Drivetrain Water to air intercooler
Old Aug 26, 2004 | 09:00 AM
  #151
05JCWS's Avatar
05JCWS
Originally Posted by andy@ross-tech.com
I haven't seen temps anywhere near that high on the street, strip or track. Only on the dyno have I seen intake manifold temps that get to that level.
That is what I thought I had seen with your previously posted numbers. With nearly 200degrees, I can see Randy being concerned about the 19%, but of all the numbers I have seen with the 19%, he must be living in a supernatural physics vortex or something else must be going on, because no one is seeing temperatures that high.
In fact I would think that an air to air intercooler such as the one from GSR with it's increased efficiency would offset all temperature differences between the 19% and 15%.
Old Aug 26, 2004 | 09:06 AM
  #152
andy@ross-tech.com's Avatar
andy@ross-tech.com
Temperature, possibly. But the intercooler cannot help the drive power increase seen in the 19% versus the 15%. At redline, the 19% is eating up quite a bit more engine power than the 15%.
Old Aug 26, 2004 | 09:56 AM
  #153
mars31971's Avatar
mars31971
How is the 19% eating up more power, Because of the extra heat or what?
Old Aug 26, 2004 | 10:28 AM
  #154
RandyBMC's Avatar
RandyBMC
Temporarily Banned
As I stated, that number is on the track only, and peak at that. Around town, I can hit 160 on the stock intercooler.
The 19% is using more power because you are encountering more drag - the faster you spin, the more air you are trying to move. That ends up taking power to do.
I'm happy to show anyone out at the track that 195F with a stock intercooler - it isn't hard to reproduce.
Randy
Old Aug 26, 2004 | 10:53 AM
  #155
andy@ross-tech.com
By design, a Roots blower has drive power requirements that increase as the blower speed increases. In fact, it's not a linear relationship, but an exponential one, so spinning a little faster can require a lot more power.
Old Aug 26, 2004 | 10:55 AM
  #156
andy@ross-tech.com
Randy
I'd really like to see testing data for the stock and your aftermarket intercooler under the same conditions. If you'd like to send me one of your cf units, I'd be happy to test it for you. :smile:
Old Aug 26, 2004 | 11:23 AM
  #157
05JCWS's Avatar
05JCWS
Which redline? The redline of the 19% should be about 700 or more rpm lower than the 15%. From your Eaton graphs it is about 10hp at 16,000 rpm, which is lower than the 17,000+ rpm redline of the Eaton unit. Since we can't see the limits of the graph and can make a guess on extrapolation it looks like maybe a guess of 14hp at 17,000 rpm. If we modify the redline of the engine to match the redline of the SC for each pulley, than the power loss should be about 14hp (if it is truly a 5psi difference between the two, which I don't think it quite is, maybe about 4psi).
Old Aug 26, 2004 | 11:33 AM
  #158
jlm's Avatar
jlm
lets set up some track measuring standards so we can sort this out:
for example:
1. the car has to be moving at least 40mph? and have been moving for long enough for heat soak to be stabilized (as opposed to just starting moving after a heated run and a slow down that let the heat soak build while the cooling stopped)
2. no restrictions to the cooling air flow;
3. optimized cooling flow through intercooler (no removal of rubber between hood and intercooler top or removal of intercooler top cover, for example)
4. peak measurements are ok, consistent with the above.
the statements that: "195F with a stock intercooler - it isn't hard to reproduce." AND "Around town, I can hit 160 on the stock intercooler." need some filling in.
I can hit 160 after coming into NY from the highway and slowing down for 15 minutes of funky traffic, but that isn't really what we want to measure.
Old Aug 26, 2004 | 11:36 AM
  #159
andy@ross-tech.com
Which redline? .
I was referring to the redline of the engine.
Old Aug 26, 2004 | 11:48 AM
  #160
TonyB's Avatar
TonyB
Also, ambient temp is quite important, I would think. I will log IAT's this weekend with some spirited canyon driving and report back. I will upload logs that will show this in relation to speed, and among other things like coolant temp, timing adv and maninfold pressure... all recorded in 5 second intervals. I'll also note ambient temp.
Old Aug 26, 2004 | 12:33 PM
  #161
andy@ross-tech.com
Knowing the ambient temp, the intercooler inlet temp, and the intercooler outlet temp are critically important. Without all 3 of those pieces of data collected, there is no way to compare one intercooler to another. Luckily, efficiency calculations done in very cold weather match up very closely with those done in very hot weather.
Old Aug 27, 2004 | 08:08 PM
  #162
TonyB's Avatar
TonyB
I'm going to try to upload an Excel doc of a 12 min run this evening. As you can tell by the initial IAT and coolant temp, she was already warm from my commute home. The temps driving home were in the low to mid 90's.
After a couple minute rest, I fired her up again, and the MINI was reading the ambient temp as 88. I installed the CarChip E/X and went for a semi-spirited drive in the canyon where I live. Folks were coming home, so i really could not dig into it. I got 145 for a high (IAT). I got this figure, as you can see, when flooring it. I was really only able to do so just that one time. So, I can certainly see going higher on the street, especially with an ambient in the 90s to low 100s...
No Excel upload possible... So, I'll try Word...
Old Sep 15, 2004 | 07:05 PM
  #163
mars31971's Avatar
mars31971
O.K. I have a few numbers for you all.
Ambient = 80 degrees F
Before intercooler = 150 degrees F
After intercooler = 90 degrees F
This was during normal driving " for me" spirited through trafic with hard accelerations between lights and periodically for passing. These temps were the average during a 1 hour test period. Peak temps under hard acceleration were:
Before intercooler = 200 degrees F
After intercooler = 110 degrees F
Also we have made a design change to the air tube as the previous tube had too much flex and was continually breaking clamps. With the new tube the issue has been resolved.
Old Sep 15, 2004 | 08:22 PM
  #164
jlm's Avatar
jlm
just today, ambient about 65 F, recorded 240 F in, 110 out after a 3rd-4th gear WOT blast, probably hitting 80mph. stock intercooler.
Old Sep 16, 2004 | 08:33 AM
  #165
sfjames2's Avatar
sfjames2
Last weekend on a run thru and up mountain road that got up to 4000 ft in elevation on a 95 degree day. My intake temps got to 128 degrees with stock intercooler. I have the Alta air diverter with sprayer and when I used it, my intake temps would drop to 105-110 degrees.
Mars, glad to see some test results onthat intercooler, thanks. I do prefer the stock one with a sprayer though. take care
W0TM8
Dec 19, 2019 07:50 AM
5904
Aug 27, 2015 10:00 PM
Aug 11, 2015 09:01 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
M7Speed
Aug 6, 2015 01:48 PM
