Drivetrain Diverter Issue?? Boost leak...
Old Dec 17, 2014 | 11:30 PM
johntotah94's Avatar
johntotah94
Little Background. I have a Stage 3 Mini running a JMTC E45R K04 Turbo. It came with an upgraded diverter valve already installed on the turbo. So it literally was a direct swap when I swapped my turbo. Been on stage 3 for a while now running around 22psi. Today I was doing a real nice powerful pull peaking at 22psi then all of a sudden my boost pressure dropped to 8-9psi. I am doing more pulls and my peak boost now is 10.5psi. I've checked my hoses and they are fully connected. The system is still able to do 10.5psi so I don't think it can be an issue with the connections of the hoses. The second it happened I instantly felt like it was a diverter valve failure. No check engine lights, just a significant drop in boost pressure. What do you guys think?
Thanks!
Old Dec 18, 2014 | 03:07 AM
cerenkov's Avatar
cerenkov
Good place to start. Also could be leaking around the meth jet. Someone else had a issue like you describe and that was the problem.
Old Dec 18, 2014 | 09:43 AM
johntotah94
Good idea. Will check there. What did he do to fix this problem? Used sealant of some sort?
Also anyone running an upgraded DV on an N18?
Old Dec 18, 2014 | 09:58 AM
cerenkov's Avatar
cerenkov
I believe that he replaced it. Showed up on a smoke test above a certain psi. IIRC it was wzabrouski.
Old Dec 18, 2014 | 08:29 PM
ra2fanatic's Avatar
ra2fanatic
If it's the DV, it's a quick and easy check to see how if there is any damage to it. Just don't work on it while its hot, you might burn yourself =P
Old Dec 19, 2014 | 08:05 PM
wzabrouski's Avatar
wzabrouski
It was I. Still trying to hunt these two very frustrating codes! I thought it was the meth jet elbow but that was not it. Had both the high and low pressure fuel pumps replaced lately, thought that was it, no dice!
Old Dec 19, 2014 | 08:07 PM
johntotah94
Attachment 103863
Are you still trying to figure out the low boost issue? Sorry the picture is blurry on my phone..
Old Dec 19, 2014 | 09:06 PM
wzabrouski's Avatar
wzabrouski
Yep! 2C57 and 2C91
Old Dec 19, 2014 | 09:55 PM
johntotah94
Yep! 2C57 and 2C91
How long have you been encountering problems? Don't those codes mean like failed/stuck diverter? Have you removed it or replaced it? Or not yet.
Old Dec 19, 2014 | 09:56 PM
wzabrouski's Avatar
wzabrouski
One my second forge valve. Been back on stock for a month or so, same issue.
Old Dec 19, 2014 | 09:58 PM
johntotah94
How fast does the code come back when you clear it? Do you notice decrease in performance?
Old Dec 19, 2014 | 10:21 PM
wzabrouski's Avatar
wzabrouski
It is generally triggered on the highway holding steady at 70-75, give it very little gas then CEL.
Old Dec 20, 2014 | 01:25 PM
cerenkov's Avatar
cerenkov
I have noticed that with the Manic tune, the car does not like to be WOT in 5th or 6th gear with the RPMs below 2500.
Not sure if it acts the same with the stock tune loaded.
Old Dec 20, 2014 | 01:54 PM
wzabrouski's Avatar
wzabrouski
What do you mean?
Old Dec 20, 2014 | 03:28 PM
cerenkov's Avatar
cerenkov
It kind of stumbles.
Old Dec 20, 2014 | 04:54 PM
wzabrouski's Avatar
wzabrouski
No cel?
Old Dec 20, 2014 | 05:15 PM
cerenkov's Avatar
cerenkov
No cel?
No CEL, but I wouldn't have been surprised to get one if I kept doing it.
I rarely, maybe once a month, drive on the interstate so I don't recall if it felt the same on the stock map.
Old Dec 21, 2014 | 12:04 AM
johntotah94
Found the problem. Piece of crap.
Old Dec 21, 2014 | 04:43 AM
cerenkov's Avatar
cerenkov
Easy fix though. I wonder how often it will break with the higher boost you're running?
Old Dec 25, 2014 | 03:57 AM
Systemlord's Avatar
Systemlord
Probably by design, most piston failures occur at low rpm during high load, high boost so I have been told by some smart dudes!
Old Dec 25, 2014 | 11:54 AM
johntotah94
Lots of people get check engine lights with the forge unit simply because they are running the wrong unit. Is yours for the N18? I heard someone running a N14 forge unit on an N18 and couldn't figure out the check engine light. Vice versa.
Does your model match with the N18 one?
EDIT:
LOLOL. Scratch all that. Didn't read hard enough. I see that you went back to your stock one and you still have the same issue.......
When you clear the code on stock it still comes back right? ..
Last edited by johntotah94; Dec 25, 2014 at 11:55 AM. Reason: Didn't read properly
Old May 10, 2016 | 10:46 PM
pepperwhiteknight's Avatar
pepperwhiteknight
Got the power back!!!
Got a yellow half engine light but no CEL. Always triggered while on the highway and would go away if I restarted the engine. Carly had codes 2C90, 2C57, 2C91. In hindsight I actually heard the problem a week or two before the car acknowledged the problem. The turbo would just keep spooling when I hit the gas making an exaggerated high pitch sucking noise forever with weak acceleration. After replacing the diverter valve with a new stock one the engine has pull again along with the turbo sounding correctly. About 25,000 miles on Manic Stage 1 and 77,000 miles total. I pretty much always run map B.
Attached Thumbnails Diverter Issue?? Boost leak...-2016-04-25-18.56.23.png   Diverter Issue?? Boost leak...-2016-05-11-00.19.58.jpg
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
PEterChoqu
Aug 26, 2015 08:33 AM
Chasp
Aug 25, 2015 06:36 PM
