Drivetrain Removing Original Exhaust Tips
Old Dec 12, 2015 | 08:24 AM
bugeye1031's Avatar
bugeye1031
Moderator
Just received my ECS Tuning tips and am trying to remove the originals from my 09 Clubman....been on there a long time. Removed the allen bolts, but they are rusted on. Have tried PB Blaster (shooting from the front to back within the two walls, and letting it soak), and an old style oil filter wrench, and tapping on them with a hammer, but no go. I don't think that heating them would do much good because of the double wall construction. I hate to cut them off.
Anybody have any suggestions?
Old Dec 14, 2015 | 12:51 PM
Its the rusted allen screw that stuck on. And then the inner way sticks, grab it with a wrench and do the thist back and forth. Drive it around and let it heat up a bit, then twist it again. Should be able to walk it off back and forth.
Thanks for the order the the ECS Tuning tips are universal and 2.5" on the inner , the stock cooper S inner is about little under 50mm wide. So u will have to set it up little over 1/2 inch.
Old Dec 19, 2015 | 08:41 AM
nkfry's Avatar
nkfry
If you have no care for the original tips it sounds like you didn't use a large enough hammer.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 21, 2015 | 11:56 AM
any update ?
Old Dec 27, 2015 | 02:09 PM
bugeye1031's Avatar
bugeye1031
Moderator
thanks for the replies. Allen screw comes out very easily. the inner piece is pretty solidly rusted on to the pipe...probably due to the road salt they use around here. I've tried a hammer with a piece of wood, and have tried to pliers approach. No go so far....still trying to avoid damaging them. Intend to try a bigger hammer with a piece of 2x4 to try to walk it off.
Old Dec 28, 2015 | 05:51 AM
Thanks, try to walk it off. Sometimes that just whats needed.
Old Aug 19, 2016 | 08:54 AM
bugeye1031's Avatar
bugeye1031
Moderator
update-
pulled the exhaust system off and used a medium sized dead blow hammer to beat them off. It took many heavy blows to break them free due to the rust. There is no way that could have gotten them off while on the car....maybe if I had a lift, but even then it would have been tough.
Old Aug 23, 2016 | 07:05 AM
Thanks for the update. Sounds like the northeast winters did a number on them.
Old May 4, 2017 | 11:49 AM
tonmilv's Avatar
tonmilv
Do you know if this is the same case for Countryman 2016 S All4? I want to change exhaust tip but I not sure if my car could be removed.
Old May 9, 2017 | 08:29 AM
I would give it a try we had a guy on here install them on his countryman and they worked. ECS Swivel exhaust tip :
https://www.ecstuning.com/News/ECS_Tuning_Exhaust_Swivel_Tip_18863/
https://www.northamericanmotoring.co...-today-96.html
Yes you can remove the Cooper , Cooper S, exhaust tips the same way. The JCW exhaust are Countrymen are in the bumper and float
https://www.northamericanmotoring.co...aust-tips.html
Lex2008
Aug 9, 2024 12:54 PM
Tires, Wheels & Brakes
Dec 29, 2019 12:07 AM
aviaator
Nov 26, 2015 06:47 AM
Nov 20, 2015 02:33 PM
Nov 17, 2015 07:42 AM
