Drivetrain Way motor works cams
Old Dec 22, 2015 | 09:23 PM
audio131's Avatar
audio131
Does anyone know the specs for the way motor works street cam and race cam .also how much of a difference is the street cam to the stock cam???
Old Dec 27, 2015 | 04:52 PM
audio131's Avatar
audio131
Lift @tdc on the way motor works street cam??duration?
Old Dec 30, 2015 | 05:29 AM
Saltysalt's Avatar
Saltysalt
i inquired about the cams earlier this year and plan on getting the race cam this spring, although it may come sooner than that! but I talked to way about them, and here is his response.
yes we came with these cams cause crower are all regrinds which doesn't allow any extra lift. And lift is what these cars need to get more in the cylinder. ours are machined from brand new blanks. Other brands we tried had too much variation in manufacturing and were made of crappy metal which would pit and fail.
The mild cam is great for a street car with no idle issues but nice gains.
The race cam is a little lumpy at idle, and really needs the idle bumped to make it run well at idle due to the lobe seperation. The race has like .1 more valve lift but more advance and lobe sep. which gives it more torque on the low and mid range. So you pretty much need some tune tweaks like you have the ability there to do to run the race cam.
WAY
I didn't get the specs, honestly I don't know enough to tell how one set of spec defers to another in gains other than lift.
mild cam: drop in
race cam: more lift, needs tune
Old Dec 31, 2015 | 06:14 AM
audio131's Avatar
audio131
Hi. I ran into the same situation. Weird no specs
Old Jan 5, 2016 | 06:32 PM
audio131's Avatar
audio131
way motors street cam r53
Any other info? Anyone using one? Any one ever found specs on it??
Old Jan 6, 2016 | 04:55 AM
bavmotors's Avatar
bavmotors
call way and ask, that's your best best
Old Jan 6, 2016 | 08:52 AM
audio131's Avatar
audio131
I did. Not much info told. ..not much info here.. so im gonna assume im the only guy that will have one ? Figured there would be a bunch of people with it or heard of it since theres only about 3 other cam brands out there..
Old Jan 6, 2016 | 10:31 AM
Saltysalt's Avatar
Saltysalt
he hasn't had them for that long, when I was looking last year spring time, they were not available
Old Jan 9, 2016 | 05:50 AM
audio131's Avatar
audio131
So far what i see is the lift is only about .5 mm bigger.but the duration or thinkness of the peak is wider.so the valves may stay open longer.
Old Jan 13, 2016 | 08:43 PM
MiniLife's Avatar
MiniLife
Im interested in a Mild cam....would love to hear more info
Old Jan 13, 2016 | 11:27 PM
audio131's Avatar
audio131
Drove mini today for first time with cam. Def pulling harder.
Old Jan 14, 2016 | 01:16 AM
bavmotors's Avatar
bavmotors
any downsides?
Old Jan 14, 2016 | 06:25 AM
Saltysalt's Avatar
Saltysalt
yeah I plan on getting the race cam in the spring, no need to have it right now, since I don't have a garage to throw a new cam in. I also would need a tune for the race cam, which I also don't want to be changing my injectors right now as well haha.
im glad the mild cam is working out for you right now, notice a difference in the idle? that mid range to top end should have definently opened up a bit
Old Feb 4, 2016 | 02:22 PM
Rixon1's Avatar
Rixon1
Any updates or any more info on the Way mild street cam? I just ordered one, but now am having second thoughts on not getting the race cam. I have 380s btw.
Old Feb 4, 2016 | 03:32 PM
audio131's Avatar
audio131
Exhaust is a lot louder..not much engine idle difference but can hear it a little in the exhaust.power is a lot better.it pull from aout 2500 4500 rpm. Once i get my ecu backnfrom way motors ill let you know then..id say for street use its great.can only go so fast on street and just want speed thru first 3 gears.which this cam keeps torque in low end.
Old Feb 14, 2016 | 12:01 AM
davisflyer's Avatar
davisflyer
Go with an RMW street cam. Near stock idle, nice mid-range and up pull.
Old Feb 24, 2016 | 11:14 AM
Thumper460's Avatar
Thumper460
WAY
mild cam: drop in
Actually this in not correct with the Crower cams.. !! We have Lift numbers as high a .455" on a 're-grind' !!
There is an issue with the Exhaust lobe hitting the spark plug tube ( IE: Schrick has 8.9mm lift and tube needs tube dinged) Intake lift, there isn't an issue, with interference.
ALL the camshafts will under cut the stock base circle in order to make aggressive lift and duration numbers and still FIT the HEAD!! Under-cutting the base circle will remove 'some' of the pre-load on the lifter. IF too much pre-load is removed, that pre-load and be added by using a Lash Cap. ( only if you get that aggressive. 8000 rpm operating range)
The Crower Cams are cut on the high quality core used by BMW for their applications.. go wonder !!
Crower Cam drop in and rock.
Thumper
racemini
Feb 26, 2016 01:53 AM
arsci
Jan 7, 2016 08:45 AM
PelicanParts.com
Dec 22, 2015 09:10 AM
tesibori
Tires, Wheels, & Brakes
Dec 18, 2015 09:15 PM
GAT
Dec 17, 2015 04:00 PM
