Avatar
Guitaradam2000
Well, Arric from JMTC has replied to my email (got my super K03 turbo from him) and is assuring me that I need to increase the gap on these and it's the reason for my issues. He's been pretty spot on with my other issues so looks like I'll be getting the needle nose pliers out and damaging some plugs tonight!
Old Oct 14, 2017 | 06:00 PM
  #29
Guitaradam2000
Contrary to my better judgement and reluctance to gap the iridium plugs, I'm happy to confirm that a wider gap seems to have worked! For the record, I used the recommendations from JTMC (found here) and opened the gap to 0.026".
I'm using the Manic stage 3 tune on performance mode C with decent 98RON fuel.
Thanks to everyone that replied.
Old Nov 15, 2017 | 01:19 AM
  #30
Guitaradam2000
Ok, so actually don't use these spark plugs. The rough ideal returned,even after gapping them. I thought this may just be a trade-off of using the colder plugs so I just put up with it. But, on the dyno today I did a few power runs and blew the motor! A lot of fingers are pointing to the spark plugs now. Super Knock occurred
Old Nov 15, 2017 | 02:15 AM
  #31
jetsr6's Avatar
jetsr6
What are these spark plugs?
Old Nov 15, 2017 | 02:25 AM
  #32
jetsr6's Avatar
jetsr6
I’ve used the manic recommended 1422’s this summer and worked great with zero troubles. I think you had other problems.
Old Nov 15, 2017 | 03:14 AM
  #33
Guitaradam2000
Did you gap them? Or leave them as they were out of the box?
I could've had other problems, but until I put in those plugs everything was running smoothly. I had all the correct supporting mods, and running the correct fuel. Only other thing could've been a piston ring failure. Still investigating. It made 260bhp on the dyno run before it blew, which was quite impressive.
Old Nov 15, 2017 | 03:53 AM
  #34
jetsr6's Avatar
jetsr6
I didn’t gap them. I autocross the car and ride the rev limiter all the time. Oil samples came back clean too. Water/meth injection is a must for these. Keeps things clean and cool.
Old Nov 15, 2017 | 05:28 AM
  #35
cerenkov's Avatar
cerenkov
That’s sucks.
I’ve been using the plugs for 20,000 miles with no issues.
Old Nov 15, 2017 | 10:14 AM
  #36
oldbrokenwind
Don't judge the plugs 'til you do a tear-down and find all the damage. Last time mine blew, I found CYL #1 plug (1422) lost the ground electrode, but I also had zero compression while the other three were OK. On teardown, I found one of the #1 exhaust valves and its seat burnt. When it blew, I was on a power run and it was a hot day. Cylinder heat took out the plug electrode and a valve. My tuner suggested my WMI distribution needs to be improved --- to help cylinder cooling, so that's my current project --- adding WMI to each port, in addition to the usual jet placement up-stream from the MAP/T sensor. I also replaced all valves with inconel (Ex) and SS (In), to help withstand the heat my power runs create.
Let us know what you find?
Old Nov 15, 2017 | 07:42 PM
  #37
BigBoost's Avatar
BigBoost
Not supposed to gap radium plugs
Old Jul 9, 2019 | 11:19 AM
  #38
Richieb0y28's Avatar
Richieb0y28
Need some advice - I just replaced my plugs with the NGK (95770) ILZKBR7B8DG, basically direct replacement from factory.
I have a 2010 R56 JCW (N14 engine) running stage 2 with the accessport.
Should I be using NGK 1422s? Is there any noticeable difference?
Old Jul 9, 2019 | 12:44 PM
  #39
MarioKart's Avatar
MarioKart
Vendor
Try .028”. I have seen some Minis like a slightly larger gap. Also make sure the plugs are are solid don’t slide in and out
Mario
mQubed Motorsport Manic & RPM Power Tuning
Old Jul 9, 2019 | 01:11 PM
  #40
oldbrokenwind
Comparing performance with sets of new plugs of each type, you probably won't see any noticeable difference. Obviously, replacing a set of 95770's with 50K miles on them, with a set of new 1422's, will show noticeable improvements. I found the 1422's (one heat range colder) to have better reliability --- less breakage under high performance conditions.
