Drivetrain Just got the manic tune, what's next?
Old Apr 18, 2015 | 12:54 PM
JMC1's Avatar
JMC1
I have a bone stock 2010 N14 R57. I got the manic stage 1 last night, super happy with it. So now I'm thinking about what's next. Should I get rid of the second cat,get a new intake or start saving for an intercooler?
Old Apr 18, 2015 | 01:36 PM
Ovrclck's Avatar
Ovrclck
Second cat and intercooler. If anything, intercooler to start with.
Old Apr 19, 2015 | 10:07 AM
johnso56's Avatar
johnso56
But is it true that if u add any mod to your tuned car, u need to send the car back to remap it, so that the remap can take advantage of ur mods?
Old Apr 19, 2015 | 10:16 AM
johntotah94's Avatar
johntotah94
downpipe, intercooler. Is the most important.
Then you can do a Stage 2 tune
Old Apr 19, 2015 | 10:38 AM
Joeygonz's Avatar
Joeygonz
Doesn't a stage 2 require a CAI too? And $50 more for the tune?
Old Apr 19, 2015 | 05:08 PM
JMC1's Avatar
JMC1
I hope not..
Old Apr 19, 2015 | 07:43 PM
johnso56's Avatar
johnso56
that's what I heard from my local manic mini dealer, he said having your mini tune should be your very last thing to do
Old Apr 19, 2015 | 08:54 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Maybe drive it for more than a day before lusting for more? Is that even possible with you Manic tuned folks?
Old Apr 19, 2015 | 11:55 PM
velvetcows's Avatar
velvetcows
To fully "take advantage" of a mod, a tune is required. Exhaust, intake, and intercooler can be done one at a time,
then get a tune once all three are done.
Old Apr 20, 2015 | 05:02 AM
JMC1's Avatar
JMC1
I guess it's no big thing, I'll just go with an intercooler and a downpipe. Because my tune would now be obsolete I'll be forced to get the stage 2.
Is that how it works, or would I need to have the stage 1 done over, then a 2?
Old Apr 20, 2015 | 05:43 AM
countrymanman's Avatar
countrymanman
Not entirely true. What is true is that in order to get the most out of any mod, you will need to tune for it. This does not mean he can't work on stage two supporting mods while running stage 1.
Old Apr 20, 2015 | 05:44 AM
countrymanman
Drive a car with a manic tune and you tell me...
Old Apr 20, 2015 | 09:50 AM
johntotah94
You don't need to do any tuning done unless you choose to. Tuning is just to get the most power out of your mods. I had an intake, exhaust, downpipe, and intercooler done with absolutely no tuning. Drove on it for about a year until I got a stage 2 tune. No need to update your tune unless you want to squeeze the most power out. I am on stage 3 and I occasionally run my stock map for kicks. Doesn't hurt the car at all.
Old Apr 20, 2015 | 10:19 AM
JMC1's Avatar
JMC1
I like the downpipe and IC being my next mods. Problem is I'm scared of the downpipe. I have no wish for a loud car. I was thinking I'd get rid of the second cat and that would be about as much noise as I could handle, that and I could get it done without spending too much.
What would be better, downpipe and keep the second cat or get rid of the cat and skip the downpipe. I'd love to do them both but the noise is a BIG concern.
Old Apr 20, 2015 | 10:21 AM
johntotah94
You can do a high flow catted downpipe and delete the second cat.
Old Apr 20, 2015 | 12:16 PM
JMC1's Avatar
JMC1
Can anyone recommend a catted downpipe that won't brake the bank.
Also, how much power am I giving away going this route?
Old Apr 22, 2015 | 12:51 PM
johntotah94
I think CNT has a catless downpipe with a resonator on it. I've never tried it though.
Old Apr 26, 2015 | 12:02 AM
Systemlord's Avatar
Systemlord
Any reason why you don't just want a downpipe? A non-catted downpipe would be better than a catted downpipe, turbos don't like any type of restriction which adds to the heat collected at the turbo/downpipe. Get that heat away from the turbo/engine, cats cause heat soak that heats up you turbo/engine! Here's what you ask about, Evolve Sport Cat is a 200 Cel ($687), gives better flow than the stock 400 Cel cat. Don't know about the increase in HP and torque but I will tell you you'll get quicker spool. Keep you resonator though and delete your second cat.
Old Apr 26, 2015 | 04:56 AM
cerenkov's Avatar
cerenkov
He stated that noise was a concern with the catless DP.
For JMC1:
I've tried both. I really wanted to like the non-catted dp but it was much too loud for me. I was hesitant to go wide open throttle because of the noise. So I installed the 100 cel dp from Akrapovic (you can find used ones on the Marketplace). The noise is still louder than stock but FWIW I did have a 70 year old co-worker who drives a Nissan Leaf tell me that my car sounds fantastic when he was driving behind me one day. I've actually never heard my car from the outside.
Old Apr 27, 2015 | 05:45 AM
JMC1's Avatar
JMC1
I’ve heard I may have trouble passing emissions test going with a catted DP and second cat delete.
Thoughts?
Old Apr 27, 2015 | 07:00 AM
Grizld700's Avatar
Grizld700
Thoughts?
Don't worry about 2nd Cat as its not monitored and has no effect up stream. However, you will not pass emissions with a catless DP. Even with a high flow cat you may fail an emmision test. It all depends on what kind of test Texas does. If its just a OBDII scan test, a proper tune should let you pass that. However, if they go further (like CA does) and do what they call a "sniffer" test, you will fail with anything other than an OEM Cat. (or equivalent replacement).
So if you decide to go with any higher flow cat. be aware of that. You can swap the cats out for testing and back again after, but most people don't want that hassel. Me, I wouldn't care, I can swap them out pretty quick now as I've done it 3 times now. (in, out, in).
Old Apr 27, 2015 | 07:32 AM
JMC1's Avatar
JMC1
That does not sound like a good time for me. I'm heading over to a muffler shop at lunch to have the 2ed cat and resonator removed.
I need to think about what I want to do about a DP..
Old Apr 27, 2015 | 12:06 PM
Systemlord's Avatar
Systemlord
Thoughts?
Install both your catts and have the smog test, go home and re-install your cattless downpipe and remove your second catt. That's the only way, hoped you didn't throw away any of your stock catts!
Old Apr 27, 2015 | 03:24 PM
cerenkov's Avatar
cerenkov
The second cat is not needed for sniffer tests in mosts states. It is there to help with fleet emissions. Depending on the state, some people here have passed a sniffer test with a high flow cat DP. A tune can bypass around the OBD2 port tests.
As report by fellow members the Manic tune will pass the OBD2 portion in Texas for people running a catless DP, do they do a sniffer test there?
Before you do buy anything, verify with a fellow member in your state.
Old Apr 30, 2015 | 06:28 PM
poolguyinaz's Avatar
poolguyinaz
you can do the first stage tune with just intake and exhaust, stage 2 you need the DP, here in AZ we don't have any issue with smog, stage 2+ you need the FMIC and stage 3 you need bigger turbo and then water meth.
Colt45Magnus
Aug 27, 2024 05:03 AM
M7Speed
Sep 2, 2015 01:04 PM
Sep 2, 2015 12:57 PM
atlas8000
Aug 14, 2015 07:45 AM
