Drivetrain Any sparks upgrade? F56
Old Feb 29, 2016 | 08:12 AM
fcolluberes's Avatar
fcolluberes
Any sparks upgrade for F56?
Old Feb 29, 2016 | 08:48 AM
anotherminiinthegarage's Avatar
Old Feb 29, 2016 | 10:59 AM
Spark plug upgrades I guess ?
Old Feb 29, 2016 | 06:42 PM
fcolluberes
yess
Old Mar 1, 2016 | 06:02 AM
Just the stock plugs 12120041666 for now.
Cooper S F56 fF55
https://www.ecstuning.com/Search/SiteSearch/12120041666/ES2770797/
Old Mar 1, 2016 | 06:26 AM
MarcoPolo's Avatar
MarcoPolo
there's really no need to upgrade...only replace if necessary...and the car is too new to replace them already. unless you managed to drive it 100k miles already.
Old Mar 1, 2016 | 07:55 AM
dcummer's Avatar
dcummer
Originally Posted by MarcoPolo
... unless you managed to drive it 100k miles already.
According to the manual in my '15 F55, "spark plugs every sixth oil service (approx 60,000 miles)." With 100k plug service intervals being the norm these days, I'm sure I'll forget to change these on time.
Old Mar 31, 2017 | 03:23 PM
Chazman's Avatar
Chazman
I had a bit hard time finding a thread discussing spark plug choices in this forum, and this is the closest one I could find.
Is NGK the Mini oem brand plugs for F56?
The above ECS link shows NGK in their photos and says the manufacturer part number is 12120041666KT1. But that doesn't sound like a typical NGK part number, at least not what I'm used to, or is it?
Has anyone removed their oem plugs from F56/B48 and knows what the stamping says on the outside of the plugs?
Old Apr 10, 2017 | 01:48 PM
johntotah94's Avatar
johntotah94
Turning up the boost on the F56 soon. Would like to readdress this question.
No one step colder options that anyone knows of?
All I know are the options from Burger Tuning.
http://www.burgertuning.com/N54_BMW_...t_adapter.html
Old Apr 11, 2017 | 03:30 AM
LormaD's Avatar
LormaD
Todays spark plugs....
Todays vehicles are built to have spark plugs that last as the number one priority. Yes, they are designed to perform to achieve fuel economy and performance. But, the number one objective is that they last and out perform the conventional spark plug (the copper based).
Scientifically, copper is a better conductor than platinum or other marketing exotic rare earth type plug.
The factors to weigh in on, is...
a) how easily is it to replace (my 2007 Lexus Hybrid SUV required 5.5 hours of shop labour, and approximately $200 in various gaskets to access and to put back everything). So you Want long lasting.
b) environmental... take the number of vehicles X the 1 spark plug changes per 12 -18 months, vs once every 5 - 6 years.
c) how much real seat of the pants performance are we actually making. A better spark, will lead to a lot of good things over a simply a good spark. But even if you can improve the spark, will you be actually worth the time, effort, and cost to achieve a 1hp gain?
d) i don't see the engine in an environment of 18+ (I have driven a 22 psi turbo charged vehicle, very streetable, at that performance level and the spark plugs were copper for that very reason) psi of boost to warrant the spark plug pressures, where every little bit of spark to achieve the right amount of timing and cylinder pressures to warrant performance over every other criteria.
Probably a good reason why BMW chose NGK plugs. They probably offer the most ideal all around plug for these engines.
Cheers,
Old Apr 11, 2017 | 08:41 AM
johntotah94
Yeah the Beru Plugs on my N18 R56 were crap. When tuning, plugs couldn't keep up. I had a bigger turbo with 23 pounds of boost. Had to swap with NGK plugs from an Evo X and it was flawless.
The F56's are NGK from factory? I will be tuning ~20psi on the F56. Concerned about what plugs they currently have and if it will hold up.
Thanks.
Old Apr 11, 2017 | 05:12 PM
DunkM's Avatar
DunkM
Okay, so this is all from the internet, so take it with a grain of salt, but...
My understanding is that BMW uses the same plugs for the F56 S and JCW. Also, BMW uses the same engine in a lot of different applications and at plenty of higher output levels than the F56 S. In terms of economics of scale, they'd be stupid to SPEC different spark plug designs for similar engines. It would be throwing money away.
Second, not once has anyone hitting the 300 lb-ft of torque mark (or even higher) mentioned changing plugs. The world where that made a difference should have disappeared by now because BMW is now controlling everything.
