Drivetrain Official 3rd Gen Dyno Thread
Old Mar 8, 2017 | 11:18 AM
MarcoPolo's Avatar
MarcoPolo
Seems that lately more and more people are getting down and dirty with their mini, power-wise. A few mentioned the idea of an official "dyno thread". Decided to start one up. While i would normally have placed this in the F56 forum, i didn't want to avoid F54/F55/F57 guys from posting up, since really, it's the same engine.
I welcome everyone to share their dyno graphs as they progress with their car. This thread should give people the opportunity to see what works (exhaust/intake/tune/downpipe/etc...) vs what doesn't (stickers). It'll also give everyone a chance to educate themselves when looking to purchase something. You should include the following in your post:
- Vehicle (Year, Make, Model)
- Modifications
- Type of Dyno
- Gear Used
- Description of Graph
- results (in case unreadable)
followed by a picture of your graph.
Feel free to add any notes regarding your post (technical difficulties, errors in dyno, future plans, etc).
Old Mar 8, 2017 | 11:31 AM
MarcoPolo's Avatar
MarcoPolo
- 2014 Cooper S (2Dr Hatch)
- Mario Downpipe, AWE Intake, AWE Touring Exhaust, ACI Dynamix Custom Dyno Tune
- Mustang AWD Dyno
- 4th Gear
- Power/Torque Graph with AFR
- Before: 176WHP / 210TQ (all mods minus tune)
- After: 206WHP / 268TQ (after tune)
- Gains: 30WHP / 58TQ
Notes: my AFR's were starting off high and dropping down to 12.6. After the tune, they were able to get me down to the mid-11's. the low-end torque feels very good. i also have a JB4 but currently disconnected while i decide whether i want to do a stacking tune or just sell it.
Old Mar 8, 2017 | 05:22 PM
BadakVT's Avatar
BadakVT
- 2014 Mini Cooper S (Euro)
- Mods: JB4, All else stock
- Type of Dyno: Mainline Dynolog
- Gear Used: 4
- Fuel: RON95/AKI91
- Ambient Temp: 35C/95F High Humidity
- Stock baseline vs Map1 JB4
- Gains: 23WHP & 19 ft.lb
- Note: Dynolog and Mustang reads 10%-15% lower than Dynojet. Will post Baseline VS. Map1 VS. Map2 next.
Old Mar 10, 2017 | 02:02 PM
leozip's Avatar
leozip
Good thread!!! Here's my old dyno graph. Will take to dyno again for some fine tuning. Hopefully get close to the 300hp mark.
2014 Mini Cooper S (Brasil)
- Mods: JB4, K&N Inbox, Full 3" catless exhaust
- Type of Dyno: Dynotech 720i
- Gear Used: 4
- Fuel: RON95
by https://www.flickr.com/photos/2jml/, on Flickr
Old Mar 10, 2017 | 05:45 PM
MarcoPolo's Avatar
MarcoPolo
- Gear Used: 4
- Fuel: RON95
great numbers! happen to have a before dyno before all the work?
Old Mar 11, 2017 | 12:25 PM
leozip's Avatar
leozip
Don't have stock dyno here but it was around 178whp. Right within specs from factory.
Putting flex wires on Tuesday and taking to dyno for fine tuning. Bear in mind our Brazilian Podium gas has 95 octane along with 25% Ethanol on gas. So should be around 105-110 octane. That helps a little for higher output.
Old Mar 11, 2017 | 12:57 PM
cerenkov's Avatar
cerenkov
What octane rating system do they use in Brazil? Is it MON, RON or AKI? The US uses AKI which is the average of MON and RON.
Also rating of 95 octane with 25% ethanol is still 95 octane (of which ever rating system that is being used).
Old Mar 11, 2017 | 03:13 PM
leozip's Avatar
leozip
Originally Posted by cerenkov
what octane rating system do they use in brazil? Is it mon, ron or aki? The us uses aki which is the average of mon and ron.
95 aki
Old Mar 11, 2017 | 03:21 PM
cerenkov's Avatar
cerenkov
Petrobras Podium is 95 AKI which is 102 RON.
You have the good stuff down there.
Old Mar 11, 2017 | 03:25 PM
leozip's Avatar
leozip
That is equivalent a what octane in US?
Old Mar 11, 2017 | 03:30 PM
cerenkov's Avatar
cerenkov
that is equivalent a what octane in us?
95
Old Mar 11, 2017 | 11:16 PM
Bytetronik's Avatar
Bytetronik
Bytetronik's Stage 1 Flash (+45 WHP; +78 WTQE) w/ OEM JCW Parts
This is the dyno gragh from the JCW (w/ Auto tranny). We ran this JCW on the Mustang Dyno in AWD mode b/c we didn't want to put the car into "dyno mode".
Modifications:
  • 2015 Factory JCW Auto
  • Factory resonator removed.
  • 2 gallons of E85 mixed with a full tank of 91 Octane;
  • Bytetronik (BT) Stage 1 Flash;
  • Everything else stock
Power Output to the wheels (Not BHP!):
OEM Stock: 231 WHP / 248 WTQE
BT Stage-1 Flash: 276 WHP / 326 WTQE (~442NM)
Gains: +45 WHP; +78 WTQE
Dyno pulls were all done on the same day within 30 minutes of one another. Outside temperature was about 80-degrees Fahrenheit.
