Drivetrain Water to air intercooler
Old Jul 6, 2004 | 02:07 PM
  #76
Barnabas's Avatar
Barnabas
Andy's just keeping the vendor respectable that's all. hehe :smile:
I am too enjoying this and hopefully we'll have another great MINI product on the market.
Old Jul 6, 2004 | 02:15 PM
  #77
andy@ross-tech.com's Avatar
andy@ross-tech.com
To clarify, I really like the design of this IC and it may very well be the best solution we've seen so far. Of course the temp of the air going through the intake valves is what the engine actually cares about, but efficiency measurements allow us to calculate what that temp will be with varying supercharger outlet temps. Outlet temps can range from a little over ambient all the way to 250F and higher.
Sorry if any of my comments or questions were misinterpreted as being "bashing".
Old Jul 6, 2004 | 02:21 PM
  #78
Bisch's Avatar
Bisch
I have a suspicion that all of the belts that blew were NAPA's. The Goodyear GatorBack is a much stronger, flexible, and cooler running belt.
Old Jul 6, 2004 | 02:25 PM
  #79
clevy's Avatar
clevy
Nope, All of mine were car-quest which are made by gates rubber, what I need is a kevlar belt.
Old Jul 6, 2004 | 02:31 PM
  #80
andy@ross-tech.com
My NAPA belts were made by Gates.
Old Jul 6, 2004 | 02:36 PM
  #81
clevy's Avatar
clevy
From what I have seen most of the belts are either from goodyear or gates, but there are a few smaller companies.
Old Jul 6, 2004 | 02:56 PM
  #82
TonyB's Avatar
TonyB
Glad to see another IC option for us! And it appears that it might indeed be a very good one. I appreciate you coming on here to share, and respond to the many personalities who post here. If your product is indeed worthy, NAM will want to get the details to decide such...
As shared on a recent thread (and others for that matter), there are pros & cons of going with water. I for one, with the limited info I've accumulated, and with how I see myself using my MCS, feel that water might not be the most ideal solution. I would love to see your MCS on an "endurance" run of hard-driving.
While water's mass is a positive when it is cool (takes longer to heat than air), those same virtues work against it after it has heated. Masses of water have a moderating effect. Crossing the bridge from San Francisco to the East Bay (Oakland or Berkeley for example) reveals this on a larger climatic scale...
For some hard canyon driving, I don't see water as the best choice, and not just because of the aforementioned cooling attributes, but the heavier weight, increased cost, more involved install (shop time needed, probably not a DIY for many), and even possible maintainence (yes/no?). It would have to really outperform the best a-to-a unit to make this a viable option for some of us...
And if indeed it can get 3 to 5hp better (ideally more) than an aftermkt a-to-a unit, then that is something that can revealed on the track with improved lap times. Efficiency ratings taken under certain conditions, like those, would be most telling...
I am open to being convinced that a w-to-a unit is the way to go, and if so, I will glady consider yours!
Old Jul 6, 2004 | 03:52 PM
  #83
jlm's Avatar
jlm
a bit of info:
the air/water intercoolers that have been on the market previously used a core similar to the air/air (if not the very same core, with water chambers welded on). In these cases, the barrier between the mediums was a fairly thin (.025") aluminum sheet fromed into finned tubes with many, many oven welded seams. A potential for mixed media if there ever was one, although they have fared remarkably well.
The laminova core is much more robust, with many fins machined directly onto a solid water carrying core (no fin-to-core seams). Each water path/core is sealed from the air chamber by O-rings fitted into the end caps, a simple and robust system with basically four O-ring joints per intercooler. The only theoretical disadvantage is that the airflow path is considerably restricted in passing through the finned area, but mars seems to indicated this problem has been overcome. The system weight is significantly higher (I would guess about 30 lbs more, with core, hoses, water, radiators, pump and resevoir) and obviously more complex, compared to air-to-air.
I see that the 86% efficiency level for the laminova is also quoted on the kennebell site
Old Jul 6, 2004 | 04:47 PM
  #84
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Originally Posted by clevy
Oh yeah by the way I had the fastest car at the challenge.
Uh, excuse me?
