Drivetrain Water to air intercooler by FMD
Ok I wanted to post some numbers for everyone. I have installed a dual temp gauge, probes are at charge side, out of super charger, and inlet side, after intercooler. I was unable to get to the track this week due to a rain stom the day I had planned. I did however get to a dyno. During the dyno runs (3) we saw charge temps of 250 degrees F and inlet temps, after intercooler, of 120 degrees F. This was on all three runs, full redline runs. The dyno shop we used is in Parker, Colorado called Mac autosports. www.macautosport.com The guys there were impressed with the intercooler and will confirm these numbers. I laid down an average of 200 HP at the wheels corrected.
To give you all a reference point I have the following mods on my car: Rogue intake, header, 19% pulley, FMD water to air intercooler, lightweight flywheel, stage 2 racing clutch, salsbury LSD, and ECU remap.
Thanks for the numbers.
This makes me think of a related concern.
For a water to air intercooler.
How does the ambient temperature affect the efficiency of the intercooler compared to the air to air intercooler?
For example in a very hot environment like 100 degrees + would the water to air be more efficient at lower speeds like on the street or at autocross and the air to air more efficient at high speeds like on a track?
Then at lower temperatures say 70 degrees would it be any different or at 40 degrees any difference between the two? This concerns the ability for the air to air intercooler to succeed in creating a big difference in air temps vs the water to air.
mars31971,
How much was the install for your IC? How much larger than stock is it?
What is the maintenance recommended for it? Got any pictures showing the placement of the additional radiator for the system?
mars31971,
The ambient temp on these runs were 88 F on the first 2 and 90 F on the last run. The starting temp of the inlet side , after IC, was 10 degrees above ambient.
Ibelieve there are pics of the additional radiators in the first thread on this IC. Labor is approx. 4 hours. The system weighs about 16lbs. with liquid. There is no maintainance needed on the IC.
Originally Posted by weaverpsu
you don't have an aftermarket exhaust?
Originally Posted by dgszweda1
Was the EvoTech specially done for the 19% pulley? i.e. custom programming, lowered rev limiter....
Aug 11, 2015 09:01 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
M7Speed
Aug 6, 2015 01:48 PM