Parameters Adjusted:
  • Raised Speed limiter (VMAX)
  • Fuel Pressure raised
  • Target Lambda optimized
  • Clutch torque optimized
  • Optimum torque optimized
  • Torque monitors optimized
  • Schubblurbben (burble) parameters optimized for more bangs and pop
  • Race start (launch control) start temperature modified
  • Boost target optimized
  • Target torque optimized
F56 JCW Auto w/ Bytetronik Stage 1 Tune (gained +45WHP & +78 WTQE)
Old Mar 22, 2017 | 06:26 PM
johntotah94's Avatar
johntotah94
- 2016 MINI Cooper S Hatchback
- S&N Motorsport 3in Intake System, S&N Motorsport Full Turboback System
- Dynojet
- 5th Gear
- Top end curves are nice and flat with the modifications compared to the factory setup.
First Run:
With NM Intake and Muffler Delete
Second Run:
No tuning done yet. Factory Map.
Old Apr 9, 2017 | 04:58 AM
Bytetronik's Avatar
Bytetronik
2015 S-Manual; 298 HP / 473 NM (349 Torque); 18 PSI
2015 Manual S with Bytetronik Stage 1 Flash for the Euro-spec F56 "S".
- 2015 "S" F56 Manual (UK Model)
- 1320MINI Shop MINI
- JCW Exhaust
- Airtec IC
- 4th Gear Run
- 18 PSI
- 298 BHP ~260 WHP
- 473 NM ~349 Engine Torque
F56 Cooper-S manual, Bytetronik Stage 1 Tune
Old Apr 11, 2017 | 04:28 PM
Bytetronik's Avatar
Bytetronik
1320MINI Bytetronik Tuned Stage 1
- JCW Exhaust
- Airtec IC
- 4th Gear Run
- 18 PSI
- 298 BHP ~260 WHP (on Lohen's Dyno)
- 473 NM ~349 Engine Torque (on Lohen's Dyno)
This is the same F56 with the Before and After from the 1320MINI's Mustang Dyno:
Stock: 204 WHP / 228 WTQE
Tuned: 261 WHP / 306 WTQE (BT Stage 1 Flash)
Gains: +57 WHP/ +78 WTQE
Old May 7, 2017 | 03:02 AM
sootyvrs's Avatar
sootyvrs
- Mini F56 Cooper S 2015
- JCW Tuning kit (exhaust flap open), JB4, 99RON pump fuel (UK) and everything else standard (drive train)
- Dyno Developments
- Gear Used ?
- Lowest line std. with JCW Tuning Kit, Middle JB4 map1, Upper JB4 map2
- Flywheel power figures - std. JCW Tuning Kit 227 hp, map1 261 hp, map2 285 hp
Old Sep 13, 2017 | 12:32 PM
johntotah94
- Dynojet
- 5th Gear
First Run:
Second Run:
As there are many differences between dyno's, humidity, temperature, altitude, etc.... It is important to look at solely delta numbers.
Here are a few different dynos I have done on my F56.
2016 MINI Cooper S Hatchback (F56)
Run 1
Mods:
NM Engineering Intake
Muffler delete
JB4 on stock map (pass through)
Power: 202whp 270wtq
Run 2
Mods:
Full Custom 3in Intake System
Full Custom 4in to 3in Turboback Exhaust System
No JB4 (removed), Factory Map
Power: 219whp 295wtq
Run 3
Mods:
One Step Colder Spark Plugs OEM BMW
Bytetronik Custom Tuning
2gal E85 Mix w/ 91
Power: 276whp 373wtq
All the runs are on the latest DynoJet Dyno purchased in 2016 from DynoJet.
No corrections made.
Old Sep 13, 2017 | 12:35 PM
trentiles's Avatar
trentiles
hot damn that torque. hope you have some sticky tires and a new clutch on order!
max HP is at a slightly strange part of the RPM band.
Old Sep 17, 2017 | 06:40 PM
mattkosem's Avatar
mattkosem
Run 1
Mods:
Muffler delete
Run 2
Mods:
Run 3
Mods:
2gal E85 Mix w/ 91
https://www.youtube.com/watch?v=vwBX9ZXAJM8
Good lord that torque! Which clutch are you running and how do you like it?
--Matt
Old Sep 17, 2017 | 07:31 PM
Bytetronik's Avatar
Bytetronik
--Matt
Car is still on the OEM clutch.
Old Sep 26, 2017 | 07:50 PM
mattkosem's Avatar
mattkosem
Wow, no slip?
Old Sep 27, 2017 | 01:15 AM
johntotah94
Wow, no slip?
On a very cold night. It will slightly start to slip. I can tell by hearing it but the RPM's barely reflect it. Looking at performance clutches and doesn't seem to be anything in the market really.
Old Sep 29, 2017 | 09:45 PM
mattkosem's Avatar
mattkosem
I was afraid of that. All I see is kits from brands I've never heard of that no one seems to have.
--Matt
Old Oct 5, 2017 | 11:06 AM
J_L's Avatar
J_L
To anyone posting their charts- how much boost are you making? Wondering where that dangerous edge is...
Old Oct 23, 2017 | 08:54 PM
Bytetronik's Avatar
Bytetronik
Wow, no slip?
Just for the record, we think the Torque reading on this DynoJet is reading a little bit off. As much as we would like to claim the 373WTQE since it's our tune, our map is only targeting around 400NM (or roughly 295 to 300 ft-lb of torque). The "delta" in HP and Torque are in line with our testing results.
Stage-1 Gains: +45 to +57 WHP / +60 to +78 WTQE
