Drivetrain Oil Catch Can with JCW strut brace?
Old Feb 29, 2016 | 08:55 PM
nels415's Avatar
nels415
I'm thinking about getting a catch can, but have not seen any installs where owners also have a strut brace. Does anyone run one with their JCW strut brace? If so, which brand?
-nels
Old Mar 1, 2016 | 08:29 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I think you might be ok. If you look at post #8 HERE the individual is running a CC and a strut brace as the can sits further back by the intake.
OCC here - http://www.pelicanparts.com/catalog/...pg4.htm#item14
888.280.7799 | 6am - 5pm PST
Old Mar 1, 2016 | 11:02 AM
timski's Avatar
timski
Originally Posted by nels415
I'm thinking about getting a catch can, but have not seen any installs where owners also have a strut brace. Does anyone run one with their JCW strut brace? If so, which brand? -nels
Yeah you will be just fine.
Old Mar 1, 2016 | 11:03 AM
timski's Avatar
timski
No worries
Attached Thumbnails Oil Catch Can with JCW strut brace?-image-2650583232.jpg
Old Mar 1, 2016 | 05:06 PM
nels415's Avatar
nels415
catch can
Hi Timski,
Sorry I don't see in your pic where you have your catch can, is it located on the left side.
-nels
Old Mar 1, 2016 | 10:23 PM
timski's Avatar
timski
Hi Timski, Sorry I don't see in your pic where you have your catch can, is it located on the left side. -nels
Sorry. I know it's not the best pic. The only one I have on my phone. You really can't see it from the pic. Point is the catch can is lower than the M7 strut brace and located between the strut brace and the firewall. Plenty of room.
Old Mar 1, 2016 | 10:26 PM
timski's Avatar
timski
Oil Catch Can with JCW strut brace?-image-3850827046.jpg Here is a better view of where the catch can is before I installed the brace. The other pic is with the brace. Fits in just fine. You can see the black catch can right behind the valve cover. But keep in mind I have the DOS CAI. I removed the JCW air filter box so I have extra space but the M7 brace I have is the 2nd gen version which is curved more to fit the factory air box.
Old Mar 2, 2016 | 08:57 AM
nels415's Avatar
nels415
Sorry, still not the best pic. But you're right you no longer have the stock airbox, so I still don't have a good idea of how much clearance I might have. There are two points to mount but I think the only one that will work is the one on the right.
Sounds like the consensus is that it will fit, but would be tight and not much clearance. How do you empty the contents of the catch can? I haven't gotten that far yet with reading the instructions, can I unscrew the top and syphon out liquids/oil?
-nels
Old Mar 3, 2016 | 08:28 AM
PelicanParts.com
Vendor
For the M7 one's, all you do is simple twist the bottom fitting connected to the clear hose on the right below and it'll drain out.
If you look at the install instructions you'll also see a different mounting position for it. Look below.
Old Mar 17, 2016 | 05:50 PM
Jesus1980's Avatar
Jesus1980
-nels
dez
Feb 24, 2016 09:05 AM
eyan212
Feb 5, 2016 04:49 PM
Combat_Astronaut
Jan 24, 2016 07:28 PM
Racingguy04
Jan 19, 2016 11:53 AM