Take a look at the time sheet - I have one if you need one. My fastest time was a 1:23.9. You can ask Anthony who had a watch on both of us as well. Just want to keep it straight - you weren't the only one bustin' hump out there! You were definitely faster than that other "265hp" car .
I am very interested in your testing, as I said to Anthony. I look forward to looking at the research and doing my own. So far, here are the impressions I have had on the current available units on the market:
Water has a very high thermal mass. This is great for removing the heat from the intake charge, but not so great for dissipating it after the fact in the radiator. That relates to the track and high ambient conditions in a very long recovery time to baseline. What ends up happening under constant load is like a domino effect - you get warmer water because the air through the radiator has less thermal mass, the intake charge cannot be cooled as much, so there is more heat in the mass, then the water gets warmer, and it starts raining, you don't have an umbrella, yada yada yada. The recovery rate will obviously depend on load and velocity, but averages about 5 minutes with no boost and 50 mph with an ambient of around 70F. I did this testing over a six month period with a thermocouple directly in the outlet path of the intercooler and read it on a Fluke - I backed it up with the OBDII inlet temp. Tip - make sure the thermocoupe doesn't touch the inside metal of the intercooler!
Air-air intercoolers cause more of a drop in pressure, but since we are more concerned with density, and both temp and pressure are part of that equation, the key is what the outlet temps look like. The air-air has a much faster recovery rate to baseline - like during a shift. The peak temps start out much higher, but over a short period of constant load, that peak temp very quickly becomes only slightly higher, and with the fast recovery rate of outlet temp, the average temp is significantly lower than the average of the water-air. You will have a drop in pressure with a drop in temp - that is just physics. You compress you heat, you lower pressure you cool. You also raise density if the efficiency of the core is good enough. That was the big reason we changed the core design of the Alta unit - it is a more efficient bar/plate design. It also has slightly larger end tanks to prevent some of the turbulence problems we found early on. There are obviously still issues with exit path and packaging restrictions, but to date, I have still found this unit to be the most effective production unit, especially with the water mister.
To get rid of packaging concerns and exit path, we have been developing a front mount air-air intercooler. The biggest issue with this unit is the price. I'll post more on this unit after more testing.
These have just been my personal experiences and data, and I have already talked with Anthony about further testing his water-air unit as well. I look forward to the future developments in this area, as it seems to be the most effective change after the pulley in saving or making power.
Hope that helps!
Randy
Old Jul 6, 2004 | 05:42 PM
  #85
BlueMCS's Avatar
BlueMCS
Bisch - Do you have a part # on the Goodyear belt for a 19% pulley?
jlm - Was that you driving to a 3rd place autocross finish?
Old Jul 6, 2004 | 06:08 PM
  #86
mtrspt5's Avatar
mtrspt5
Originally Posted by RandyBMC
Uh, excuse me?
Hope that helps!
Randy
Randy,
What are the chances of the unit being ready by the Labor day weekend????
Bruce
  #87
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Cross reference the 25-060539 NAPA belt. The 060535 is what a lot of folks use, but I have had much less of a failure rate with the slightly longer belt.Randy
Old Jul 6, 2004 | 06:09 PM
  #88
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Originally Posted by mtrspt5
Randy,
Bruce
Bruce,
There are five units coming in this week.
I still want to check the temps and pressures of the production unit, so they should be available by the end of next week.
Randy
Old Jul 6, 2004 | 07:11 PM
  #89
Barnabas's Avatar
Barnabas
Ok so watercooling is better if the water itself is cooler than engine temp, and once it becomes hotter than ambient temp, it gets harder to cool due to water's resistance to change in temp. Then why are all modern cars watercooled? It seems like under heavy load air cooling would be better suited for the car than water cooling, unless one is able to keep the water temps pretty low. Granted water temps from cooling the engine is probably alot higher than what we'll find in the IC, but it'll still be resisitance to cooling, and is ending up like an insulator more than anything. So why do we watercool all the cars nowdays?
Old Jul 6, 2004 | 07:16 PM
  #90
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Water is much more stable. When talking about engine temps, the thermal difference between the dissipation mass and the energy mass is substantial - ambient is always cooler than internal temps.