Finally, BMW has not in the history of my interest in BMW, so back to the 80s, specced anything other than highly known brands, first being Bosch, and then NKG when they became well known.
If I were you, I would spend money on other things.
Old Apr 11, 2017 | 06:16 PM
vetsvette's Avatar
vetsvette
Moderator
When I was going with the Manic stage 2 tune on my R56 it required one step colder plugs. I'm waiting for their B46 tune to find out if it's also required on the F car.
Old Apr 11, 2017 | 06:42 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
First off, comparing what was going on with the Prince Engines for an F engine is apples and oranges.
Stick with stock, just get an exhaust and tune, and create an annual budget for tires.
These new MINI's are very much like modding a Subaru WRX STi. Unlock the DME and free up the breathing is all that's needed.
Old Apr 12, 2017 | 05:28 AM
Bytetronik's Avatar
Bytetronik
Thanks.
~20psi on the Cooper-S might be a little too aggressive for those high-compression pistons...
At 18psi, we are already making 298 BHP / 349 Engine Torque (~306 Wheel Torque) and the stock clutch is barely holding on... at 20psi, your stock clutch will go for sure
Old Apr 12, 2017 | 09:37 AM
Clutch Wotan's Avatar
Clutch Wotan
as said stick with stock ! Nothing comes close to NGK !
Iam sure a NGK dealer can recross very easy the equivalent NGK part nos, he can also assist you to choose upgraded "racing plugs" which are up 10x more expensive.
Used them for gokart 1 plug 50 Bugs, worth every dime, you could go so slow in formation lap that halve of the field stalled, and you could use them "forever"
NGK Racing<br/>
Old Apr 12, 2017 | 01:42 PM
johntotah94
So stock F56 Plugs are made by NGK?
Also, I believe Manic and Evolve Automotive tune at 21psi.
Old Apr 12, 2017 | 02:18 PM
Chazman's Avatar
Chazman
Nope.
I called NGK U.S.A. and their rep told me I have to go buy from a Mini dealer.
Old Apr 12, 2017 | 02:20 PM
Chazman's Avatar
Chazman
I thought so because I saw NGK name on the plugs that ECS Tuning is selling.
But maybe not because NGK U.S.A. couldn't or didn't tell me what their part number.
Old Apr 12, 2017 | 02:23 PM
Chazman's Avatar
Chazman
Wonder why this thread got moved to a Modificaton/Drivetrain section.
I didn't know something as simple as replacing spark plugs are considered modifying & belonged to Drivetrain?
Old Apr 12, 2017 | 11:01 PM
Clutch Wotan
Originally Posted by Chazman
Nope.
NGK - Part No. SILZKGR8B8S
https://www.ngk.de/fileadmin/Dokumen...release_03.pdf
Old Apr 13, 2017 | 03:43 AM
LormaD's Avatar
LormaD
really?...
Come on, Really ?!?!?!?!?
I am not even going to ask what kind of vendor you are...
Stop spreading false facts, based on gut feeling and opinions.
Sorry... just saying.
Old Apr 13, 2017 | 05:12 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
because people are looking for colder plugs so they can up the boost without missfires? that is modifying
Old Apr 13, 2017 | 04:53 PM
Bytetronik's Avatar
Bytetronik
Just out of curiosity, do you happen to know the stock boost from a F56 S?
Old Apr 13, 2017 | 05:04 PM
Bytetronik's Avatar
Bytetronik
Don't take our words, what do we know, we just do dyno tuning on Gen1 and Gen2 and Gen 3 MINI (and BMWs)
Here's a link to our dyno numbers on 18psi (Cooper-S) and 19psi (JCW Auto). See post #12, #14 & #15.
https://www.northamericanmotoring.co...no-thread.html
Originally Posted by devilmotorsports
I've heard the clutch in the 3rd gens is weaker than in previous models, when I had mine done my tuner warned me of this as well and pointed out that he was getting clutch slip in 2nd. Knowing all this I've been very careful since I've gotten my tune not to full on floor it.
Looks like other MINI owners are experiencing the same thing on their tuned F56s..
I see. But the clutch does slip in 2nd when he was tuning it?
Will be tuning it soon. So maybe I should target 19-20psi..
Yeah. I'm pretty sure I've had it slip while I was driving as well.
We felt the clutch sipping while dyno on 3rd gear at WOT on the Mustang Dyno.
OP: We are also looking for colder plugs for the F56. Also working with 1320MINI on an valve train upgrade as well.
All the the above opinion are provided based on our testing on various F56 models; none are based on guts. Take it for what's worth; it's a free country