Old Jul 9, 2019 | 01:47 PM
  #41
Richieb0y28
Oldbrokenwind - Thanks for the quick reply. I'll keep this in mind. I ordered a set of 1422s so I may try swapping them later this summer.
Old Jul 12, 2019 | 05:34 AM
  #42
knt's Avatar
knt
Also worth checking to see if you have genuine NGK plugs as lots of fakes are being sold.
Search "how to spot fake ngk spark plugs" just to be on the safer side.
Old Jul 12, 2019 | 05:55 AM
  #43
Richieb0y28
Thanks for the tip. Didn't even think about this. I already installed my factory replacement plugs that I got on Amazon. I'll have to check them.
Old Jul 12, 2019 | 11:36 AM
  #44
knt's Avatar
knt
Just out of interest, has anyone tried the alternative spark plug listed "NGK 91448 Double Iridium"?
Old Jul 13, 2019 | 02:59 PM
  #45
yesti's Avatar
yesti
If the accessport stage 2 is more aggressive in timing then you might notice a difference. I have stage 2 manic and the 95770 was not good enough, the car kept pulling timing which means pre ignition and/or detonation. After the 1422 I had no problems.
Old Apr 21, 2021 | 08:51 AM
  #46
MWMWMWM's Avatar
MWMWMWM
Reviving an old thread for more controversy.
I contacted m7 to find out what the 1 stage colder plug is so I could give them a try. My R56 N14 has Manic Stage 2, many m7 parts and well beyond support. They wouldn't give me the part number and told me to do my own research.
I had been confused with other threads I have read and wanted to cut to the chase. I contacted NGK directly and they told me........
Hello Kelley,
Thank you for contacting us! You can use NGK 97506 SILZKBR8D8S Laser Iridium Spark Plug: https://www.ngk.com/ngk-97506-silzkb...ium-spark-plug this is 1 step colder with similar specs of the ILZKBR7B-8DG.
Best Regards,
Murphy
I also contacted Mario as well as reading some other thread that OBW1 (slang for old broken wind FYI) had said to run the 1422 ILKR8E6. This thread points in that same direction.
I read other threads where tuners on the other side of the pond are running ILZKR8C-8G very expensive and only available on ebay from Europe. Guys on the thread sounded like track hawks.
Soooo. Technology may have changed with NGK as this is now 2021. I opted to go with the 1422 regardless and use it first. My car runs well with stock plugs but I wanted to test things and get to the optimum.
I will likely try the ones in the future that NGK suggested as I am doing my own research.
Just some food for thought.
​​​​​​​Kelley
Old Apr 21, 2021 | 09:30 AM
  #47
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I've been running the NGK 1422s since getting my Manic stage 2, and have never had spark issues. I change them out every spring to make sure the engine stays healthy. (cheap insurance) I'm now running a Prototype-R stage 2 tune, and still on the 1422 plugs.
Old Apr 21, 2021 | 11:37 AM
  #48
oldbrokenwind
Hello Kelley,
Best Regards,
Murphy
Kelley
This recommended plug from NGK has a similar part number to the OEM plug. Main difference appears to be the "Special Washer" --- different from the OEM plug and described by the "S" in the part number. The ILZ~ characters all have a specific meaning / description, and a couple of them seem to be "update revisions" or lot codes.
One advantage to this NGK 97506 (stock number, not part number) is it uses the same spark plug socket wrench size as the OEM (14mm, 12-pt). The NGK 1422 uses a different size (16mm, 6-pt).
I'm still learning how to navigate the NGK.com site. Finding the complete selection for our engines hasn't been easy, and I still don't have it, just the ones I need.
Old Apr 26, 2021 | 03:05 PM
  #49
Jimmy-R56s's Avatar
Jimmy-R56s
Any issue running these on a stock cooper s?(2013 N18) needing new plugs and will be going intercooler, down pipe and remap quite soon and was going to upgrade to these just now instead of buying twice.
Good idea or not?
cheers in advance
Old Apr 26, 2021 | 05:38 PM
  #50
to_aussie's Avatar
to_aussie
Wondering the same thing, except I already have the mods and waiting for a stage 2 RPM tune