Randy
Old Jul 6, 2004 | 08:12 PM
  #91
Barnabas's Avatar
Barnabas
Randy
Ok, so are you saying that even after compression inlet temps are not hotter (or that much hotter) than ambient temp? Because if I'm reading your response correctly, you're saying because of the difference in temps (ambient being always cooler), watercooling the engine works.
Or are you saying watercooling the engine works because the difference is so big compared to heat generated through compression?
Sorry I'm so dense, I fail to see why water-air IC won't work in a similiar fashion to watercooling an engine. Is there also something going on between the water and air in the IC itself? Are you saying the air will heat the water instead of other way around in the IC?
Old Jul 6, 2004 | 09:13 PM
  #92
4GAZM's Avatar
4GAZM
i know this might get some bad feedback but just curious about those cryo tanks that freeze the intercooler for much lower temps my whole thing is would it work better than a bigger intercooler, not loosing boost and lowering temps lower than a big intercooler, im just wondering because its cheap to make one of these, and i dont have the money for one of these big intercoolers but if the performance is close then what the heck ill make one!!!:smile:
so to make a long story short is a cryo tank more economical and will it lower the temps more than a bigger intercooler!!!
thanks
Old Jul 6, 2004 | 09:19 PM
  #93
TonyB's Avatar
TonyB
There was at least one good size thread here on NAM about this. I believe MINI Madness offers, or at least offered such an option... It indeed makes it colder alright, and that was part of the concern - too dang cold, or radical of a temp delta over a very short span of time would be too harsh on the construction materials... There were other concerns as well. Try a search, and you should find plenty of reading...
Old Jul 6, 2004 | 09:24 PM
  #94
mars31971's Avatar
mars31971
here are few other options available for the center tube.
Old Jul 6, 2004 | 09:25 PM
  #95
mars31971's Avatar
mars31971
Acouple more shots.
Old Jul 6, 2004 | 09:55 PM
  #96
mars31971's Avatar
mars31971
This might help everyone, go to Laminova.com, goto OEM/consult and look at their references. You all may recogonize a few small companies that are using the system and just maybe Randy should let these engineers know they have it all wrong. I mean these companies have put a lot of money and time in this product, as well we have, and if it did not work they would not be putting them on their top notch vehicles. Not all applications are for intercooler purposses, they also use them in the engines and transmissions as well. Land Rover, Honda, Mercedes, Ford, Chevy, and Pontiac all use or have used them in one form or another. I will work on getting more data for you but I just wanted to point out that the product has been tested and proven for about 20 years and that no one in the MINI aftermarket intercoolers has that kind of testing or performance records to prove their products, and this unit does.
Old Jul 6, 2004 | 10:48 PM
  #97
TonyB's Avatar
TonyB
I was speaking with someone today in the MINI community about Laminova, and apparently they are indeed quite well-known. I have two questions on top of the efficiency ones asked earlier:
What is the weight of the entire system, minus the water?
What is the capacity of the system (amount of water in holds)?
Adding additional weight to the nose of an already front heavy MCS is not exactly desirable, but if the power gains are exceptionally more than aything else...
Very nice touch with the personalized colors!
Old Jul 7, 2004 | 06:49 AM
  #98
Bisch's Avatar
Bisch
thanks
The only application that this system works somewhat well for is drag racing. The system is limited by the amount of co2 you carry in the car. A 5 lb tank will only give you 30-45 seconds of effective use. If you cannot totally isolate the air intake path from the co2, it is worthless. You will actually lose power. It is a great novelty if you like hearing the psssssst sound when you spray.
Old Jul 7, 2004 | 06:55 AM
  #99
paulmon's Avatar
paulmon
Maybe I'm missing something but the center tube doesn't actually do anything, correct? It just connects the left to the right. Why then couldn't the stock intercooler be left in place so that the car gets cooling from the intercooler and the water to air?
I'm sure there is a reason for this, I just must be missing it.
Paul
Old Jul 7, 2004 | 06:57 AM
  #100
jlm's Avatar
jlm
some of the space between the snoots is used for the laminova box
