Drivetrain Reduce power steering Assist
Old Mar 20, 2016 | 08:34 AM
Jedc's Avatar
Jedc
Hey all,
I have a 2011 Cooper S (for 9 months now & love it).
Is there a way to reduce power assist ala Sport Mode withOUT changing engine?
It seems possible but.....
Thanks, Jed
Old Mar 28, 2016 | 05:19 PM
BigBoost's Avatar
BigBoost
what are you trying to do?
if you hold down the dsc down for 3sec it turn's ever thing off !! there be a light on the dash when you turn it all off,
Old Mar 29, 2016 | 04:34 AM
Jedc's Avatar
Jedc
Thanks--follow up
Thanks for reply.
I am hoping the stiffen the steering withOUT having to engage "Sport Mode". Thus more responsive handling while NOT changing engine.
--Jed
Old Mar 29, 2016 | 04:52 AM
cerenkov's Avatar
cerenkov
I'm wondering if this possible using NCS Expert. Maybe someone will chime in.
Old Mar 29, 2016 | 04:00 PM
gjxj's Avatar
gjxj
Originally Posted by Jedc
Thanks for reply.
--Jed
Just out of curiosity why would you not want the responsive throttle?
Old Mar 29, 2016 | 05:46 PM
cerenkov's Avatar
cerenkov
Not sure about the OP but for me, my Manic tune enables nearly everything the sport button does (lower coolant temps and throttle mapping, etc.) but I wish it always tightened up the steering. That way the sport button would only turn on and off the exhaust pop and gurgle.
Old Mar 30, 2016 | 12:59 PM
Jedc's Avatar
Jedc
What is "Manic" tuning.
I like the more responsive steering but I have plenty of throttle response. Adjusting the electric power steering should be doable. I have an older OBD-2 Bluetooth device but I should invest in newer one that I could use with some software/apps that might be able to do this, I.e. NCS.
Cheers, Jed
Old Mar 31, 2016 | 02:59 AM
robbo mcs's Avatar
robbo mcs
Probably because he prefers the more linear throttle response of the standard mode.
Sports mode does not make any more power, it just changes the throttle percentage relative to the pedal position.
I have a GP2 that is a dedicated rally car, and a JCW that is dedicated racecar. For both I prefer the non-sport mode, as it allows more careful modulation of throttle input in the midrange, to balance the car mid corner and feeding power on. In both modes full power is there is you push it to the floor!
Old Mar 31, 2016 | 03:03 AM
cerenkov's Avatar
cerenkov
Cheers, Jed
Manic should be able to alter the steering response. Manic by default changes the throttle mapping to always sport mode but you can ask them not to do this. I do prefer the linear throttle mapping myself.
Manic is a company that tunes the ECU for secondary generation MINIs with either the N14 or N18 engines. It is flashed over the OBD2 port. The are currently the only company that can flash the N18 ECU over the ODB2 port.
Typically there are 4 tunes that are loaded and you can switch between them on the fly. Each tune is slightly more aggressive than the next.
1. Stock tune
2. Map A
3. Map B
4 Map C
The tunes are what people call "canned" tunes but they are tailored to the modifications of your car. You have to go through a Manic dealer to get the tunes loaded. Typically the tune are $500-$600 plus $200 for the switch device.
See www.manicmini.com for a list/map of dealers.
The original Manic thread (there are many others):
https://www.northamericanmotoring.co...ally-here.html
Old Apr 6, 2016 | 01:16 PM
Jedc's Avatar
Jedc
I found this interesting link
http://www.autospeed.com/cms/article...ering&A=111532
They talk about this and show a simple solution.
Seems very promising.
Cheers, JedC
Old Apr 7, 2016 | 04:12 AM
cerenkov's Avatar
cerenkov
I'd be leery on doing something like that. There has to be a way to adjust it via software.
Old Apr 7, 2016 | 06:15 AM
BigBoost's Avatar
BigBoost
Call way mini works or Detroit Tuning see what they have to say
Old Apr 7, 2016 | 07:19 AM
cerenkov's Avatar
cerenkov
I just looked at NCS Expert and the EPS computer module is for the electro-mechanical power steering. There are some settings that can be adjusted, not sure what does what yet, but there is a sport setting.
I FUBAR'ed by NCS Expert installation when I upgraded to Windows 10, I plan on down-grading back to Windows 7 next week, since I only boot to windows to use NCS Expert.
When I do I'll report back.
Old Apr 7, 2016 | 08:33 AM
BigBoost's Avatar
BigBoost
Does the NCS work along with the manic tune ? Never really seen any thing about it !
Old Apr 7, 2016 | 11:56 AM
cerenkov's Avatar
cerenkov
NCS Expert is totally independent of the tune. Most people use if for mostly "trivial" changes such as one touch roll up windows and sunroof, disabling bulb out warnings, turning off the over estimation on the speedometer. Or retrofitting and enabling options that were not originally in the car, or are European options.
Old Apr 9, 2016 | 06:16 AM
cerenkov's Avatar
cerenkov
I reinstalled NCS Expert and read the EPS modules. Not sure what to change to always have the sport steering response. Ideas anyone?
VEHICLE_VARIANT_STANDARD
variant_standard_3
VEHICLE_VARIANT_SPORT
variant_sport_3
STEER_WHEEL_SPEED
nicht_aktiv
LW_OFFSET_CORRECTION
nicht_aktiv
MSA_MAX_CURRENT
wert_01
MEASURE_IDENT
nicht_aktiv
FACTOR_SERVO_STANDARD
wert_01
FACTOR_SERVO_SPORT
wert_01
MSA_SIGNAL
nicht_aktiv
MEMORY_DATA
eeprom
ACT_RET_ENABLE
aktiv
TS_DRIFT_CORRECTION
nicht_aktiv
UNDERVOLTAGE_RED
aktiv
ANGLE_FINDING_CLIP
nicht_aktiv
WHEEL_CIRCUMFERENCE
wert_01
SPORT_SWITCH
aktiv
TRQ_STEER_COMP
aktiv
STEERING_ANGLE_SIGNAL
aktiv
STEERING_ANGLE_REF
extern
Black-eyed-Purple-Mini S
Jul 21, 2016 06:35 PM
PDirector
Mar 8, 2016 08:53 AM
ColoCoug
Mar 8, 2016 06:11 AM
Mrdrmini
Mar 1, 2016 07:45 PM
stickboy2k
Feb 24, 2016 08:36 AM
